Old 10-16-2011, 09:39 PM   #1
stoneweed1
My Ride: '01 330xi 200K miles
Lights flickering
330XI 195k MILES, replaced alternator under a yr ago
I start the car and immediately notice that while in park the headlights (including the side lights) flicker every second. So for one second its normal lights, then it dims down for a second and then goes to normal lights, and so on. With the dimming in and out, the lights coincides with the idle which goes from approx 500RPM (dim) to 600RPM (normal) and repeat. So its a constant phase every second.
Now when I put the car in drive with my foot on the brake, same thing, except maybe 1.5 seconds phase.
When I am driving the car at night, I notice the lights dimming in and out as well, especially on straight aways.
Coincidentally my right headlight just went out a few days ago and I replaced it and today my driver front headlight went out as well. I use sylvania silverstar and they generally don't last long, however I'm wondering if this dimming problem has something to do with it.
Any thoughts?
stoneweed1 is offline   Reply With Quote
Old 10-16-2011, 09:44 PM   #2
CaptainOversteer
My Ride: Has three pedals
i would make sure your battery and alt are working/charging properly for starters
Now Coding Cars in the Burlington,VT/Plattsburgh, NY area - PM if needed
BMWCCA # 461124
1986 325 - SOLD
2002 325ci
CaptainOversteer is offline   Reply With Quote
Old 10-16-2011, 09:54 PM   #3
immigrant
My Ride: 2001 BMW 330CI
Send a message via MSN to immigrant
If they are xenon maybe the ballasts are trying to retire.
FS OEM BLAUPUNKT CD PLAYER (no mode)
FS OEM 330 AIRBOX + NEW AIR FILTER
FS 35W CANBUS BALLASTS (UMNITZA)
FS COMPLETE OEM LIGHTS: FRONT,CORNERS, REAR
FS PEAKE TOOL
FS 2001 LCM
P.M. me for anything you are interested.
immigrant is offline   Reply With Quote
Old 10-17-2011, 12:53 AM   #4
stoneweed1
Headlights are H7
Old 10-17-2011, 03:50 AM   #5
Commando
My Ride: 'O2 325Ci TiAg Man
Did you check the alt. and bat. likr Captain Oversteer suggested? Results?
Commando is offline   Reply With Quote
Old 10-17-2011, 10:23 AM   #6
edsmax
My Ride: 01 330i
Send a message via AIM to edsmax
Check your taillight wires. They overheat and short out and will cause your headlights to flicker. Its a common fail point...do a search on it and you will find the fix.
Mods: OEM clears all around, ZHP ///M weighted shift knob, GruppeM CAI, UUC Clutch Stop, B&M SSK, red line fluids, golf tee
edsmax is offline   Reply With Quote
Old 10-17-2011, 10:24 AM   #7
edsmax
My Ride: 01 330i
OH, and stop using Silverstars - they have a short lifespan. I kept replacing mine every 3-6 months before I went back to stock bulbs.
