Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 10-17-2011, 10:49 AM   #1
kens5225
My Ride: 328i
Cool newb with a problem please help
I have a 328i that has been sitting for 10 months I went to start it and the battery was dead so I replaced the battery and now it still will not start all lights and everything works as normall motor will turn over but will not run.
kens5225 is offline   Reply With Quote
Old 10-17-2011, 12:09 PM   #2
xXSHR00MIESXx
My Ride: BMW 330ci Sport Pckg
Send a message via Skype™ to xXSHR00MIESXx
Did you blow in the exhaust =D
My 2004 330ci , Picture Taken By E46_Moonlight
xXSHR00MIESXx is offline   Reply With Quote
Old 10-17-2011, 12:18 PM   #3
kens5225
My Ride: 328i
No not sure what good that would do but I will try anything at this point lol.
Sent from my Droid using Bimmer
Old 10-17-2011, 12:21 PM   #4
peytonracer4
My Ride: '00 328i
Check all fuses.
Old 10-17-2011, 12:26 PM   #5
kens5225
My Ride: 328i
I will check. But would a fuse stop it from firing
Old 10-17-2011, 02:00 PM   #6
peytonracer4
My Ride: '00 328i
Well it could be a number of different fuses. One could've possibly blown during the battery installation. They control everything from the injection system to the fuel pump.
Ugh disregard the "net" at the bottom. Bimmerapp won't let me delete it for some reason.
Net
Old 10-17-2011, 02:10 PM   #7
kens5225
My Ride: 328i
Ok thanks I will check as soon as I get off work today. Will post results
Old 10-17-2011, 02:13 PM   #8
peytonracer4
My Ride: '00 328i
If your car is turning over but not starting I'm 99% positive it's a fuel delivery problem.
Check fuses then let us know what you found.
Old 10-18-2011, 09:04 PM   #9
kens5225
My Ride: 328i
Ok so fuses seem to be ok but I have no fuel at shrader valve.
Old 10-19-2011, 12:44 PM   #10
iliad
My Ride: e30 Turbo/e46 328ci
If the car has been sitting for 10 months I would think that the fuel is bad...
I would drain the fuel tank and refill it with new fuel, change the fuel filter (it may be clogged up and restrict the fuel from reaching the engine)
If that doesn't work I would probably replace the fuel pump.
iliad is offline   Reply With Quote
Old 10-19-2011, 12:51 PM   #11
iliad
Do you hear the fuel pump prime the system when you turn the key to the on position?
I would get a multimeter and check for power at the fuel pump as well. (The fuel pump power may be grounded...)
Old 10-19-2011, 02:31 PM   #12
kens5225
My Ride: 328i
Yes I can hear the fuel pump.
Old 10-19-2011, 02:58 PM   #13
iliad
Then I would definitely change the fuel filter...
I changed mine last week, it takes 20 minutes and it costs $17 for a bosch filter from pelican parts.
Old 10-19-2011, 09:26 PM   #14
kens5225
My Ride: 328i
Turns out it wasn't the fuel pump I heard. So what is the cheapest place to get a pump
Old 10-19-2011, 11:06 PM   #15
iliad
I would jump your fuel pump relay to make sure that the fuel pump is the issue.
Pelican sells a fuel pump for the e46 from VDO for $160
http://www.pelicanparts.com/cgi-bin/...9%2C%20Each%20
Old 10-20-2011, 12:50 AM   #16
Martin C.
My Ride: 02 325i; 91 318is
Perhaps it would help to know if the car was parked as a consequence of initial failure?
2002 325i Steel Gray
Soon to be traded for new Bimmer
1991 318is
Custom Sound System
Custom Alarm and RS
LED interior lighting
US Ellipsoids with HIDs
Rebuilt m42
ST Sway Bars and Welded Brackets
Bilstein HDs with Bav Auto Springs
Pfeba Rear Spoiler
New paintjob in progress!!!
1997 328i Boston Green - SOLD
1990 325is Red - SOLD (and totalled shortly after)
Martin C. is offline   Reply With Quote
Old 10-20-2011, 11:18 AM   #17
kens5225
My Ride: 328i
No the car was running fine when it was parked. Its my brothers he put it in a storage unit while deployed with the Marine corps
Old 10-20-2011, 11:25 AM   #18
kens5225
My Ride: 328i
Must I drop the tank to replace fuel pump or is there an easy way.
Old 10-20-2011, 12:03 PM   #19
CylonRed
My Ride: '01 E46 330i sport
No - access is from the top - under the back seat. Visit the DIY forum and search - there should be a thread on replacing the fuel pump.
CylonRed is offline   Reply With Quote
Old 10-30-2011, 09:09 PM   #20
kens5225
My Ride: 328i
Replaced the fuel pump and she started right up. Thanks for the help.
Display Modes
