Old 10-17-2011, 01:15 PM   #1
stoneweed1
My Ride: '01 330xi 200K miles
330xi alternator question
I need to replace the alternator. The online sites have 90V and 120V. Any reason to get the 90V since its cheaper. I have heated seats/AC/and the typical stuff. Thanks.
stoneweed1 is offline   Reply With Quote
Old 10-17-2011, 01:28 PM   #2
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Take your Air filter housing out to see which Alternator you do have. Probably need the 120A Bosch or even the 140A Valero Alternator.
Replace it with same one that is in the car now.
BMWCaptain is offline   Reply With Quote
Old 10-17-2011, 02:47 PM   #3
alwaysw
My Ride: '01 330i
In addition to determining which brand and amperage you have in your car, be sure to check the type of electrical connector it uses. If it is a 120A Bosch, it will be either rectangular or oval in shape. Pelican Parts carries both versions.
The rectangular connector will look like the one shown clearly in the second photo of this post:
http://www.e46fanatics.com/forum/sho...d.php?t=583423
Once you have the intake box off, you should be able to disconnect the plug without issue.
alwaysw is offline   Reply With Quote
