Old 10-17-2011, 02:08 PM   #1
Icexx99
My Ride: E46 M THR33 V3RT
Send a message via AIM to Icexx99
Where can I buy Thin Wall Sockets?
Ive been searching all over the internet no results, I need the specific External Torx E12 Socket for removal of the back end of the driveshaft off of my differential output flange but It needs to be thin walled.. my differential is shot and I need to change it... last time i changed my rear diff bushing i removed the diff and driveshaft in one piece..
Icexx99 is offline   Reply With Quote
Old 10-17-2011, 02:24 PM   #2
kfiggins
My Ride: e46 330ci ZHP
yeah i looked all through snap on and cant find it might be your best bet to call snap on and ask if they have it.
kfiggins is offline   Reply With Quote
Old 10-17-2011, 03:21 PM   #3
lcoleman
My Ride: '79 Massey Ferguson
I'd get a cheap one from an auto parts store and grind that sucker down. I've been through this with the output flange on an e30 trans...Snap-on doesn't often make thin-wall sockets in weird sizes (like 30mm, for example). Even if they do, it'll be ridiculously expensive.
Old 10-17-2011, 03:29 PM   #4
GoingNuts
Just Nuts
My Ride: 2004 330Ci
How thin a wall do you need. I used normal size socket http://www.machinemart.co.uk/shop/pr...=1&TC=SRC-torx and it worked for me:
GoingNuts is offline   Reply With Quote
Old 10-17-2011, 03:32 PM   #5
Phoenix330ci
My Ride: 04 330Ci Convertible
Sure you need thin walled sockets? I removed mine out of the car a few months back to replace the rear bushing and didn't use anything special to drop the rear out and I removed the drive shaft from the differential.
EDIT:
Also you need an internal socket (female socket) for those bolts. - See picture above, althought that is showing the half shaft and not the drive shaft.
Phoenix330ci is offline   Reply With Quote
Old 10-17-2011, 03:45 PM   #6
blarf
My Ride: 323i, 325iT, 540iT
Start asking around. Samstag carries all sorts of BMW tools, but you'll pay for them. Maybe Hazet makes something close enough? Zelenda also carries some nice, German tools. Can you fit an E-TORX box wrench in there? If so, you can find those at S-K resellers (NAPA used to stock some S-K items).
Originally Posted by howie View Post
do you park near poodles?
blarf is offline   Reply With Quote
Old 10-17-2011, 07:29 PM   #7
RKiepper
My Ride: 1999 E46 328I x2
A regular e12 socket will work fine, the auto parts store sells it in a set of 3. Your only having problems because the cv boots are in the way. Find a way to get under the car with the suspension in its normal position, and the socket should wiggle on the bottom bolt against the cv boot. Your gonna need an extension too.
RKiepper is offline   Reply With Quote
Old 10-17-2011, 08:15 PM   #8
jdstrickland
My Ride: '94 325iC & '00 323i
I bought a set of Star sockets for my car to do that job. Those bolts are not really what you think. They are a reverse-torx, for lack of a better description. I had never heard of a star socket until I stumbled across these bolts.
Old 10-17-2011, 10:58 PM   #9
blarf
Given that the OP labeled them "external torx", I suspect they're exactly what he thinks they are.
OP: http://garagejournal.com/forum/showthread.php?t=117754
