Old 10-17-2011, 06:37 PM   #1
cdseven95
My Ride: 328
All the problems with my E46 need input
All this happened in the last month
149k
FIXED
Cleaned throttle body (fixed eml light, throttle temp stuck code)
Replaced the CCV (fixed the "Chewbacca" noise)
Replaced starter
Replaced diff bushings ... Fixed clunk
Current issues
1)When I start the car the brake lights out indictator turns on for 5 seconds then turns off... All the light work correctly (I have a coupe)
2)I get like a slight hesitation... In first and reverse..
Only at slow speeds... If I accelerate faster I do not have the issue.
3)ABS Brake DSC lights on . I have no spedo, odo, or mpgs
I read the code and it is CAN to DME and both rear speed sensors
I assume the issue is the CAN to DME and the speed sensors codes are false
4) If I start the car cold and let it idle. The RPMs will dip
5) I have a cel for mass air flow and o2 deviation
Cleaned MAF with no success looks new..
6) I have the correct coolant level as indicated but the coolant light comes on when I turn the heat on...
7) The heat blows cool when I am stopped. Gets hot once I press the gas
cdseven95 is offline   Reply With Quote
