Sponsored by The Tire Rack
Old 10-18-2011, 07:16 PM   #1
a32axo
My Ride: 2004 bmw 330CI
rubbing issues
If im rubbing with a 255 30 19 in the rear, will I be able to run a 245 35 19 without rubbing or 235 or 225 35. 9.5 inch rim with et35. Thanks for input. Slight rub on very outside of tire.
a32axo is offline   Reply With Quote
Old 10-19-2011, 12:22 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
A 245/35 will be 10mm narrower, but it will be more that 3% outside of your oem specs due to the height.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 10-20-2011, 03:59 PM   #3
Woggster
My Ride: E46 M Tech
Is it possible to fit a 19x9.5" wheel to a non-M3 E46 Coupe without rubbing? What offset would i need? +35 or +38?
Any help would be appreciated, sorry to kinda hijack your thread
Woggster is offline   Reply With Quote
Old 10-20-2011, 04:25 PM   #4
a32axo
ummm 38
i think 38, or higher. I have 35 and rub, i dropped. I had 45 before, with 265 30 19 tire and slightly rubbed.
Old 10-21-2011, 12:00 PM   #5
VMRWheels
VMRWheels's Avatar
I would suggest a +45 offset to fit a 19x9.5
Old 10-21-2011, 03:47 PM   #6
Woggster
My Ride: E46 M Tech
Awesome thanks!
Can i fit a 19x10" rear with +37 offset? I know it's pushing it but i think it'll look sooo good (I've seen it done on another non-M E46)
I've lipped my guards and looking at getting coilovers aswell to try do all i can to fit them, is there anything else you can recommend to make them fit?
Sorry for picking your brain
Old 10-21-2011, 06:59 PM   #7
VMRWheels
VMRWheels's Avatar
I would have to say not without fender work and some pretty stretched tires. But another member has fitted a 19x10 ET37 wheel with -3 Degrees of camber and claimed that he had no rubbing issues. I dont know if he has fender work or not though.
http://forum.e46fanatics.com/showthr...ight=19x10+non
