E46 Xi Forum
Old 10-19-2011, 12:44 PM   #1
Mhnd
My Ride: 2004, 330XI
Smile XI service engine P0420,P0430,P1410,P0456
330xi w 130,0000 no records of O2 sensor replacement.
Recently changed engine oil, air filter.
About 2 months ago changed
Fuel pump
Fuel Filter
Service engine soon light on 10/18/11, after gas fill up from mobil 93.
codes are:
P0420
P0430
P0456
P1410
0420, 0430
Related to CAT or O2?
How should I handle this?
0456
Gas Cap
I checked, it looks good?!!! No cracks on seal, and cap is tight.
Should I Replace?
1410
Related to EGR?!!
Failed Evaporate canister purge regulator valve.
Car runs good, no problem or sluggish noticed so far!!
Any advice?
Thanks.
Mhnd is offline   Reply With Quote
Old 10-19-2011, 02:46 PM   #2
Kubica
My Ride: 2003 325xi
Are you sure the gas cap was on tight after you got gas? That will definitely throw codes. Don't top off either.
Old 10-19-2011, 03:11 PM   #3
Mhnd
Question
It was tight, and I only filled about 1/2 a tank. I even checked the cap multiple times and it was firmly secured. I'm kind of worried about the other codes related to the O2 or CAT. Does that mean that my cat is blocked/cooked. like I said earlier I haven't noticed any bogging or abnormal gas consumption issues so far, but it might be just a little while before I start noticing these kind of symptoms!! Any suggestions, or where should I start first?
Old 10-20-2011, 02:56 PM   #4
Mhnd
This is the weirdest thing ever happened and I don't have any explanation to why it cleared!! Yesterday after work I reset the oil change service light which displayed service mileage in the minus about ~ -77778, after moving the ignition key to position 1 while holding the odometer reset knob down for 5 seconds, let go and then holding again for another 5 sec .... The oil change service light was reset and this procedure cleared the service engine soon light !!!!!! Im not sure why but it was cleared. I'm not sure if this is a permanent fix but the light is gone now. I'll keep you updated if the SES light comes back again. Does it mean that not reseting the oil service light triggered all the codes above?! It's kind of weird and how it happened I'm clueless!!! Can someone explain?????
Thanks!!
Old 10-21-2011, 07:35 AM   #5
Mhnd
Anyone ..... ????
Thanks!
Old 10-21-2011, 10:03 AM   #6
Kubica
My Ride: 2003 325xi
Clear the stored coded and see what comes back. The codes are still there even if the ses light goes off.
Old 10-23-2011, 10:51 PM   #7
bimmer53
My Ride: 330I, 540I, 330CI
Light came on after fuel was added. It happened to me few times, even if you open and closed the lid, will take from few miles to couple days to clear the fault, then yellow goes off too. I don't know about reseting service counter will clear a fault, however if you do have problems, codes will remain in the system, you may get yellow light again.
bimmer53 is offline   Reply With Quote
Old 11-18-2011, 10:54 AM   #8
Mhnd
I cleared the stored codes, still no SES light, but after checking with OBD tool after a couple of days there was a pending code P0430 only.
Do u have any other suggestions? Again SES light is not present anymore!!
Some thread suggested replacing the post O2 sensor cylinder (4-6), is there a way to test before replacing? my OBDII provide the O2 sensors test, but what voltage should I expect from a good post O2 sensor. How can I determine if it's the O2 sensor or the CAT (hope not)?
Old 11-18-2011, 11:30 AM   #9
Kubica
My Ride: 2003 325xi
I'm not sure, but check for exhaust leaks. There might me new cats in your future, or an AA tune which eliminates that code.
Old 11-18-2011, 11:44 AM   #10
Mhnd
AA eliminate the code!! but what if there are problems with the CAT or O2? I will check for exhaust leaks.
