Old 10-20-2011, 04:22 PM   #1
radames15
My Ride: 2004 BMW 330ci
Promblem starting my 330ci HELP!
Hi people I'm having a problem with my 2004 330ci aut(not zhp). When I try to turn on my car it starts but didn't turn on,other times it turn on and off very fast but after do the same thing like 5 times it starts normally and sometimes also the light from the transmission(at the left of the letter of P,R,N,D) went on. If I keep playing turn on and off the light comes off and I can drive the car normally. The codes are camshaft sensor,crankshaft sensor,air mass meter...crankshaft sensor and air mass meter are new. I think it's maybe the ECU...What do you think? I read somewhere I don't remember that the anti theft system send wrong codes and didn't start the car, that I have to change the ECU...
radames15 is offline   Reply With Quote
Old 10-20-2011, 04:26 PM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
replace the sensors? why would it be the ECU?
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 10-20-2011, 04:45 PM   #3
ALPIN3
My Ride: E46 M3 & E46 323i
Possibly the fuel pump, but need to know more. It could be triggering the other codes since its "hiccuping" to get started right now.
ALPIN3 is offline   Reply With Quote
Old 10-20-2011, 05:13 PM   #4
radames15
the crankshaft sensor was replace...yes maybe it's the fuel pump thats my next step...i think its maybe the ecu because I have a vw with similar sympthons and was the ecu but I dont know my car has only 70k
Old 10-25-2011, 07:25 PM   #5
radames15
Today I check the car and its a electrical problem..there is no current in sparks when the sympthon occurs...what do you think? Ecu?
Old 10-25-2011, 07:29 PM   #6
chqj
My Ride: E46 320i
What's the code you have? That's fun stuff. People will help you out.
chqj is offline   Reply With Quote
code, e46, ecu, problem, starting
