Old 10-20-2011, 08:45 PM   #1
jracer72
My Ride: m3
Can e46 m3 suspension fit e46 330 ???
Can the Ground Control Koni Street/Track suspension setup from the E46 M3 fit the E46 330 ???????????????
jracer72 is offline   Reply With Quote
Old 10-21-2011, 09:21 AM   #2
T.B.W.
My Ride: 2001 330Ci
Yes, I believe, but I do not know how this will affect the handling. I know companies make coilovers that cover both m's and non-m's but there must be a reason these guys make two separate kits.
PSSHHH!!!
By mivdub at 2011-08-05
T.B.W. is offline   Reply With Quote
Old 11-06-2011, 12:58 PM   #3
Phantom Mark
My Ride: 2001 330i M-Sport TT
Spring rates I think you will find.
Phantom Mark is offline   Reply With Quote
Old 11-08-2011, 03:41 PM   #4
murph1379
My Ride: 2006 M3
Should fit, though if you're swapping camber plates as well, keep in mind that most companies make the M3 plates less aggressive, as they have more camber stock.
murph1379 is offline   Reply With Quote
Old 11-10-2011, 02:01 PM   #5
LivesNearCostco
My Ride: 2003 ZHP 6MT
I recently asked Ground Control this very same question, and while I recommend you contact them directly, I believe the answer is YES, except for the E46 Street and E46 Hybrid camber plates--those are specific to M3 or non-M.
--Rear shocks will fit
--RSMs will fit
--Springs should be the same size (not sure of recommended rates are exactly the same)
--Rear spring height adjusters will fit (non-M kit comes with reinforcement plates for cast aluminum upper control arm)
--Front struts will NOT fit stock non-M strut mounts
--But you can use the kit with Ground Control E46 non-M street camber plates (not strut mounts)
--Or I believe the GC E46 race camber plates (not strut mounts) fit both M and non-M
I was trying to buy the GC-valved Koni shock and dampers without their coilover kit or camber plates, with plans to use them with my stock strut mounts and TMS fixed camber plates. But they told me the front strut shafts on their specially valved Koni struts were 16mm not 14mm, so I also bought their E46 non-M Street camber plates to make it all work and have been pretty happy. Except now I think my stock springs might be too soft for track days and I need to get their coilover conversion kit.
Lowering my car's resale value one track day at a time...
Last edited by LivesNearCostco; 11-15-2011 at 02:40 PM. Reason: changed Ground Control "strut mounts" to "camber plates"
LivesNearCostco is offline   Reply With Quote
Old 11-15-2011, 12:44 PM   #6
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
I currently run an M3 GC setup on my non-m 330ci(bought it used). Works fine.
And yeah, from my previous research is that if you run camber plates you can run m3 suspension.
SL Blak Soldier is offline   Reply With Quote
Old 01-06-2012, 05:34 PM   #7
zcchen
My Ride: Z3M/F80M3
What about the other way around? I have the bilstein ride control on my non-m sedan and likes the fact it's electronically adjusted.. And I'm converting my sedan to a track car so ride control will be useless..
So can a non-M coilover set up fit on Ms?
zcchen is offline   Reply With Quote
Old 01-08-2012, 11:11 AM   #8
murph1379
My Ride: 2006 M3
As long as your suspension includes the top mount, it'll work just fine, though it may sit a little lower on an M3, as the M3 is heavier. If you can control ride height, it'll work fine on any non-Xi E46.
Old 08-04-2012, 12:32 AM   #9
Hornung418
My Ride: '04 MB ZHP
Bumping this from the dead.
Conversely - I'm going to be buying a non-M suspension for my Sedan, but I plan on upgrading the rear end with an M3 Subframe and the works. Will the Shocks and Springs in the rear work in conjunction with the M3 rear control arms and mounting points? If the only difference is the spring rates, then I think I'm okay to follow through with my order when the time comes. Just need some feedback from people who know, as my vendor is unsure of the fitment due to the nature of the rear end swap being uncommon and all.
TIA.
Hornung418 is offline   Reply With Quote
Old 08-13-2012, 02:43 PM   #10
Hornung418
My Ride: '04 MB ZHP
Bump.
Old 02-15-2013, 10:16 PM   #11
Cpconst
My Ride: 2004 e46 m3
Was the ground control set up from the M3 you bought a direct swap or did you have to change camber plates?
Cpconst is offline   Reply With Quote
Old 02-17-2013, 10:42 AM   #12
JohnBlaze
My Ride: Black Sunshine
the rear will be M3 rear will be fine with non-M shocks and springs
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 02-26-2013, 08:12 PM   #13
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I just took the TC Klines with Vorshlag plates off my 330, they go on my m3 with no issues. We'll see what happens when I align it.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 09-15-2013, 04:56 AM   #14
boostjunkie92
My Ride: 2004 330ci
So if I bought a coilover set or shocks and springs that were meant for an m3 it would fit my 330ci?
boostjunkie92 is offline   Reply With Quote
Old 12-08-2014, 08:05 PM   #15
Zawelch
My Ride: M3
Bigjae1976. Did you have any issues aligning your car? Looking to use some non-m suspension parts on my m.
Zawelch is offline   Reply With Quote
Old 01-09-2015, 01:09 AM   #16
ajai
My Ride: 330ci***65104; 328i
Bump
missed the ci, welcome the i
ajai is offline   Reply With Quote
Old 01-11-2015, 08:19 PM   #17
bigjae1976
bigjae1976's Avatar
The dampers and springs will work. The rear shock mounts are the same. The only difference is the front strut mount/camber plate. You can use a non-M camber plate in an M3 which is what I'm doing. Main difference is you end up with more camber (min camber is -3.0) and heaver steering from increased caster.
I don't think you can use the M3 front strut mount or camber plate in a non-M...or at least want to...because you'll have very little or no camber in the front at all. You need some negative camber in the front.
