Old 10-20-2011, 11:42 PM   #1
raywcleung
My Ride: 330i
E46 Headlamp reminder buzzer failure
Hi,
Does any one know where is the location of the E46 Headlamp "reminder buzzer" in E46 330i, this is a buzzer to remind you when your headlamp is still on when you unplugged the key. I dismantled the speedometer, and dismantled the driver side drawer ; look up into the steering shaft all the way to the left side, cannot find it, can anyone help please? I want to replace the parts. My Serial number is E46 NF00392, I cannot find in any diagram in realoem.com
Thanks and regards,
raywcleung is offline   Reply With Quote
Old 10-21-2011, 12:18 AM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
I'm assuming you do not have automatic lights.
Do you have any buzzer at all? If not, you'll need to check exactly where that buzzer is. To be honest, I don't know. I feel like it'd be part of the instrument cluster, or maybe even in the steering column itself.
Old 10-21-2011, 12:47 AM   #3
raywcleung
My Ride: 330i
Hi, I don't have automatic lamp, but I think there is a buzzer as I check other E46 have Headlamp on reminder buzzer sound. I think you may be right it may part of the cluster,
Old 10-21-2011, 12:49 AM   #4
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
there's a beep noise. no buzzer as far as i know on the e46. i know they buzzed on earlier models like the e30.
anyway it's under the dash by your feet. you'll need to look straight up to see it. it looks like a speaker, sorta
when you have the key in the 1st position it should make a beep noise too. this is coming from the same thing.
Old 10-21-2011, 09:42 AM   #5
raywcleung
My Ride: 330i
Headlamp reminder buzzer [dismantle Dash photos] need for help!!
I just dismantle the dash board and driver side drawer and driver lower dash cover again, and I completely dismantle the odometer, but cannot find any buzzer or any speaker devices, can any one help. The local parts seller quote me the parts for 50 UK pounds for the buzzer but he did not tell me the position, I can't install it even if I bought a new one? Any one has an idea?
See all photo attached.
https://plus.google.com/u/0/photos/1...52958185530881
ID:	421791   Click image for larger version
ID:	421792   Click image for larger version
ID:	421793   Click image for larger version
ID:	421795   Click image for larger version
Old 10-21-2011, 09:57 AM   #6
raywcleung
My Ride: 330i
Some more photo of Dash speedometer dismantle to solve the headlamp reminbuzzer issue
some more photos attached. thanks.
ID:	421797   Click image for larger version
ID:	421798   Click image for larger version
ID:	421799   Click image for larger version
ID:	421801   Click image for larger version
Old 10-21-2011, 10:47 AM   #7
peytonracer4
:D
My Ride: '00 328i
Dude you took a picture directly of it!!
You did all that crazy work when I told you EXACTLY where it is.
Look at the picture you posted that says obdII and other connections. See that little cover that looks like it could cover a speaker to the right? That's it.
Old 10-21-2011, 10:54 AM   #8
raywcleung
My Ride: 330i
Thanks, Let me check the right side speaker tomorrow morning, it is very dark 12:00am midnight in Asia, so I can check tomorrow if there is a speaker, thanks a lot! regards,
Old 10-21-2011, 10:58 AM   #9
peytonracer4
:D
My Ride: '00 328i
Alright. And btw euro coded cars don't have the beep noise I don't believe. So it's possible it's your coding and not a lack of an actual speaker.
Old 10-21-2011, 11:28 AM   #10
afstud
My Ride: 2003 ZHP 6-speed
im 100% on this, the speaker is mounted on the speedo cluster motherboard, its the black cylinder with the little hole on top, if yours does not work, its because yours is programmed that way, and the only way to get it to be on, BMW has to reprogram your car to have the chime on. here is a pic that i edited and circled the part.
afstud is offline   Reply With Quote
Old 10-21-2011, 06:50 PM   #11
raywcleung
My Ride: 330i
E46 Heallamp reminder buzzer help!
Hi, thanks all.
I dismantled the lower dash again, and it seems the round shape speaker stuff does not have any device in it, I peel off the trim, it just a has die-cut dash line preset for other for computers connections, may be ODB I or CAN BUS [may be for other countries][I don't know], It seems to be a integrated part of the plastic trim and did not have any sign of modifications or alternation, drill, break, but just a part of the whole plastic lower dash trim. . Please take a look on the picture.
On the Dash Board, please take a closer look of the picture of the right side of the dash speedometer circuit board picture that I taken earlier, mark [B], But I search real OEM and parts suppliers they don't sell individual components for speedometers, but instead he quote a parts for buzzer for headlamp reminder/door on for 50 UK pounds, so it must be somewhere else, I think it may be inside the speedometer, because speedometer they don't sell individual parts inside it. Let's take a look on the picture.
ID:	421896   Click image for larger version
ID:	421897   Click image for larger version
ID:	421898   Click image for larger version
Old 10-21-2011, 07:07 PM   #12
raywcleung
My Ride: 330i
This is a closer look of the speedometer dismantle I did earlier, but the part suppliers said they does not sell individual component for speedometer inside of it, but they do sell the parts call buzzer for headlamp reminder and door dime sound for 50 UK pounds.
Old 10-21-2011, 07:41 PM   #13
SweTurbo
Big Pimpin'
My Ride: 323i -98
Try removing your outside temperature sensor , dash should read -40C and should beep.
If no beep then beeper might be broken.
buzzer, headlamp, reminder
