E46 Xi Forum
Old 10-21-2011, 08:43 AM   #1
chaso
My Ride: 2001 330xi
Maintenance/Modifications
Hey all,
I'm about to dump $2k into my car on various parts and upgrades included but not limited to the following: all belts, diff bushings, water pump/thermostat, clutch/flywheel, coilovers (HR or KW), and a set of wheels.
I just wanted to know if anyone thought of anything else that should be addressed. I have all new fluids, cooling system, and front axles.
Thanks.
Sent from my SPH-D710 using Bimmer
OEM+ 2001 330xi | Steel Gray | Black | FK Highsports
chaso is offline   Reply With Quote
Old 10-21-2011, 09:53 AM   #2
SamDoe1
My Ride: 4cyl of fury
Better buy some more front axles to go along with the coilovers...
Also, change the fuel filter out and get the FCABs and the sway bar end links changed while you're in there.
Old 10-21-2011, 10:13 AM   #3
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
he listed he has new ones already
Id make sure your control arms are in good shape. if you are going to change the belts, tsat, might look into the oil filter housing gasket as well as thats known to leak.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 10-21-2011, 10:25 AM   #4
SamDoe1
I know, I said that because he's getting coilovers...
Old 10-21-2011, 10:38 AM   #5
wdeerfield
wdeerfield's Avatar
haha. dont scare him! its okay to go low (even if you become a snowplow like me in the winter). Im still on original axles, only one ripped boot since i owned the car and that was before going low.
Old 10-21-2011, 10:46 AM   #6
TR4G-
My Ride: '01 325xi, '90 325iC
word, Im on V1's and its treating my axles fine so far. I repacked all four front CV joints after a thorough inspection of the ball bearings and pieces, and all looked good. Been holding up without a leak for some time now. Um, but pretty sure if you are planning on getting KWs (~1600) then you should push up your 2k limit lol.
TR4G- is offline   Reply With Quote
Old 10-21-2011, 10:59 AM   #7
Kubica
My Ride: 2003 325xi
O2 sensors, plugs, fuel filter.
Old 10-21-2011, 01:30 PM   #8
chaso
My Ride: 2001 330xi
What brands do you recommend for FCABs and sway bar end links?
Forgot about the control arms! No leaks that I know of, but I do burn some oil. Maybe that's the culprit?
Yeah I'm leaning towards the FKs or HR as my list grows. I'm going to see if I can find some info./reviews on FKs.
Check, check, check.
Thanks everyone.
Old 10-21-2011, 02:00 PM   #9
ModBargains III
ModBargains III's Avatar
My Ride: E46
Have you addressed all the bushings yet? You might want to consider those as well when doing coilovers.
Sean S. | Sean@ModBargains.com |(714) 582-3330 ext 8009
We Specialize In: BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts |
BMW Wheels In Stock | BMW Intake Experts
Hours
Check out our Blog for updates & discounts!
ModBargains III is offline   Reply With Quote
Old 10-21-2011, 02:54 PM   #10
cardsfan007
My Ride: 2002 330xi
Bushings, sway bar endlinks, fcabs, all the strut mounts. Id definitely check your oil filter housing gasket, mine is currently leaking. And while you are changing that put on new pulleys and belts. Change plugs and filters, easy fixes that will make a difference.
cardsfan007 is offline   Reply With Quote
Old 10-21-2011, 03:10 PM   #11
jcarpfishman
My Ride: '01 330xi
Make sure to check all rubber parts while you're in there... I'm in the middle of a teardown on mine to replace the subframe bushings, so here's my firsthand experience suggestions:
Guibo - Mine looked fine upon visual inspection, but once I started poking it, found it was cracked all over and starting to dry-rot
Check transmission and engine mounts - The center metal chunk of the transmission mount literally fell out of the bushing when I pulled the aluminum bracket off
Subframe bushings - Once I got the subframe out, definitely glad I'm doing this as they are all visibly deteriorated / coming apart
These are just the things I've noticed so far, there may be more... back to the garage now.
jcarpfishman is offline   Reply With Quote
Old 10-21-2011, 04:05 PM   #12
john311tran
My Ride: awd + 5 doors
why are you changing? what's wrong with the ones in there? sometimes i feel like i'm the only bimmer owner that doesn't have thousands of money to throw into my car whenever i feel like it. it's not like i'm a high school or college student. i have a graduate degree and make good money. wtf?
john311tran is offline   Reply With Quote
Old 10-21-2011, 06:51 PM   #13
wdeerfield
wdeerfield's Avatar
^ second that. I only do the basic maintenance like oil changes, tire rotations etc.. Only when i do big jobs like brake changes etc.. will i address issues tied to those.
Old 10-21-2011, 07:57 PM   #14
325xittt
My Ride: 2003, 325 XIT
how about the vanos seals, DISA VALVE and check the Idle control valve
325xittt is offline   Reply With Quote
Old 10-21-2011, 08:13 PM   #15
john311tran
don't get me wrong.. there is nothing with changing out pretty old/broken parts. but wouldn't you think the guys at bmw, you know, the german engineers knows what's better for your car than the random dudes on e46?
idk, maybe it's just me.
john
Old 10-21-2011, 08:21 PM   #16
Mulatto325
My Ride: 325ci convertible
How many miles? If your doing plugs I would also do your VCG.
My tops down, its upset.
>>>Mulatto325<<< Build thread
http://forum.e46fanatics.com/showthr...087&highlight=
Mulatto325 is offline   Reply With Quote
Old 10-22-2011, 11:21 AM   #17
TR4G-
Yes, I have a high mileage BMW now and it's just not practical to throw money's into "mods" when the basic maintenance items haven't Been addressed. 157k bout to replace the ICV, VANOS seals, sparks, and VCG. I'm excited to feel this baby rev again!
Old 10-23-2011, 10:04 AM   #18
chaso
My Ride: 2001 330xi
VANOS seals a DIY job? Also, I'm unfamiliar with DISA VALVE and the idle control valve. Are they prone to failures?
112,400 miles. Plugs of course. VCG?
I plan to do all this maintenance before addressing anything that I'm actually interested in.
Old 10-23-2011, 10:07 AM   #19
TArse
My Ride: 03 330xi, 87 325is
My disa brokel the other day, im glad the pieces didn't get sucked into my motor. You need to check it just to be safe
Bimmer App - Because it's faster than my computer.
TArse is offline   Reply With Quote
Old 10-24-2011, 02:15 PM   #20
chaso
My Ride: 2001 330xi
Just pulled the trigger on some coils
I just saw a video on YouTube of how to check the DISA. I'll do that soon. Was yours rattling?
