Old 11-02-2011, 06:39 PM   #21
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Cool video, can't understand 3/4 of what he's saying, but still worth watching.
SUMMIT POINT WV 1:24:229 SCCA
Old 11-02-2011, 08:18 PM   #22
Nervous
My Ride: 01 330CI 6MT ZSP EU3
...meaning it wears, right? What kind of diff is in M3? 25%, 40%, variable?
Nervous is offline   Reply With Quote
Old 11-08-2011, 10:56 PM   #23
wtbass21
My Ride: 04 330i6
what if i want a 3.15 with a quaife already installed so i can just throw it in when it gets to my door? what type of diff is performance gearing using? O and i have a 330 6 speed so will my driveshaft work?
wtbass21 is offline   Reply With Quote
Old 11-08-2011, 11:17 PM   #24
Rob43
Rob43's Avatar
You can have Performance Gearing or Diffsonline build what ever you like, it's just a matter of money. Also, there may be shops in your area that have the skill to to build you a great diff. Give great consideration to building a 3.38 or 3.46, because you have a 6 speed. A 3.38 or 3.46 in a 6 speed will feel like my Quaife 3.15 in my 5 speed.
Old 11-08-2011, 11:27 PM   #25
wtbass21
My Ride: 04 330i6
Yea Im just asking if I were to go to performance gearing's site and order one right now what would the internals be, I can't find it anywhere on there as to what internals they use and I want a quaife since this will be a street car. And I considered the idea of 3.46 or 3.23 (used to have 3.38 in my 5spd it was awesome) but I plan to go FI in the future and don't want too short of gears.
Old 11-08-2011, 11:33 PM   #26
Rob43
Rob43's Avatar
Just give them a phone call tomorrow.
Old 11-09-2011, 12:16 PM   #27
murph1379
My Ride: 2006 M3
Performance Gearing uses a clutch-style, similar to diffsonline or OS Giken. Give Jim a call, he's great to work with. Make sure he understands your application.
murph1379 is offline   Reply With Quote
Old 11-21-2011, 08:30 AM   #28
sam323Ci
My Ride: 2000 323Ci
hey all, i am just wondering if anyone has any ratios higher than the 3.64. its all the same price on performance gearing from the 3.64 to 4.10 so jw if anyone has experience with a higher ratio.
sam323Ci is offline   Reply With Quote
Old 11-21-2011, 06:07 PM   #29
Jackcat559
My Ride: 2003 530
I went to 4.10, and don't recommend it. To do it again I woulddo 3.83 (or close to it)
Jackcat559 is offline   Reply With Quote
Old 11-21-2011, 06:30 PM   #30
Nervous
What is the gearbox? For 5 spd even 3.64 is way too aggressive. Even 3.46 is too aggressive.
Old 11-21-2011, 06:55 PM   #31
Jackcat559
My Ride: 2003 530
good point on the gearbox
Old 11-21-2011, 07:13 PM   #32
JohnBlaze
My Ride: Black Sunshine
Originally Posted by Nervous View Post
What is the gearbox? For 5 spd even 3.62 is way too aggressive. Even 3.46 is too aggressive.
3.46 isn't to aggressive, unless you plan on driving over 80mph a lot
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 11-21-2011, 09:11 PM   #33
Nervous
Calculate and decide yourself: http://www.bokchoys.com/differential...calculator.htm
For me, 3500 rpm at 75 mph is WAY too aggressive.... On 3.64 it will be 3675 rpm...
Old 11-22-2011, 02:08 AM   #34
sam323Ci
My Ride: 2000 323Ci
well its an automatic, so im starting with a 3.46... also im living in texas so going over 80 is a regular occurance. i also have the conforti software so ive bumped the rev limit to 7000. maybe the 3.91?? which puts me at 3101 cruising at 80 mph
Old 11-22-2011, 07:14 PM   #35
Jackcat559
My Ride: 2003 530
mine's an auto, 3.91 would be my max, 3.8x would be optimum
Old 11-23-2011, 02:39 AM   #36
sam323Ci
My Ride: 2000 323Ci
cool, thanks for the advice guys.
