Sponsored by The Tire Rack
Old 05-31-2003, 04:57 PM   #1
BigRain
^_^
My Ride: 316i
Anyone has a SEDAN w/ Spacers?
Anybody has a sedan w/ spacers on the rear? If so, what's your wheel and spacer size. Does it rub? did you roll your fenders?
'02 Ti Ag 4dr : 99% stock
BigRain is offline   Reply With Quote
Old 05-31-2003, 05:47 PM   #2
Mark@vfive
Banned
My Ride: be em veh
question is way to vague man, rubbing is gonna depend on what rims ure running what offset and size and what tire size
anyways, i got 5mm on top of +38 rims (8.5) with a 225 tire and its lowered pretty low and its barely clear (tho i think the bumper clip is getting in my way not the fender)
Mark@vfive is offline   Reply With Quote
Old 05-31-2003, 06:19 PM   #3
BigRain
^_^
My Ride: 316i
Sorry, let me provide the full detail. So, are you rubbing then? Did you roll?
ACS TypeIII 19x8.5 w/ 235/35/19 ContiContact Sports 2 tires
2002 330i w/ Sports Package
+ 7mm ACS spacer
I "believe" the offset of the rim is ET43 but don't know where to CONFIRM. and the ****ty thing is that apparently it only rubs on right turns too! @_@??? Or I just haven't had a change to make a sharper left turn since it's always easier to find a spot for right turns.
Old 02-20-2004, 08:22 PM   #4
sam
My Ride: E92 SB 335i
+ 7mm ACS spacer
Did you get your fenders rolled? And is your car lowered?
E46 Retired....................................Project E92 SB 335i
sam is offline   Reply With Quote
Old 02-21-2004, 03:52 AM   #5
rdsesq
ouroboros autorotica
rdsesq's Avatar
My Ride: 2002 330i
+ 7mm ACS spacer
If you haven't tried it yet, I would suggest rolling the fenders. You could also go to a 5mm H&R spacer. I am guessing that it rubs on a right turn and you are the only one in the car. So the rightside isn't under load, then the weight is transfered to the right side and it rubs.
I could be worng.
rob
"The existence of life is a highly overrated phenomenon."
-- Dr Manhattan
quis custodiet ipsos custodes
rdsesq is offline   Reply With Quote
