Australia
Old 10-31-2011, 06:45 AM   #21
fgin
My Ride: e46 facelift
Originally Posted by ///Pulo View Post
My headlight washers arnt operating at all.. How do I diagnose if it's the pump or something else?
I am planning to retrofit the headlight washers sometime soon. From what I know, you need to have the headlights on and then do the windscreen wash. See if the nozzles pop out and spray the headlights. Then every 5th windshield wash, the headlights should spray.
fgin is offline   Reply With Quote
Old 10-31-2011, 06:52 AM   #22
dan_1337
My Ride: 330CiC
^ I thought it was every third wash (likely to be wrong here) and don't think that your lights need to be on for them to be washed (could be wrong here too).
What I can say with certainty is that they don't get washed every time you do the windscreen wash! I'll see a bit of a spray mist come up from the front of my car every few windscreen washes, but I always lose count of how many between headlight squirts.
Oh yeah, and my washer pump failed about a year ago. Got it replaced with an OEM while it was at the mechanic for like $80.
dan_1337 is offline   Reply With Quote
Old 10-31-2011, 07:14 AM   #23
///Pulo
My Ride: 330CI///M individual
I did this test but I was told 3 times Aswell so only tried 3
Fk it I'll just get Worx to fix it I cbf with this ****
6s MT E46 BMW 330CIC Convertible M-Sport Individual Phoenix Yellow
///Pulo is offline   Reply With Quote
Old 10-31-2011, 12:16 PM   #24
aznstyler
My Ride: 330ci
anyone got a spare clip lying around? the one for the washer motor - headlight washer
aznstyler is offline   Reply With Quote
Old 10-31-2011, 06:44 PM   #25
steve330
My Ride: '05 330cic
Or you could just run a 12v line to it & test it that way...
On his deathbed:
Either that wallpaper goes, or I do.
- Oscar Wilde
steve330 is offline   Reply With Quote
Old 11-13-2011, 11:30 PM   #26
Ballistic325
My Ride: slow and steady
Also available from Burson for ~$50. Just called them for a price.
www.burson.com.au
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
