Sponsored by The Tire Rack
Old 10-24-2011, 04:35 PM   #1
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Peculiar tire wear: Hankook Evo V12
Both front tires are wearing on the same side. It looks like the tread is coming off. My camber in the front is 1.5 degs right and left.
Could it be the batch I bought is defective or are they supposed to wear like this? I only have about 1500 miles on the tires.
phamine is offline   Reply With Quote
Old 10-24-2011, 10:13 PM   #2
Blocked Out
My Ride: Imola 330i M-Sport
I think those tires arent designed for the driving style of yours. They seem to be overheated. This could be the problem , however I never seem anything like this, if you bought them at a local shop try to return them , if you bought them online then forget it. If it was me, Id still run them as I dont think this is dangerous.
Original BMW Teile ///
IMG_1725
Old 10-25-2011, 09:05 AM   #3
phamine
They may not be. I've tracked them for 6 days. I know people who have used these street tires for the track as a budget Direzza w/o having the same issue.
Old 10-25-2011, 09:34 AM   #4
truekreation
My Ride: E36, E46, R53
I've had mine for a few thousand miles and they look nothing like it.
| 1993 Calypso Red BMW 325is | 2002 Titanium Silver 325XiT (5MT) | 2004 Titanium Silver Dinan 3 | 2006 Hyper Blue JCW MINI Cooper S (6MT)
truekreation is offline   Reply With Quote
Old 10-25-2011, 10:29 AM   #5
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Any track time on these?
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 10-25-2011, 10:32 AM   #6
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
That looks about normal for 6 track days. My direzza's looked like that after 2 weekends.
My RS3s look pretty good after 2 track weekends.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 10-25-2011, 12:50 PM   #7
phamine
Thanks. yes - 6 days of track time over 2 months.
Old 10-25-2011, 01:47 PM   #8
bigjae1976
bigjae1976's Avatar
You'll see the tread blocks will kind of shift after some hard track sessions. Especially if your tires got greasy. Normal. I stressed over the same thing after my first track weekend.
I have noticed that street tires will ride much louder and a little rougher after each successive heat cycle.
Old 10-26-2011, 10:14 AM   #9
gvcmel
My Ride: 2004 330i ZHP
Assumption, all the wear is on the outside edge, tread and graining patterns seem to indicate that.
Too much tread depth, too much slip angle at the front which leads to too much heat and the tire starts to chunk up. Check your toe setting also. Suggestions - a little less bravado on corner entry and maybe a couple more pounds of air in the tires. Don't see the outside edge of the tire so can't tell how much roll over you are getting. Check the tire pressures when you come off the track. Without some guidance on this tire I can say the RS3 ( another Hankook tire ) likes 40 psi hot for best bite versus wear pattern.
gvcmel is offline   Reply With Quote
Old 10-27-2011, 04:12 AM   #10
zcchen
My Ride: Z3M/F80M3
I believe RS3 is the one u need
zcchen is offline   Reply With Quote
Old 10-27-2011, 06:19 AM   #11
bigjae1976
bigjae1976's Avatar
Yes, my RS3s are holding up pretty good but they are not so great on the street.
http://forum.e46fanatics.com/showthread.php?t=869823
