Sponsored by The Tire Rack
Old 10-24-2011, 08:48 PM   #1
Straightpipez
My Ride: 04 325i
Same size tires with different diameter?
My wife's 04 325i currently has 225/45-17 Hankook Ventus V4es tires on 17" OEM Sport Wheels (5 spoke "LA"). I recently bought a set of Beyern Mesh wheels and had mounted Conti Extreme Contact DWS (from TireRack, btw), same size as the Hankooks. The Hankooks are still on the car and when I set the Beyern's with the Conti's next to the front and back wheel, these things are like an inch taller. Can this be or will the new tires, under pressure from the weight of the car lower in height?
Straightpipez is offline   Reply With Quote
Old 10-25-2011, 10:33 AM   #2
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
If you simply roll one unmounted tire or tire/wheel next to one that is on the vehicle, yes, they will appear to look different in diameter. The vehicles weight on the tires will cause some deflection for sure.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
