Old 10-26-2011, 11:32 AM   #1
danpav325i
My Ride: 2004 bmw 325i
E46 325i Oil Leak HELP
i have a 2004 325i at 100k and im starting to have a small oil leak but its not at the oil pan but right underneath the engine not at the oil check tube or the atf tank its on the driver side so its not the vc gasket HELP
danpav325i is offline   Reply With Quote
Old 10-26-2011, 12:16 PM   #2
yrksccr6
My Ride: 2000 328Ci ZPP
http://forum.e46fanatics.com/showthr...&highlight=ccv
yrksccr6 is offline   Reply With Quote
Old 10-26-2011, 12:19 PM   #3
beauch3
My Ride: BMW 325
I search oil leak on my 2001 325 for a long time. It turns out that it was the gasket / oring on the oil filter housing. That is fairly common and there is a diy somewhere on this board that tells you how to change. Part was inexpensive but took long time. Because of what you need to remove to get to it, you probably want to consider doing other maintanence at the same time. Good luck. Oil leaks are a pain.
beauch3 is offline   Reply With Quote
Old 10-26-2011, 12:36 PM   #4
moiz21
My Ride: 1999 323i 5-SPD
Oil filter housing gasket. Time consuming, but over all not that bad.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 01-27-2012, 09:42 PM   #5
danpav325i
anything on diy window regulator
Old 01-27-2012, 10:08 PM   #6
forzam
My Ride: 04 325Ci
Try this:
http://www.skene.org/bmw/window/
forzam is offline   Reply With Quote
Old 01-27-2012, 10:15 PM   #7
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
They usually leak very little oil.
danpay, you must be new here!
If you want help with regulator, you can either just ask in a random thread above, or click search/advanced search/ and do a title search on that. You'll find many threads on it and many tips.
I don't want to ask why you're here wandering around, but I'm imagining you as sort of a 5 year old left alone by his parents in Times Square...like in Home Alone.
Read the threads on it...it's an easy diy...as they almost all are...when you know what you're doing! If you don't, just study until you haven't a clue! True Story.
You'll get used to the place pretty soon...or not. I don't how long I've been here and I still don't have a clue how it works!
Don't worry, most are far nicer than me!
Facebook.com/DMAXstandup
Mangofy your E46!
325i 2004, oil loss
