Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Lighting & Mobile Electronics (I.C.E.)
Xenon lighting, HID kits, fog lights, BMW head units, navigation, speakers, subwoofers, In Car Electronics (I.C.E.), carputers, DDEs, angle eyes, halos, LED tail lights, interior lighting, etc.
Old 10-26-2011, 10:39 PM   #1
Shimmy23
My Ride: ///M3
WTB: Bosch AL headlight Insert
I'm looking for a set of the preface lift AL headlight inserts... its the insert with hi beam bowl and projector mounts. Its the part at the top of this pics. I need the insert only, not the projectors or shrouds
Let me know what you have. Painted is ok too.
Shimmy23 is offline   Reply With Quote
Old 10-30-2011, 04:00 PM   #2
Shimmy23
My Ride: ///M3
Bump
Old 10-31-2011, 04:18 PM   #3
GCoop
My Ride: '04 325xi
Ive got AL single Xenon frames. The frame you have pictured is the Bi-Xenon frame. There are some subtle differences between the two. Most noteably the mounting holes are a little different and the high beam reflector is smooth vs the ribbed on the BiXenons.
So if you can use the single Xenons let me know.
GCoop is online now   Reply With Quote
Old 11-03-2011, 08:05 PM   #4
Shimmy23
My Ride: ///M3
is auto leveling mounts and such the same? if so, these might work.
Old 11-04-2011, 04:24 AM   #5
MJLavelle
My Ride: 2001 BMW 330ci
I have a set. PM me with an offer. They are from an M3 coupe, but are the same as the regular coupe.
Old 11-04-2011, 11:16 AM   #6
jack.chris328
My Ride: is a truck.
The mounting points are the same on single and bi-xenon.
jack.chris328 is offline   Reply With Quote
Old 11-04-2011, 08:05 PM   #7
keithyaka
My Ride: 2003 m3 coupe 6 spd
No they're not, they used different projectors with differences in the pitch between mounting holes.
The 1999-2001 single low beam xenon projectors will not fit a 2002-2005 Bi-xenon projector frame and vice-versa.
keithyaka is offline   Reply With Quote
Old 11-04-2011, 08:13 PM   #8
jack.chris328
True about the projector mounting. I should have been more specific I suppose. As I believe the question was in regards to attaching the insert to the housing. In which case the auto-leveling arm mounts the same and the insert attaches the same to the adjustment arms/screws on both inserts.
Old 11-07-2011, 07:48 PM   #9
Shimmy23
My Ride: ///M3
bump anyone?
Old 11-08-2011, 08:02 PM   #10
Shimmy23
My Ride: ///M3
found a set.
Old 11-08-2011, 09:11 PM   #11
MJLavelle
So, you won't need mine?
