E46 Convertible
Old 10-26-2011, 11:18 PM   #1
dsmer323
My Ride: e46 m3
Red face :( Convertible top stops half way and light blinks red
My top stopped working like a month ago haven't gotten diagnosed yet by a technician , but before I do I would like to get some input from you guys.my friend with a gt1 scanned it for codes and it shows (POSITION SENSOR VSW 4.2 ERROR). What can that mean? Or be? Perhaps a sensor? When I close the top manually I can't open it with the switch. But when I open it completely manually the top then starts to work when pressing the switch, the lid opens the softop starts extending to close position but then stops half way and light starts blinking read again any help is greatly appreciated!! Thank you in advance!
dsmer323 is offline   Reply With Quote
Old 10-26-2011, 11:20 PM   #2
SpadezMarquise
My Ride: None
Probably a sensor..i believe it had been covered before..but you can look for it..I'm sure stuff is out there
Sent from my HTC Glacier using Bimmer
SpadezMarquise is offline   Reply With Quote
Old 10-26-2011, 11:27 PM   #3
dsmer323
My Ride: e46 m3
Thanks, I did search before posting this thread but I couldn't find anything related to codes. I checked my hydraulic reservoir and it seems to be full. I also checked for blown fuses but everything looks okay. I'm. Guessing its a sensor too but don't know which one in particular. Maybe someone can point out which one with code I provided?thanks
Old 10-27-2011, 09:45 AM   #4
dsmer323
My Ride: e46 m3
Its has come to my attention that my rear defroster is not working either
Old 10-27-2011, 10:47 AM   #5
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Does your battery have a full charge? Low voltage can cause all sorts of strange quirks. Also check out the post found HERE, he ran into an issue with the drive unit failing, which judging by our records is common.
Drive Unit
ECS Tuning
Old 10-27-2011, 11:09 AM   #6
dsmer323
My Ride: e46 m3
What I have noticed is that if I leave the key in the ignition in position 2(cluster lights on) for 3 to 5 min my battery gives out. Can it be that if my battery is on it's last leg the top won't function properly?and even if I have the car on?I'm going to get my oem battery tested at autozone today. Thanks for the input ecs tuning oh and I did looked into the drive unit and what's strange is that when I manually completely open the top the light stops blinking red. I can then close the top automatically using the switch but soft top stops half way as its retracting to close positon and the red light starts to blink again
Old 10-27-2011, 11:10 AM   #7
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Give that battery a test, if it's on it's final leg than a new one might help out your top (and keep you from getting stranded with a bad battery).
ECS Tuning
Old 10-27-2011, 11:19 AM   #8
dsmer323
My Ride: e46 m3
Sure thing I will, thanks.
Old 10-27-2011, 12:13 PM   #9
sfhondapilot
My Ride: e46 M3 cic
Are you trying to close the top without the car running (battery power only)?
Before my battery cr@pped out, I had to make sure the engine was running if I wanted to raise/lower the top.
David
2007 997TT
2004 e83
2003.5 e46 M3
2008 e90 335xia
Sienna Limited AWD
sfhondapilot is offline   Reply With Quote
Old 10-27-2011, 03:15 PM   #10
dsmer323
My Ride: e46 m3
normally I do it with the engine running. When the top gave out I remember having the engine on.
Old 10-28-2011, 09:16 AM   #11
E46-Cabrio
My Ride: E46 330CI Cabrio
Read this pdf file and check all the sensors, I think it's one of the Hall (angle) Sensors in the tension Bow.
E46-Cabrio is offline   Reply With Quote
Old 10-30-2011, 06:53 PM   #12
Phoenix330ci
My Ride: 04 330Ci Convertible
Ok I had a similar problem with the top going about half way down. Find my thread on here about it. But to save you some time, mine was the wire harness. There was a broken ground wire in the harness the runs the length of the vert roof. My break was in the front section just over the drivers side. I had an indy shop find and fix it after I read every thread on here, the pdf and even drew my own mapped out diagrams to the sensors. What they did (and still feel way over charged for) is found the broken wire and then ran a seperate around the broken spot and tied it in on each end. Something told me it was going to be in the harness but I didn't want to listen to myself. Anyway, a new harness I think is around $150. Doesn't seem to be hard to do, but would be time consuming.
The drive unit that ECS is talking about is probably not the problem unless you are hearing a series of popping noise (actually that started today on my car and I was just going to write a thread on how I think I may have fixed that.)
Oh Yeah, make sure that battery is good. I noticed really slow action with my top when the battery was running down and this was while the car was running. I don't put the top down too often without the car running because it sucks up some of that battery juice.
Phoenix330ci is offline   Reply With Quote
Old 10-31-2011, 12:48 AM   #13
dsmer323
My Ride: e46 m3
Thanks for the taking the time to help me I greatly appreciate it ill be inspecting my wires hopefully this week. So now its either the hall angle sensor or the wiring harness. ill be inspecting the wires first before I move onto the next expensive part, the sensor. Anywho ill keep you guys updated and let you know what I find, hopefully its either one.
Old 02-01-2012, 12:23 PM   #14
savage33
My Ride: 2001 330 CIC
did you ever find out what was the problem and how did you fix it?
savage33 is offline   Reply With Quote
Old 02-01-2012, 02:25 PM   #15
dsmer323
My Ride: e46 m3
No no yet, but I think it might be the angle hall sensor, its located on the rear driver side brracket mechanism, its bolted on an l shape bracket. If you do replace before I do let me know.
Old 02-01-2012, 03:01 PM   #16
savage33
Did you ever figure out why your rear defogger isnt working?
Old 02-01-2012, 03:13 PM   #17
dsmer323
My Ride: e46 m3
I think it has to do with the sensor. I guess it somehow the hall sensor controls the defrosterfor for the rear glass. Why?did yours also stopped working?
Old 02-01-2012, 07:13 PM   #18
fmzip
My Ride: '08 328xi / '01 530i
maybe this will help
http://forum.e46fanatics.com/showthread.php?t=790169
fmzip is offline   Reply With Quote
Old 02-02-2012, 02:45 PM   #19
savage33
Yup! i had the same exact symptoms as you. the top went up half way and stopped. manually put it up and the light was just blinking until i drove it for a second. rear fogger stopped working shortly after.
Old 02-02-2012, 02:51 PM   #20
savage33
Originally Posted by fmzip View Post
Nice post!!
Did this fix your top problems? did you have a rear defroster problem too?
Also what were your symptoms when is stopped working?
