Thread Tools Search this Thread Rating: Thread Rating: 648 votes, 4.95 average. Display Modes
Old 02-25-2013, 09:14 PM   #181
bradleyg
unregistered user
My Ride: '02 325ci
If the oil is milky, its gotten coolant in it. There is a leak somewhere- a head gasket, crack in the block or head, etc. Not good either way. Do not drive it until you can get the engine checked out.
bradleyg is offline   Reply With Quote
Old 02-26-2013, 04:47 PM   #182
Mrkhanvict24
My Ride: 2001 BMW 325CI
Coolant leak
ID:	492705 this is the best picture I could get to show where the leak is coming from. I'm trying to get something more pinpoint
Mrkhanvict24 is offline   Reply With Quote
Old 02-27-2013, 12:32 AM   #183
CrazyOneToo
My Ride: 1999 328i 4dr
Originally Posted by Mrkhanvict24 View Post
Attachment 492705 this is the best picture I could get to show where the leak is coming from. I'm trying to get something more pinpoint
Sorta looks like the coolant level sensor is leaking.
Maybe spray it down with water to see where its coming from better??
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline   Reply With Quote
Old 02-27-2013, 09:59 AM   #184
capriccio
My Ride: 2002 325i
Originally Posted by CrazyOneToo View Post
I replaced my Expansion Tank about two years ago and assume its not that leaking again.
Its possible but looks like the radiator to me. The leak is a lil to high to be the ET.
I bought a new radiator and other parts and will do it on my Xmas time off from work.
I may sell the other new parts (ET, ET mount bracket, thermostat etc.) if my old ones are
still in good shape when removed and inspected.
Hey. I'm new to the site. I have the same leak as yours. What parts did you get to fix your leak ? Thanks !
capriccio is offline   Reply With Quote
Old 02-27-2013, 10:04 AM   #185
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
Few things in that area that could leaking:
expansion tank
upper radiator hose/bleeder screw
radiator where the upper hose connects
heater hoses connected to the et
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 02-27-2013, 12:53 PM   #186
CrazyOneToo
I unfortunately had to replace the radiator. It was leaking around the plastic ends of the rad.
Since I had to take it all apart to replace it I also replaced the expansion tank, ET bracket,
and auto trans thermostat (it breaks when coming apart). I shortened the reassembly steps a little when
putting it back together. I did it with the ET, ET bracket, therm, and bottom connector all assembled first.
Just look at it closely and make sure you get the ET mounting bracket hooks locked in where they go.
I'm not even close to being a mechanic and it wasn't so bad really. My hardest and worst part was the lower hose.
It was seized on and I had to wrangle it around and remove the radiator while it was still attached.
Old 02-28-2013, 09:57 PM   #187
jds400ex
My Ride: 99 323i
Why is this not a sticky???
jds400ex is offline   Reply With Quote
Old 03-01-2013, 10:05 AM   #188
330ciandr6
My Ride: .
Because quite a few people around here don't like me
Old 03-01-2013, 10:09 AM   #189
jds400ex
My Ride: 99 323i
Fair enough. Damn social politics.
Old 03-01-2013, 10:11 AM   #190
330ciandr6
My Ride: .
Originally Posted by Zell View Post
Sticky!!!
Originally Posted by Miko_10 View Post
so thats how that thing sets up, was looking at that on the site and was trying to figure out how it mounts.
This thread needs a sticky...
Originally Posted by Drewdown View Post
really awesome thread should be stickied
Originally Posted by chris10492 View Post
This is amazing! I'm surprised this is not Sticky'd yet!
Originally Posted by cjccww View Post
wow sticky!
I have some pics i can add from my latest adventures
Originally Posted by Alex323Ci View Post
Yep it should be. Funny how a thread about "What did you do to/for your E46 Today" is stickied and something useful like this isn't.
Is it in any way useful to have 530 pages long of people saying they washed their car stickied? As if anyone new is going to read 10 hrs of people washing their car or changing their oil post.
Is something like that an important thread for E46Fanatics to know or learn from or gather information?
it's comical to see that other thread Sticked and something useful to EVERY E46 owner. be they a DIYer or even a novice that takes their car in and what to expect and keep from getting ripped off.
i'm not saying every informative thread be Stickied. but this is certainly more deserving then that other thread. what a joke
STICKY
Originally Posted by ///MPR77 View Post
+1
OP, great write-up!
Read all of the above from this thread
I may actually add to this thread later today.
Old 03-01-2013, 10:26 AM   #191
330ciandr6
My Ride: .
Couple pics went down and couldn't edit the OP so:
Differential output seals
These normally won't pour fluid or leave a leak on your driveway. But you will notice the leak if you get under the car and look at the diff. They leak slowly and build up residue under where the axles bolt to the diff. This is what it looks like when one is leaking.
Water pump
This one is new with the pulley and belts removed, but it will be leaking from below this area.
Old 03-03-2013, 06:05 PM   #192
corollers
My Ride: 2001-e46
sub!
corollers is offline   Reply With Quote
Old 03-12-2013, 11:29 PM   #193
NCLee
My Ride: 2004 330xi
Send a message via AIM to NCLee
WOW! Thank you so much, 330ciandr6. I've had an oil leak for a year, and THEN I found your post. I replaced the valve cover gasket, the oil filter housing gasket, and the VANOS line. STILL had a leak. After all of this, and finding your article, I found it was #4, the oil separator drain tube. It was degraded to a point of having a HOLE in it, on the side towards the front of the car. The whole rubber hose was soft and mushy, with a big oily tear in the front. I'm oil free for two days, and I'm grateful to you. Well done!
NCLee is offline   Reply With Quote
Old 03-19-2013, 08:27 AM   #194
330ciandr6
My Ride: .
Old 03-19-2013, 09:49 AM   #195
scarede46er
My Ride: 2001 BMW 325i ZSP
What about the front main seal? Is that a problem usually?
Old 03-21-2013, 10:29 AM   #196
330ciandr6
My Ride: .
I've never had to do one. I'm sure it has happened. But its not very common.
Old 03-21-2013, 10:32 AM   #197
My Ride: Lexus
330ciandr6.
Old 03-22-2013, 03:29 PM   #198
330ciandr6
My Ride: .
oh.
Old 04-01-2013, 08:56 PM   #199
eksath
My Ride: 02 330ci TopazBlue
Originally Posted by 330ciandr6 View Post
Thanks for this thread. This is really helpful. I am trying to chase down the source of some oil droplets on my driveway ( I am not even sure it is my E46 ) however this is a good starting point!
www.starracer.us
People believe in Ghosts, UFOs, talking to the dead, advertising, magic, curses, voodoo dolls, Elvis' death faked, the Great Pumpkin, Tupac still lives, the WWF, that all the moon walks were staged, real unstaged audience questions in talk shows, JFK's conspiracy assination theories, TWA 800 shoot down conspiracy theories, the image of the Virgin Mary appearing on a left over pizza, that Dr. Laura has no bias, that homosexuality is a choice, the guests on Jerry Springer, the TV illness of the month, that guns don't hurt people do, that CNN doesn't hype stories, the Osbornes not being staged, that a pill can make you loose weight without ever dieting or excercising, that there's a cure for baldness, aging and being short, that Britney Spears doesn't lip sync, That KFC is a healthy food choice, that the British Royal family isn't disfunctional, that there really were weapons of mass destruction in Iraq, that all Arabs are the same, that Muslims encompass everyone from Indonesia to Morocco and they are all extremists, that all Americans are the same, that's it's always cold in Canada, that cigarettes aren't addictive, that it's ok to drink but not ok to smoke up.........and on and on and on and on...... so what on Earth makes anyone believe that there is something unusual about people fearing the number 13 or astrology?
eksath is offline   Reply With Quote
Old 04-04-2013, 11:08 PM   #200
Tament
My Ride: 2001 330I
Excelent thread
Tament is offline   Reply With Quote
