Thread Tools Search this Thread Rating: Thread Rating: 648 votes, 4.95 average. Display Modes
Old 02-21-2012, 09:04 PM   #81
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
Glad everyone likes the thread!
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 02-22-2012, 01:22 AM   #82
CrazyOneToo
My Ride: 1999 328i 4dr
Originally Posted by momofthree View Post
Brilliant pics...thank you!
This weekend is oil and coolant leak day: oil seperator, hoses, clearing dipstick, oil filter housing gasket, vanos line, disa gasket, throttle body hoses boot, etc., water pump, thermostat gasket, thermostat, drive belt, power steering reservoir, air dist, coolant flush, oil change...and I THINK *fingers crossed* that's it.
Any truth to the transmission never needing to be flushed or have filter change? Mine is 2005 330i w/160K...
Well...I called BMW today and asked if they could flash my comp to stop a hard shift down I am getting.
First thing the guy said was since my car has over 100K miles I need to do a BMW trans service immediately. ($800)
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline   Reply With Quote
Old 02-22-2012, 08:38 AM   #83
330ciandr6
My Ride: .
100k is technically when they are supposed to be done.
Old 02-22-2012, 11:28 AM   #84
CrazyOneToo
Any idea what is included in that $800 service??
If that's changing all the seals and things that need to be changed that's steep but better than a new transmission.
If its just fluid and filter change then that's ridiculously high priced.
Old 02-22-2012, 11:37 AM   #85
Platinum_MV
My Ride: 2001 330ci
Very NICE!!! Great info... Mine is leaking from the heater hoses that connect to the front of the engine... Does the intake manifold have to come off to fix this? also Part #'s would be great.
Thanks!!!
Platinum_MV is offline   Reply With Quote
Old 02-22-2012, 06:04 PM   #86
330ciandr6
My Ride: .
Not sure what all they were quoting honestly
Old 02-22-2012, 06:05 PM   #87
330ciandr6
My Ride: .
Thanks!!!
Talking about the plastic tubes?
Old 02-27-2012, 11:16 AM   #88
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
Thanks for this helpful thread. :thumpsup:
I have already followed the same inspecting procedure and found out that i have a power steering fluid leak, and i hope its just the clamp. Gonna fix it today at my dad's shop.
This leak has given me a big problem, because all the fluid spilled on my garage floor.
Sent from my ADR6400L using Bimmer App
rizwan1377 is offline   Reply With Quote
Old 03-02-2012, 08:28 PM   #89
kwheat
My Ride: E46
so I just recently replaced my valve cover gasket because I was leaking oil. however it is still leaking. I usually have a lot of oil on top of my oil filter housing, do you think it is my oil filter gasket leaking? is there any other way to tell what the leaking is from. it is definitely the oil that is leaking as my oil is usually low.
kwheat is offline   Reply With Quote
Old 03-02-2012, 10:56 PM   #90
330ciandr6
My Ride: .
Is it the vanos line dripping on the filter housing? Post a pic.
Old 03-03-2012, 09:50 AM   #91
momofthree
My Ride: 2005 330i
Your vanos line might be leaking, or the hose to your oil seperator. Can you post a few pics?
momofthree is offline   Reply With Quote
Old 03-03-2012, 10:25 AM   #92
kwheat
My Ride: E46
Ok so I'm not sure what I am actually looking for but here are the pics that I just took.
https://dl-web.dropbox.com/get/IMAG0226.jpg?w=5cd46655
Usually the oil filter housing on the left is covered in fresh oil, it has been sitting over night so it must have dried up.
https://dl-web.dropbox.com/get/IMAG0227.jpg?w=493d0cf8
You can see that the valve cover gasket doesnt appear to be leaking and you can actually see the sealant.
https://dl-web.dropbox.com/get/IMAG0228.jpg?w=c6fb129c
Blow up of sealant.
https://dl-web.dropbox.com/get/IMAG0229.jpg?w=336e197f
Very Dirty
https://dl-web.dropbox.com/get/IMAG0230.jpg?w=932b90c6
https://dl-web.dropbox.com/get/IMAG0231.jpg?w=ce718764
Side View
https://dl-web.dropbox.com/get/IMAG0232.jpg?w=a1485099
If i need to take anymore pics just let me know what I need to take a picture of and from what angle(s)
Thanks a lot guys!
Old 03-03-2012, 12:39 PM   #93
330ciandr6
My Ride: .
Those links don't work for me. Maybe cause I'm on my phone?
Old 03-03-2012, 02:39 PM   #94
kwheat
My Ride: E46
Sorry about that, must be something wrong with the link.
Try this http://photobucket.com/kylebmw
Old 03-03-2012, 09:54 PM   #95
momofthree
My Ride: 2005 330i
The power steering reservoir looks like your cap/seal is oozing. Also may be your vanos line, from what I can see from my phone, its pretty oily. Cheap fix, two bolts, two washers and line will run about $40...i got mine from ecstuning. Hard to tell if oil filter housing is leaking, easy to swap out as well, dont forget a new gasket. Vcg looks good!
Old 04-07-2012, 10:28 AM   #96
ntrist
My Ride: 2002 325i
Awesome post, thank you all. I am a first time poster and found this thread when my oil separator valve was toast. I replaced it and nine hours later my 2002 325i was running. Now the coolant light comes on with the oil light on startup and then goes off when running. I have had to refill the coolant several times after going 30-40 miles. Anyone have any idea if I could have created this leak while replacing the oil separator valve? It seems like I would have needed to have the hands of a five year old chinese girl in order to do this smoothly so there is a strong chance I could have hit something.
Another issue that arose last night was that my car would start and then die after a few seconds. Pushing the gas pedal did nothing. I have had an issue in the past with my fuel gauge not registering an empty tank so I am assuming it is a fuel pump issue. I just wanted to thank you for the info and find out if anyone knows of something stupid I may have done that is causing this. My car has 130,000 miles so all of the plastic parts are engineered to fail by now.
ntrist is offline   Reply With Quote
Old 04-20-2012, 08:42 AM   #97
CAFFN
My Ride: 2002 316ti Compact
Detail:
Could this be the oil filter cap leaking?
BMW 316ti Compact
CAFFN is offline   Reply With Quote
Old 04-20-2012, 08:49 AM   #98
330ciandr6
My Ride: .
That looks like where its coming from.
Old 04-20-2012, 08:55 AM   #99
AkuE46
My Ride: 2001 BMW 330ci
Thanks for this thread.its really helped me diagnose multiple leaks i've been experiencing. Boss! Will be replacing parts asap
Sent from my SGH-T989 using Bimmer App
Being content leads to imperfection,
The inability to find satisfaction leads to glory.
AkuE46 is offline   Reply With Quote
Old 04-20-2012, 09:14 AM   #100
330ciandr6
My Ride: .
