Thread Tools Search this Thread Rating: Thread Rating: 648 votes, 4.95 average. Display Modes
Old 11-15-2012, 02:20 PM   #141
scim459
My Ride: 14 328i, 05 325cic
Well determine the type of fluid it is. It's all easy to remove that cover under the steering column. Take s look around in there
scim459 is offline   Reply With Quote
Old 11-15-2012, 02:40 PM   #142
Mhnd
My Ride: 2004, 330XI
Originally Posted by turnerk2 View Post
thanks! do u reckon maybe 15lbs torque will be ok for the housing itself?
I used 16 foot-pounds ..
Bolt is 8mm Grade 8.8
Mhnd is offline   Reply With Quote
Old 11-15-2012, 04:55 PM   #143
Itzed
My Ride: 2004 325xi
Just a wild guess, but heater core? Does it smell like coolant?
Itzed is offline   Reply With Quote
Old 11-15-2012, 05:26 PM   #144
turnerk2
My Ride: 02 325i
Thanks man, I'll let ya know how it turns out!
turnerk2 is offline   Reply With Quote
Old 11-15-2012, 09:25 PM   #145
damian12
My Ride: E46 M3
Isn't that usually passenger side?
I tried a picture, a bit fuzzy, but it is indeed leaking down the clutch shaft. On RealOEM they show an input and output clutch cylinder. Is that the master and slave?
Where is the slave cylinder on this car? (it's a 330Ci)
I can't tell by smell, my smeller isn't very good. The color is blue, as are my coolant and brake fluid. But, it's very blue, like my brake fluid. That's why I am thinking master or slave cylinder.
damian12 is offline   Reply With Quote
Old 11-20-2012, 11:30 AM   #146
greenpick
My Ride: 2001 325i, 1994 318i
Great post, thanks. I need work on the oil housing seal as the leak is getting worse. Both the Dealer and my local mechanic say that the oil housing should be replaced when putting in the new seal. This doubles the cost to have them do the work. I did not read this in the post. Just asking for some opinion about replacing the oil housing. Is this common for this fix?
greenpick is offline   Reply With Quote
Old 11-20-2012, 05:01 PM   #147
Itzed
My Ride: 2004 325xi
Originally Posted by greenpick View Post
Both the Dealer and my local mechanic say that the oil housing should be replaced when putting in the new seal. Is this common for this fix?
That's the first I've heard of that, and I can't imagine why that would need to be replaced. There are no moving parts inside, it's just like an extension to the block.
Old 11-20-2012, 10:22 PM   #148
greenpick
By happen chance, I was at the local Dealer today to get some parts and asked the service folks why change the oil housing. They said you might not have too but that the housing can warp and even with a new seal it will still leak. Were they just trying to make a little more $$, who knows. Just what they said. Just because I am an old guy and tired of wreching on cars, I will just go with what they suggest, so if it still leaks I can complain and get them to fix correctly. Tired of pools of oil in the garage.
Old 11-21-2012, 11:24 AM   #149
turnerk2
My Ride: 02 325i
i used those torques u mentioned, thanks! everything seems to be ok, i havent looked under car yet this morning, cleaning all that gunk from off the surfaces down there really sucks, i didnt get all of it, thanks again for the info, took me maybe 6 hours to do it, changed oil as well..
Old 11-21-2012, 01:16 PM   #150
samson
My Ride: 05' 330i
Send a message via AIM to samson
funny, I changed my VCG (no leaks) as preventative maintenace.. and it's leaking with the new one :/
samson is offline   Reply With Quote
Old 11-21-2012, 01:33 PM   #151
turnerk2
My Ride: 02 325i
when i did mine it did too, like an idiot i over torqued the bolts, squished the gasket and caused leakage, loosened the bolts and stopped leaking, iirc the torque spec is maybe 7ft/lbs on vcg
Old 11-21-2012, 10:45 PM   #152
jcallanan
My Ride: 2000 328Ci
Awesome post!
jcallanan is offline   Reply With Quote
Old 11-23-2012, 07:20 AM   #153
Boboshanti
My Ride: e46 330i and 316i
Oil leakage
I noticed an oil leakage under my 316 e46 2002 with N42 engine. I have been trying to figure out the source of the leakage. I need help badly. I made some pictures of the leakage and i hope it helps to solve my problem.
ID:	479276   Click image for larger version
ID:	479277   Click image for larger version
ID:	479278   Click image for larger version
ID:	479280   Click image for larger version
ID:	479281   Click image for larger version
ID:	479282   Click image for larger version
ID:	479284   Click image for larger version
ID:	479285   Click image for larger version
ID:	479286   Click image for larger version
Boboshanti is offline   Reply With Quote
Old 11-23-2012, 07:48 AM   #154
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Bobo, You really should clean things up and then look to find your highest sources of leaks...and work down from there.
Oil/PS fluid will leak, drip down, blow back and can potentially cover everything. It looks like your valve cover is leaking, but you really should confirm things by starting fresh.
As I'm sure you learned from this thread, there are a number of strong possibles...it's hard for me to say from your photos what's probable, though.
(My oldest friend is from Kumasi Asho...anywhere near you?)
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-23-2012, 07:57 AM   #155
Boboshanti
Dmax thanks for your great idea. I think it will be best to start all over again like you said.
( Your old friend lives 250KM away from me. I am in central part of the capital, Accra.
Old 11-28-2012, 07:43 PM   #156
COBYATCH
My Ride: 03 325i
Anybody know what this is? I noticed it after checking my coolant level, which was low, but I'm not sure if that relates to this.
COBYATCH is offline   Reply With Quote
Old 11-29-2012, 06:37 AM   #157
Itzed
My Ride: 2004 325xi
Looks like baked coolant to me. I would first suspect that its boiling over from the radiator because the cap is not holding the pressure. Just my guess, I'm not a doctor and don't play one on TV.
Old 12-03-2012, 04:13 PM   #158
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
Looks like you may need a clutch master cylinder.
I have only seen this happen once in about 6 or 7 years. Its rare, but can happen.
You sir will soon need a radiator. Happened to mine a couple years ago. The plastic at the corner where the tube sticks out becomes weak and cracks. Might want to go ahead and replace it so it doesn't leave you stranded.
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 12-03-2012, 05:43 PM   #159
Boboshanti
i finally had it fixed. My valve cover gone bad. I had it replaced today. Thanks once more Dmax
Old 12-04-2012, 02:25 PM   #160
CrazyOneToo
My Ride: 1999 328i 4dr
Same issue on mine just not dried up yet.
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline   Reply With Quote
