Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 10-28-2011, 03:36 PM   #1
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
For Rent: Rear Wheel Bearing Tool - $55
I have a rear wheel bearing tool kit for rent...gets the job done pretty easily. I will include:
1. SIR B90 tool set
2. wrench and socket for the B90 tool set
$350 - 2 week rental, deposit, and one-way shipping
$295 - returned upon receipt to tools
Your cost - $55. Paypal the total to bigjae1976@hotmail.com. Buyer should add 3% for paypal fees if applicable. Or I can just deduct them from your deposit refund.
I ship it out. You have 2 weeks to use the tool. Ship it back to me at your expense (cost is $10.50, it fits into a medium flat rate box). Each additional day beyond 2 weeks is $5/day or $20/week. Once I receive the tools back and check them, you receive your deposit back.
I won't be anal on the 2 weeks unless someone else is waiting or I need the tool.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-09-2011, 06:13 PM   #2
bigjae1976
bigjae1976's Avatar
Just got the tool back. A local will use it this weekend...so it will be available to ship out on Monday!
$55 to rent! Your total cost should be no more than $67 with return shipping...unless you ding some of the mandrels.
Old 12-21-2011, 12:29 AM   #3
bigjae1976
bigjae1976's Avatar
Old 12-28-2011, 10:38 AM   #4
bigjae1976
bigjae1976's Avatar
bump
Old 01-09-2012, 02:57 PM   #5
bigjae1976
bigjae1976's Avatar
Tool is rented out...
Old 02-20-2012, 09:24 PM   #6
bigjae1976
bigjae1976's Avatar
Received the tool back...available for rent.
FYI...I am not very strict about the late fees. The only scenario where I will charge a late fee is if I have someone waiting on the tool. I charged the last renter 1.5 weeks or $30 since I lost out on 2 potential renters...I think that's fair.
Old 02-24-2012, 06:23 PM   #7
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
I might need to borrow or rent this soon!
BimmerBrakes is offline   Reply With Quote
Old 02-25-2012, 12:32 AM   #8
bigjae1976
bigjae1976's Avatar
Let me know! I just sent it out today to someone.
Old 02-27-2012, 08:47 PM   #9
BimmerBrakes
The Brake Newbie!
It will be in a couple of weeks
Old 03-23-2012, 08:06 PM   #10
bigjae1976
bigjae1976's Avatar
About to send to Trippinbimmer!
Old 06-15-2012, 01:52 AM   #11
monkeyhead
My Ride: 2003 330i
hey bigjae, i'm intersted in renting this tool, but before i do, i read this guys experience with the tool and his disappointment, do u know what he is referring to?
"I just did the left side rear bearing on my 540i. I had done the right side about 50k miles ago; it was very noisy. I had lived with the left side noise for about 20k miles because it wasn't too bad; recently, I noticed a wobble to the wheel and decided the noise wasn't the biggest concern anymore. Anyways, just some anecdotes regarding lifetime of the bearings and failure modes. Another FYI: I did the bearing, the ball joint (aka swing arm bushing), the upper rear control arm and the sway bar links and the job took about 16 hours. 80% of that time was dealing with the inner bearing race, the ball joint extraction, and pulling the axle back through the hub. I work pretty slowly, so take that for what it is worth.
After doing the right side with no more than a dead-blow hammer and a cold chisel, I decided I wasn't going to go through that again and sprang for the Sir Tools B90 tool. This tool was useful for pushing the axle out of the hub (works in either the save-the-bearing mode or the destroy-the-bearing mode) and for pressing the hub back in to the new bearing. I was disappointed to learn after I got the tool that it did not include anything to pull the axle back through hub after the bearing/hub is mounted to the carrier. This was by far the hardest part of both times I did the rear bearings. I know that BMW specifies a special tool (of course!) that looks like it must thread onto the end of the axle. I resorted to using the dead-blow hammer to pound the hub onto the driveshaft; this required a ridiculous amount of force and repetition and I feel like I must've done some damage to the diff, CV joints, and/or the bearing. After at least 20 forceful swings, the axle emerged from the hub enough for the axle nut to catch; from there it was easy to let the nut do the work of pulling the shaft through the rest of the way. Has anyone had a similar experience with the axle/hub, and if so, how did you get them together?"
see one, do one, teach one
monkeyhead is offline   Reply With Quote
Old 06-15-2012, 11:18 AM   #12
bigjae1976
bigjae1976's Avatar
I didn't have an issue. You need to have the car in neutral so the shaft will spin so you can line up the splines.
Old 06-16-2012, 10:12 AM   #13
TrippinBimmer
My Ride: Just Fast!
x2 and make sure the splines are clean. Can add alittle lube if u want it to slid in like butter That guy was just a newbie...
-Trip
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 06-16-2012, 10:32 AM   #14
Snik
Snik's Avatar
My Ride: IR M3 Vert.
in... might be renting this bad boy later this summer.
Do you ride a sportbike?
Old 06-17-2012, 07:40 PM   #15
monkeyhead
My Ride: 2003 330i
ok cool,,,June 27 is this available for rent?
Old 06-17-2012, 07:42 PM   #16
bigjae1976
bigjae1976's Avatar
It just went out so it's very possible it will be available by then.
Old 06-19-2012, 05:15 PM   #17
bigjae1976
bigjae1976's Avatar
Rented out then it goes to Monkeyhead. Should be available again sometime in late July.
Old 07-01-2012, 03:10 PM   #18
bigjae1976
bigjae1976's Avatar
Monkeyhead has it. It should be available by the end of July.
Old 07-03-2012, 03:00 PM   #19
bigjae1976
bigjae1976's Avatar
The tool will be available again within one week.
Old 07-10-2012, 10:17 AM   #20
bigjae1976
bigjae1976's Avatar
Available
