Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc. |
#41 |
Available for rent
#42 |
Enroute back to me...should be available shortly!
#43 |
bump
#44 |
Available...
#45 |
Got pictures?
#46 |
Wrench and socket not included.
#47 |
bump
#48 |
up
#49 |
This should be PnP for rear wheel bearing swap on the 46M?
E46M3Topaz on Cinnamon
not very stock.. ![]() |
#50 |
Yes.
#51 |
Thank you bigjae. We will be in contact later this spring.
#52 |
Ok!
#53 |
bump
#54 |
ttt
#55 |
Bump
#56 |
bump...someone has bad wheel bearings!
#57 |
wow the Oreilly up the road from does free loaner tools. Just give em a deposit and you get it back when you return the tool.
#58 | |
Keep in mind, while these tools are good with hand tools, using an impact gun will make R&R a breeze. You could pull off the entire trailing arm...its not terribly difficult. I think $55 to make the job much easier is a great deal. |
#59 | |
It truly is bigjae. I learned from working on this chassis that the proper tool is worth it for several jobs: RTAB, Ball joints, wheel bearing, TDC pin, and cam timing. Other mickey-mouse efforts work for the above jobs - but are not worth it. When the snow is gone for the year - we will be in touch! Mike p.s. If you ever need the Koch ball-join tool bigjae - I have the Koch "Master-Trailing Arm bushing kit E36/E46." If your new 46M has over 50k, I bet the lower BJ's on the rear trailing arm are threaded on the inside. Firms up the rear on corner exit with fresh BJ's. http://www.kochtools.com/index.php?p=product&id=174
not very stock.. ![]() Last edited by MisterM; 03-13-2013 at 12:08 PM. Reason: added link |
#60 |
No problem! Yeah...this is one of those jobs where you really want to get it right the first time.
