Old 10-30-2011, 11:50 PM   #1
diablorojo
My Ride: Supercharged 330i
SC 330 compound boost build Twinscrew/T72 turbo
I am currently rebuilding my engine for a compound boost set up. I made this decision after damaging my supercharger by running meth and nitrous!!!!! Huge no-no. The water froze and pretty much acted like stones in the supercharger, deep scratches and funny noises followed.
So in my quest for more go fast I decided to rebuild something insane, so here we go...
Whats done/what I have...
M30B54 ported head
Cosmetic mls head gasket (lower compression)
ARP studs
Custom camshaft (260/268)
ESS twinscrew supercharger 1.6
Custom 88mm throttle body
Custom intake
Okada plasma lift (on back order)
Ceramic header and heat wrapped
Custom pulley
800cc Bosch injectors
255 lph fuel pump
Fuel regulator
Secondary air delete
Nx express nitrous (75hp)
Nx express methanol kit stage 2
ZHP 6 speed conversion
4.10 LSD
ZHP short shifter
And lots of other parts not directly related, gauges, etc..
I am ordering a T72 turbo for a rear mount set up. I will be running 8 psi on th SC and 9 psi on the turbo. My concern is the tuning and any equipment that would make my life easier.
PLEASE UNDERSTAND...I am looking for positive feed back of known issues and experiences, or known related issues of the build. I say that to say I'm not interested in how stupid the build is....thanks. All comments are appreciated.
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 10-31-2011, 12:33 AM   #2
lab rat
My Ride: '02 330iT
Don't quite see the benefit of the turbo with the SC setup, why not just turn the boost up on the SC?
Because sleeper
Old 10-31-2011, 12:41 AM   #3
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Looking forward to results
Old 10-31-2011, 01:16 AM   #4
02PRUV
My Ride: E46 M3 Turbo
Haven't tried compound charging on anything before but compound turbocharging is very interesting and I want to try it on something one day.
Interested to see the results as well
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 10-31-2011, 01:20 AM   #5
Bdave
My Ride: M3 HPF Stage 3
I think your injectors are too small. 1000 or even 1200cc.
Fuel pump is too small to supply all that FI too.need BIGGER!
You should try and find an old fuel rail kicking around...one from a Stage THREE HPF kit. You got AIR. Now you need FUEL....and lots of it by the look.
Bdave is offline   Reply With Quote
Old 10-31-2011, 07:34 AM   #6
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Unless you plan on running a direct port setup right behind the fuel injector bungs on the port runner, I wouldn't run nitrous.
How do you plan to tune this monster?
Old 10-31-2011, 07:35 AM   #7
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Old 10-31-2011, 08:31 AM   #8
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
why rear-mount?
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 10-31-2011, 08:33 AM   #9
bluejeansonfire
ninja editor
My Ride: m5xual
do you know how much boost a 8psi pulley and 9psi wastegate spring yield?
Old 10-31-2011, 08:42 AM   #10
diablorojo
I can't turn up boost on the turbo because of the compound effect, 8psi on SC and 9psi on turbo gives the car 23psi. Thats why im using a large turbo 9psi on a 700+ turbo should do well. I want to get it running right. Once I do I will look at lowering compression lower and turning up boost.
I'm going rear mount on the turbo to keep the heat down under the hood and rear mount allows turbo boost without an intercooler. Less piping, and general ease. It also allows for a simple setup in the event this doesn't work.
Fuel....I considered larger but I figured running 32lb injectors on 13psi of boost (currently) so doubling the boost would be 65lbs, but I actually am going to see if I can squeeze enough room in them to go e85. I'll know after the first tune...
Old 10-31-2011, 08:50 AM   #11
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
Wow in for results. Should be a MONSTER.
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 10-31-2011, 08:51 AM   #12
bluejeansonfire
ninja editor
My Ride: m5xual
given that the inlet of the supercharger will be seeing 9psi, and will then be ratcheting that well past 20psi... do you think that narrow belt will hold to redline?
you intend to run 23+psi on a hg spacer?
Old 10-31-2011, 09:05 AM   #13
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
How is this being tuned?
This should be the first item looked at in any custom build on an E46.
Old 10-31-2011, 09:44 AM   #14
BDUB328I
My Ride: bmw 328i S54 sedan (
this sound like a very interesting setup, im excited to see some results
BDUB328I is offline   Reply With Quote
Old 10-31-2011, 10:13 AM   #15
B33MER
My Ride: 330i SMG M-Sport
Can someone explain to me what is compound boost? Sorry am still a noob in FI
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
B33MER is offline   Reply With Quote
Old 10-31-2011, 10:29 AM   #16
Estoril-E46
My Ride: M3
Gut tells me you are going to see more boost then that. Just because it initially compresses to that, doesn't mean your engine is going to suck it in that fast. It will probably build up the way it does for a PD blower.
The quick but slow car:
www.Precision-Sport.com
Estoril-E46 is offline   Reply With Quote
Old 10-31-2011, 11:03 AM   #17
lab rat
My Ride: '02 330iT
All great inventors were considered fools at some point.
I just see this being too complicated. How much power are you trying to make? Stock internals with head spacer will likely stop you well before 400whp.
Because sleeper
Old 10-31-2011, 11:16 AM   #18
E46_330i_Stud
Technique Tunings kit with a thicker head gasket and studs puts down 400whp on like 11psi. Might be a little more boost. OP just needs to be careful not to lift the head enough to strip the head studs straight out of the aluminum block. But I agree, the internals will need work for sure.
Old 10-31-2011, 11:46 AM   #19
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
http://www.e90post.com/forums/showpo...18&postcount=1
like dennis' car.
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
Old 10-31-2011, 11:49 AM   #20
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
Originally Posted by MachRc View Post
I remember reading that his car is not functional at all - just for show.
AMG-ETR is offline   Reply With Quote
