Old 05-22-2012, 10:06 PM   #201
diablorojo
My Ride: Supercharged 330i
I believ so, not engine codes, had to rewire for hall to mke it start originally, but yea, pretty sure. Also, I can't pull up my save files, they have a lock icon on them...what's this...?
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 05-22-2012, 10:08 PM   #202
diablorojo
Oh and the car starts with the harness adapted. I was tiold the car wouldn't start and run if it was installed wrong....
Old 06-03-2012, 10:35 AM   #203
diablorojo
Update....
Got the car running with issues...
1. The RPM function on the FIC is no longer working
2. ECU code p0102 low MAF voltage. I hoping it's because the tach function isn't jumping the signal around properly.
3. Car heats up quickly driving for 3 min or so (high rpm's). I'm gonna go 2 stages colder on the spark plugs today.
The AF is better tho not great... Between 12 and 14 through the rpm band. Will fine tune once the issues above are resolved.
The drive....the car is strong, feels more like a turbo car, boost comes on at once I'm sure the tuning plays a part, but I also think it's the cam, it's for mid to high rpm range. I haven't driven it hard or revved past 4k.
The guy that did the head work said I would read less boost with the port work. I went from 11 psi to 5psi I guess it moves more air and lowers manifold pressure...this is great for the addition to the turbo. To simplify...my 11 psi pulley is showing 5 psi on my boost gauge. The pressure is lowered because of the TB and head (I'm guessing and researching)
Hmmm...I'll also hook my meth kit back up today....not gotta find meth on Sunday
I have also need a m3 oil filter housing, I'll pick one up this week. The oil cooler should help as well...
I really wanted to stay away from it but it's looking like I may need it...
Old 06-05-2012, 04:09 AM   #204
diablorojo
Update3
So...where do I start
that car is a monster!!!!!!
I have 2010 Jaguar XFR so I'm not easily impressed, but I am speechless over what this car has turned into. I only gave it about 50% throttle from 2500 thru 4000 rpm's and the car scares me. It was so crazy that I pulled over to make sure the meth didn't activate....lol. I just stood there looking at it. It was so bad that my neighbor came out and asked me if I was ok....
The power comes on the instant I give it gas. I pedaled into boost, 5 psi now, but the car pulled very hard and had no signs of stoping. I let off because I am having cooling issues. PLEASE HELP.
The car idles fine, runs fine until I began to drive. About a mile in the temp gauges begans to move to the red. I changed the thermostat today but still the same issue. I have no clue what it could be. I have no visible signs of a defect anywhere.
Also, the car throws no codes. Once the cooling is addressed, hopefully the next day or 2, then I will be adding the turbo (next week). Honestly, I'm hesitant because the car is so violent already and I am not sensing a loss of power in the high rpm's like before. But, with the head work making the manifold see my 11psi pulley as 5 psi, I can't resist adding 9-10 psi of turbo. I would still only be at 17 psi.
Recap:
Ported head
Pretty extreme custom cams mid to high rpm's
89mm tb
400 lph fuel pump
MUCH MORE AIR AND ONLY 5psi on an 11psi pulley! Insane!!!!
I have some fine tuning to do, but the boost kicks like a turbo (weird)
And I can't complain about the current set up. I can tell already that this car is going to break some records
Now to figur this cooling thing
Btw.....I have to thank Ritos for all his support with the FIC. It has been a struggle, but his imput cut a lot of the guess work....thanks!!!!
Old 06-05-2012, 04:21 AM   #205
paraklas
My Ride: ESS TS2 320ci
Something simple as in need of a good bleeding?
paraklas is online now   Reply With Quote
Old 06-05-2012, 08:22 AM   #206
InDiGlOM3
My Ride: HPF M3 stg 2.5
Air in your coolant system
Sent from my PG86100 using Bimmer App
Old 06-05-2012, 09:44 AM   #207
diablorojo
How do I get it out....
Old 06-05-2012, 10:17 AM   #208
diablorojo
Ignition position 2
Heater high
4000 rpm's 20 secs
Old 06-05-2012, 11:00 AM   #209
lakedude90
My Ride: 03' 325i
open the bleed screw turn the AC/HEAT all the way up and turn the key to postion 2 so the air comes on and start filling with coolant. once theres no air and just liquid coming out the screw you should be good.
Cant wait to see a vid man and see what numbers your putting down.
One thing I notcied you havent mentioned is a clutch. Is the stock clutch still holding? Im sure your gonna have to upgrade at some point. What are you gonna get?
_____________
Jacob
03' 325i
lakedude90 is offline   Reply With Quote
Old 06-05-2012, 12:09 PM   #210
diablorojo
I definately will bleed the system but i found the issue. The puller fan ia not activating. The plugs look ok. I let the temps get to 240 ish and it didnt activate.
I also found the issue with my fic. O had wired the car maf singnal to the fic crank signal. Oddly enough, it served its purpose by send a weak singal to the maf thus allowing more boost. Havent tested it, figured it should solve the problem with the. Tach because it was the last grimlin in the fic.
Im trying to post a video, the sound on the video doesnt even come close to capturing the sound of the car.
The current issue it the fan. If i need another one...hoping i dont so pls help me trouble shoot it....i will get something stronger.
As for the clutch, its the stock clutch that came with the trans when i did the swap. Ill address it once i see the dyno numbers of the final set up. I havent launched the car or driven it very hard yet.
Sent from my DROIDX using Bimmer App
Old 06-05-2012, 12:39 PM   #211
ritos530i
My Ride: 2004 E60 530i 6speed
Send a message via MSN to ritos530i Send a message via Yahoo to ritos530i
Congrats, I would bleed her as others have said, My brother an law bought a 740i for $700 because it kept over heating and no one could figured it out. He change the water pump, radiator, new hoses etc... and it kept over heating after running for 5 or so minutes. I just happen to go back home to visit and after five minutes on the internet to figure out how to bleed the car, trip to Autozone $12 bucks and she drives like a champ now. I want to say because of the air in the system it's not allowing the sensor to get accurate reading causing the temps to go up rapidly. Also not allowing the fan to come on when it's suppose to come on.
This is what I would do first and it want cost you anything but five minutes or so and a little antifreeze.
530i E60 Custom Turbo/Nitrous (PSI_unknown)
ritos530i is offline   Reply With Quote
Old 06-05-2012, 01:04 PM   #212
diablorojo
Ritos....what's the ar on your turbo and what rpm does it begin to boost....I'm curious because of your rear mount. I went high because I wanted top end but I'm trying to get a good gauge of where boost would Begin. I have a .84 ar. I was shooting for boost around 4k. 3800 would be optimal....
I'm thinking if the sc boost at 11psi reads low, then the turbo will probably do the same. If this is the case, I can go pretty strong on the turbo. 11 = 5 psi on sc. If 14 = 8 psi on turbo, then per the compound boost calculation, the manifold will only see 15psi - 16psi.
I do understand the flow calculation is different on a turbo, but the ending amount of air is the same.
Old 06-05-2012, 01:07 PM   #213
Hrvat
My Ride: 02 Imola Red M3
Pics?
PM ME FOR FREE SAMPLES
Originally Posted by roronoah View Post
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
Old 06-05-2012, 01:23 PM   #214
diablorojo
Video
not the best video, just figured how to upload, this was the test video.
Old 06-05-2012, 01:37 PM   #215
ritos530i
My turbo is a T4 .68 AR boost starts around 3000-3500rpms Full boost by 3800-4000rpms it's rather quick because of the 3.91s so it feels more instant
Old 06-05-2012, 08:22 PM   #216
diablorojo
Im puting the engine bay back together after painting it gold...
Old 06-05-2012, 09:11 PM   #217
diablorojo
I began bleeding the coolant line. I turned ignition to position 2. Put the heat on full blast, loosen the screw, it began to hiss.....but then it wouldn't stop. Stood there for 2 minutes letting air out and then tightened it back. How long should it take?
Old 06-05-2012, 09:28 PM   #218
ritos530i
you should remove the screw until it stopped spitting out into a nice flow then I put it back in.
Old 06-05-2012, 09:33 PM   #219
ritos530i
see the last instructions.
http://tis.spaghetticoder.org/s/view.pl?1/08/05/40
Old 06-06-2012, 03:08 AM   #220
paraklas
Draining & Adding Coolant
Venting Cooling System
