Old 11-01-2011, 11:57 AM   #61
MalibuMafiaV
My Ride: E60 M5 & Stg3 AudiS4
Originally Posted by diablorojo View Post
I will post pics shortly, I have been operating off my ipad2 and I can't seem to upload pics to this site with it. Ill have to do it from my pc...
PC win.
TheMalibuMafia.com
Instagram
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i - ST GT35R
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
MalibuMafiaV is offline   Reply With Quote
Old 11-01-2011, 12:44 PM   #62
NIVO
My Ride: 2004 330Ci ZHP
Send a message via AIM to NIVO
www.E46Turbo330Ci.com
WARNING: This modification is known to the State of California to cause cancer and birth defects or other reproductive harm due to the extreme G forces once turbo kicks in. ~ Nivo
The rest of my signature is reserved for pointless modification bits like: Halos | window Tint | carbon fiber roundels | short shifter
NIVO is offline   Reply With Quote
Old 11-01-2011, 12:48 PM   #63
Au2bahn
My Ride: 05 330i ZHP,09 HCHII
OP's project will be a monster. Definitely do E85 if you have it available in your area, running that much boost. It all comes down to the tune, but how complicated with that be and the R&D costs?
Jon Estrella
ESS TS2 - VMR V710 19" wheels - KW Coilovers - 3.46 Diff - Macht Schnell 5mm Rear Spacers - BMW Performance BBK w/ floating rotors -
BMW Performance Strut Brace - BMW Performance Air Intake - BMW Performance SSK/DSSR - Hawk HPS Brake Pads - SS Brake Lines -
OEM M3 RTAB w/ Vorshlag Limiters - Meyle HD FCAB - TMS Sway Bars w/ adjustable links - AEM Digital Boost Gauge -
Stewart w/p - 6K HID Fogs - Swain Coated Magnaflow headers
Au2bahn is offline   Reply With Quote
Old 11-01-2011, 01:59 PM   #64
diablorojo
My Ride: Supercharged 330i
E85 is the plan. Won't know if I need injectors larger than I have (800cc) until the tune @13psi SC only. I will get to see the duty cycle and adjust if I need to. I've been running 11psi on 32lb injectors (330cc est). E85 requires a third more fuel and I pretty much tripled the size of my current set up. Hopefully it works, if not I will address it.
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 11-01-2011, 02:04 PM   #65
diablorojo
To clarify, if u have 1000cc injectors running at 80%, them u can achieve the same results running 800cc at 100% (tho most people wont do over 80% duty cycle, depends on the quality of your injectors and comfort level). Most quality injectors can do 110% but that's just FYI...
Old 11-01-2011, 02:15 PM   #66
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Could you explain this to those of us that don't understand how that's possible?
Old 11-01-2011, 02:29 PM   #67
diablorojo
It's about reliability. So some manufactures will make a let's say 600cc injector. They will then advertise or sell them as say 550cc injectors. Kinda like automobile companies do on there engines and performance specs.
Old 11-01-2011, 02:30 PM   #68
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
I think he's referring to like when HPF posted the video and thread about the ID2000 injectors (I think that's the name of them) performing comfortably at like 2200cc's or something. I assume he's stating that quality injectors are underrated most times, just a guess.
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 11-01-2011, 02:37 PM   #69
diablorojo
@ 330i_stud..thanks..for the example..
Old 11-01-2011, 03:12 PM   #70
ritos530i
My Ride: 2004 E60 530i 6speed
Send a message via MSN to ritos530i Send a message via Yahoo to ritos530i
Since you already have tuning sorted out and have an idea what setup you are going to run and how much power you expect to make.
Consult your tuner and ask him what you will need and if he says this will work for him go forward with it. Don't second guess your plans once you have a well thought out one. I still say you'll need larger injectors if you plan to run E85. You should be able to sell current injectors and use the money to go towards larger injectors.
I'm still waiting on the photos!
530i E60 Custom Turbo/Nitrous (PSI_unknown)
ritos530i is offline   Reply With Quote
Old 11-01-2011, 04:50 PM   #71
SweTurbo
Big Pimpin'
My Ride: 323i -98
About injectors you're not running them at 110% DC, just 110% output.
Crank up the voltage on the injectors to 16V and you'll have 120% output, run them at 100% for too long and they'll burn out.
Tuning this will be REALLY tricky on a stock DME, maby not at idle/full throttle but partiall trottle will be crazy as a slight increase in AFR will give the turbo some more spool/drop spool which in turn gives the sc another boost ref.. while still at same throttle.
Standalone with 4D or 5D fuelmaps + boost sensor between turbo and S/C is how i would have done it.
Old 11-01-2011, 05:03 PM   #72
diablorojo
Pir4t.... the hope behind with that is a large turbo with large AR. I'm trying to delay the turbo effect until after 3k (full boost) in hopes of reducing that particular challenge. The thought or aim is to hit turbo only at wide open throttle (very tricky I know).
Point being if I'm just cruising around town I can keep shift points low to keep turbo inactive (or low activity anyway) Problem with this theory is that 4.10 gear and the highway...
Fuel pressure regulator would help I imagine as long as it plays well with the ECU....
Old 11-01-2011, 05:28 PM   #73
SweTurbo
Big Pimpin'
My Ride: 323i -98
Alright sounds more feasable
I believe i saw an electric wastegate on some project here in sweden , im sure that could be fitted to your application
(have it open under say 4000RPM and then close and open again when manifold sees X pressure)
Old 11-02-2011, 10:15 PM   #74
secono330ci
My Ride: 04' 330ci/15' A3 TDI
This thread's got more stories than Walt Disney.
Good luck with the project OP
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 11-02-2011, 11:02 PM   #75
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
You made me laugh !
OP, good luck.
You'll need it !
SUMMIT POINT WV 1:24:229 SCCA
Old 02-16-2012, 06:49 PM   #76
diablorojo
Update...the engine is reassembled with injectors, cams, porting, larger throttle body, lower compression,etc... Left the same pulley (11 psi) on to get a good before and after. The car started right up though it idled horribly, but still sounded very aggressive. Had the car towed to Topspeed he in GA and is being tuned as we speak. (they had to customize an intake due to the larger TB and custom bungs for the nitrous).
PS...walt Disney was a great man with many stories, this is just one of mine jk
Once tuned I will start the final phase (depending on the HP gain and engine strength)
I will post dyne numbers once I pick the car up.
Old 02-16-2012, 07:08 PM   #77
ritos530i
Waiting patiently
Old 02-16-2012, 07:31 PM   #78
diablorojo
Figured out how to upload from the phone since ipad doesn't upload...
Sent from my DROIDX using Bimmer
Old 02-16-2012, 07:36 PM   #79
diablorojo
Old 02-16-2012, 07:41 PM   #80
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Like the Texas Tag
BimmerBrakes is offline   Reply With Quote
