Old 02-16-2012, 11:01 PM   #81
02black330ci
My Ride: spaceship
Originally Posted by diablorojo View Post
Figured out how to upload from the phone since ipad doesn't upload...
Sent from my DROIDX using Bimmer
She is SEXXY and damn clean!
02black330ci is offline   Reply With Quote
Old 02-16-2012, 11:42 PM   #82
diablorojo
My Ride: Supercharged 330i
Thanks...
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 02-16-2012, 11:45 PM   #83
diablorojo
Here is the gauge cluster...ill be switching out the gauges latter. These are the multicolor ones
Old 02-17-2012, 12:03 AM   #84
diablorojo
Pic of engine disassembled.
Pic of stock TB vs new TB from about 54mm to 89 mm.
Pic of cosmetic head gasket.
ID:	437449   Click image for larger version
ID:	437450   Click image for larger version
Old 02-17-2012, 03:31 PM   #85
SweTurbo
Big Pimpin'
My Ride: 323i -98
How did you lower the CR without removing the pistons ?
Did you remove material in the combustion chamber/thicker HG ?
Old 02-17-2012, 03:44 PM   #86
diablorojo
Cosmetic offers thicker head gaskets which lower the compression...they have a range depending on how low u want to go...
Old 02-17-2012, 03:57 PM   #87
SweTurbo
Big Pimpin'
My Ride: 323i -98
I know about this but i wouldnt want to increase the thickness of a MLS too much either.(the increased thickness is mostly offered to make up for having the head/block decked)
You keep saying Cosmetic ? I was assuming you were running thesame as me (Cometic) i have seen "cosmetic" HG's but not for bmw , thats why i ask
Old 02-17-2012, 05:40 PM   #88
ZeroSum
My Ride: 05 325
This sounds like a cool project but I am confused with the final specs of this build, do you still plan on running a turbo or just the twin screw?
How much boost are you hoping for?
ZeroSum is offline   Reply With Quote
Old 02-17-2012, 07:47 PM   #89
diablorojo
Yes it's cometic but iPad auto corrects to cosmetic. The plan is to continue to the turbo but it has to be tuned each step to ensure each piece works as it should. It would be expensive and suck pretty bad to put all these parts on and try and trouble shoot. It depends on HP because I would like to see 600+hp. Also it's being tuned at this stage for e85 so that I can raise the boost via turbo (compounded) approx 21psi (8 on SC 9 on Turbo). But I also have nitrous 75 shot. So really, I'm working through my options but checking the boxes one stage at a time....
Old 02-17-2012, 09:50 PM   #90
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
The car started right up though it idled horribly, but still sounded very aggressive.
You've got a cam timing issue; who ever installed your cams most likely didn't use an alignment tool on the VANOS spline when transfered from the OEM cams to the aftermarket cams.
Old 02-17-2012, 10:09 PM   #91
diablorojo
Actually, it was a fuel issue. 3 times more fuel than the computer was programmed for. And a very aggressive cam
Old 02-18-2012, 12:18 AM   #92
jacobs323i
My Ride: blown 323i
you better consider rods and pistons your stock stuff will never handle that
jacobs323i is offline   Reply With Quote
Old 02-18-2012, 12:30 AM   #93
diablorojo
Jacobs323i....we will soon see....I have found no information on a known breaking point for 330 rods or pistons, do you have any, or a link would be helpful...
Old 02-18-2012, 01:37 PM   #94
SweTurbo
Big Pimpin'
My Ride: 323i -98
Here's a pic of mine at 10psi with a small oil-leak:
I see 600hp guys use our conrods in M50 machines so they should hold for the power.
As long as you dont have any knock you shouldnt experience what my pistons did.
Old 02-18-2012, 04:00 PM   #95
diablorojo
Pir4t...unfortunate for your pistons, I was running completely stock with 11psi and a75 shot on premium with no issuses. Perhaps the leak and smaller displacement played a role? Idk...i only know my engine so I can't speculate. mine have been fine so far...Hopefully we will see them hold well.
Old 02-18-2012, 08:38 PM   #96
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
It wouldn't hurt to check if this tool was used to transfer the VANOS splines:
How aggressive is the cam? I've been around M54B25 race cars with 300 degrees of duration, and they idled fine. Surged a bit under 4k RPM at part throttle....but idle was never an issue.
Old 02-18-2012, 09:59 PM   #97
diablorojo
260/268 degree....but car was tuned for 32lb injectors....I dropped in 72lb injectors as well as adding lots of air (30% larger TB, ported head, etc) fuel floods quickly...
Old 02-18-2012, 10:00 PM   #98
diablorojo
I will check tho...
Old 02-18-2012, 10:44 PM   #99
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
FYI, those cams are mild. When measured at 0.050" lift, they are actually in the 220-230 degree range.
The TB size and cylinder head porting won't matter at idle. The air is going through the IACV.
The parameter you really need to look at when changing injectors is "Tau".
Old 03-16-2012, 08:23 PM   #100
Jesse M
My Ride: 05' ZHP
any updates?
Jesse M is offline   Reply With Quote
