Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Old 10-31-2011, 07:13 AM   #1
m3racer007
My Ride: 330i 5spd
yellow "Brake" light on and traction control light on
Hey guys, I have a e46 325i and my yellow "brake" light is on along with my traction control light is on. These came on both at the same time... What is the most likely cause of this?
I heard it could be a speed sensor?
Control Unit?
alignment issue?
This seems like it is a very common problem... (good excuse to have traction control off 24/7 tho ) hahaha Just kidding...
I do need an alignment because I Hit a big pot hole like 2 days ago at night... could that be the likely culprit?
Thanks for all your advice
m3racer007 is offline   Reply With Quote
Old 10-31-2011, 08:13 AM   #2
CWest22
My Ride: 2001 325Ci
i have the same thing going on, could a bad control arm bushing do this?
CWest22 is offline   Reply With Quote
Old 10-31-2011, 09:54 AM   #3
m3racer007
My Ride: 330i 5spd
Mine actually just went off by itself... I also heard low voltage comming from battery could be the problem, and I actually replaced the front A pillars, disconected the battery so the airbags don't blow up in my face and I never tightened it back on properly... I tightened them on before... and I was good to go... I hope its not a coincidence and it comes on again.
I have no idea about the control arm bushings?
Old 10-31-2011, 10:15 AM   #4
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
I got the same two lights a couple of weeks ago. Car was sitting for 3 days and gave me those two lights after startup in fairly cold weather. Stayed on the entire way to work (55 miles), but went off the next time I started the car.
As far as I know, my battery has never been changed. I suspect it is going to need replacement soon.
Old 10-31-2011, 10:32 AM   #5
m3racer007
My Ride: 330i 5spd
so you too probably had the low voltage issue...
Old 11-01-2011, 12:42 PM   #6
LivesNearCostco
My Ride: 2003 ZHP 6MT
The "usual suspects" for these lights coming are
1) Wheel speed sensor dirty or failed (cheap part, easy labor)
2) Steering angle sensor needs recalibration or replacement (cheap part, moderately expensive labor)
3) DSC module failed (expensive part?)
4) Other CAN bus or electrical problem (possibly low voltage?)
There has been quite a bit of debate as to which of these are the most likely cause and the best troubleshooting approach. The two most common recommendations seem to be
A) Get a dealer or good indie shop to read the ABS/DSC codes, or...
B) Remove, clean and reinstall all four wheel speed sensors. If that doesn't work, go back to "A"
Lowering my car's resale value one track day at a time...
Last edited by LivesNearCostco; 11-01-2011 at 12:49 PM. Reason: added comment on rough repair costs
LivesNearCostco is offline   Reply With Quote
Old 11-02-2011, 10:43 PM   #7
95lsteg
My Ride: 2000 328i
I'm having the same probs, plus the central locking acting weird when using the remote control....
95lsteg is offline   Reply With Quote
Old 11-03-2011, 07:51 AM   #8
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Your alternator could be going south.
Old 11-04-2011, 12:30 PM   #9
silverbmwfirst
My Ride: 2002 AA HKS 325ci
I had this once when I upgraded my brakes. I didn't tighten up my SS brake line all the way and lost some fluid. Verify your brake fluid is not low... Just an idea
silverbmwfirst is offline   Reply With Quote
Old 11-04-2011, 12:32 PM   #10
m3racer007
My Ride: 330i 5spd
god damn light came on again.
Old 11-05-2011, 04:34 PM   #11
cbritton
My Ride: 2000 323i
I used to get this all the time when it was cold, and the culprit was low voltage. I took out the battery, topped it off with the distilled water, and I was good to go.
cbritton is offline   Reply With Quote
Old 09-09-2014, 10:32 AM   #12
manoftheway
My Ride: 2002 BMW 325CI
Same Problem.
Okay Guys,
I have had this same problem for about 2 months now. I've been researching and have found that it could be caused by any one of a number of sensors/problems. The lights turned on during a very wet and rainy week here in Wyoming and have not turned off once since that week. Do you guys know if there is a more common problem that happens because of water getting into specific sensors?
I have also noticed unusual wear on my passenger side rear tire as it is wearing more on the inside of the tire. Could this be causing the problem? I have inspected all of the bushings on the suspension and the all seem to be fine. is there anything else I should check??
The Bimmer has 279,000 on it so I am more than willing to do whatever maintenance is necessary.
Any help is greatly appreciated.
manoftheway is offline   Reply With Quote
Old 05-30-2015, 01:21 PM   #13
brunobliss
Originally Posted by manoftheway View Post
Okay Guys,
i noticed this too, but my tire is worn on the driver side, will be replacing my tires this week. What did you do to solve the problem ?
brunobliss is offline   Reply With Quote
Old 06-06-2015, 10:24 PM   #14
German85
My Ride: 05 325Ci
I've been having this issue on and off almost since I bought my car. I changed the battery which tested at last third of its life. That fixed some issues with sensors, but not the yellow traction control light. I then cleaned the speed sensors. The rears were the only ones that looked dirty and didn't fix the light. My tires are wearing down so i have a feeling its has to do with alignment. I don't think it could be my steering angle sensor, but im wondering what the steering angle sensor measures.
something interesting about it is that it would go off when I would drive the car hard enough to slide the back end around.
German85 is offline   Reply With Quote
Old 06-06-2015, 11:48 PM   #15
sillieidiot
My Ride: '06 AW 330ci
it could be your brake fluid level or you have air in the abs/dsc or the lines somewhere. that's what happened to me. i had like an air bubble so it kept going on/off randomly until i went ahead and just flushed the whole system then it went away.
Old 06-07-2015, 09:06 PM   #16
German85
My Ride: 05 325Ci
I looked at the brake reservoir and it does look alittle low. I also think the fluid looks alittle brown. I will pick up some fluid tomorrow and look at changing and bleeding the brakes next day I have off. well see if it keeps the light off.
Old 06-08-2015, 01:07 AM   #17
brunobliss
I'll do this myself too as I started constantly getting the lights back on. This coincided with the time I have to change the break pads
Sent from my Nexus 5 using Tapatalk
Old 06-19-2015, 10:21 AM   #18
shred325i
My Ride: 2001 325i
I have the same issue and have already changed out the sterring angle sensor. Now the shop is telling me that it is a speed sensor that is located under the drivers seat....
Will let all know when it is complete and see if this finally fixed this issue
shred325i is offline   Reply With Quote
Old 06-19-2015, 11:14 AM   #19
German85
My Ride: 05 325Ci
I meant to update on the brake fluid check. i changed out the fluid out. It was a dark brown. I havent had the light back on since.
Old 06-19-2015, 11:20 AM   #20
brunobliss
German85 i will be doing this as well this weekend! Couple of questions though, is one dot4 bottle.enough? Did you experience sort of grinding before changing the fluid while driving in slow speeds?
Enviado de meu Nexus 5 usando Tapatalk
