Old 10-31-2011, 07:31 PM   #1
brodaiga
My Ride: 330ci
tire leaking air
aftermarket 19s and 235/45/19 general exclaim tires. one of the tires leaks air and has to be refilled every week. Could this be a valve stem issue? I've had this setup for a while and this just recently started. I don't have the tools at the moment to lift the car to inspect the rim, but I cannot feel any bends in the rims when driving and it is the front driver side tire
brodaiga is offline   Reply With Quote
Old 10-31-2011, 07:33 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Take the wheel off and use water/soap to see where it's leaking from.
Old 10-31-2011, 09:34 PM   #3
brodaiga
My Ride: 330ci
how?
Old 10-31-2011, 10:44 PM   #4
Top_Bunk
My Ride: Ram-Air Nylon
+1 to soapy water. A spray bottle works well.
Top_Bunk is offline   Reply With Quote
Old 10-31-2011, 10:53 PM   #5
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Originally Posted by brodaiga View Post
how?
dowse it with the soapy water solution, either brush it on or spray it on. Where ever it's leaking air from will start to form bubbles.
/// MODS
Old 10-31-2011, 11:20 PM   #6
Vic328CSi
My Ride: depends on the mood
I had same issue about 6yrs ago, kept refilling every week,eventually weakend sidewall enough and it exploded on the freeway almost killed me. Take it to tire place immediately!!!
If checking for leaks also check schreader valve stem often overlooked, can go bad.
e46 328Ci 9psi SC
Vic328CSi is offline   Reply With Quote
Old 10-31-2011, 11:52 PM   #7
brodaiga
My Ride: 330ci
what can go bad besides the rim being bent?
Old 10-31-2011, 11:55 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
Bent rim, bad valve stem or a pinhole in the sidewall
Old 11-01-2011, 12:02 AM   #9
brodaiga
My Ride: 330ci
since I don't have the tools to take the tire off now, can I just change the valve stem and spray some compound that seals leaks in the tire and see what that does?
Old 11-01-2011, 12:05 AM   #10
Vic328CSi
Spray stuff ruins tires go ahead do that if u never want to repair it. Stem change is easy, go buy a new schreader valve first.
e46 328Ci 9psi SC
Old 11-01-2011, 12:08 AM   #11
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
Also could be a cracked rim. keep an eye out for that.
Drew@Swift Motorworks is offline   Reply With Quote
Old 11-01-2011, 11:21 AM   #12
TitaniumCranium
/// Limitless
Really... The car comes with a jack and the tools to take the tire off.
The tire shops will use a water vat to look for the leak, same principle as the soapy water.
If you don't want to do it yourself, then take it to Les Schwab (if you have one around you) and they'll probably fix it for free.
Edit: Couldn't see you were from FL while I was leaving the post - Les Schwab is more of a West coast thing...
/// MODS
Old 11-01-2011, 12:50 PM   #13
jdstrickland
My Ride: '94 325iC & '00 323i
Take the tire off of the car and drop the wheel into a tank of water, look for where the bubbles come from. Your tire shop should be doing this...
Old 11-01-2011, 12:53 PM   #14
jdstrickland
how?
How? Drive to the tire shop, ANY tire shop. America's Tire Store (aka, Discount Tire Store in some parts of the country) will do tire repairs for free. If the tire is leaking, they will repair it. If the rim is leaking, they will be able to figure out where it is leaking from and either fix it or tell you bought somebody's crap off of eBay.
Old 11-01-2011, 02:30 PM   #15
briangl92
My Ride: VQ37VHR
+1 on the soapy water. Or you could just take it to a tire shop and have them deal with it. If you get the tire repaired/patched make sure they rebalance it. Simple enough but a lot of people forget.
briangl92 is offline   Reply With Quote
Old 11-01-2011, 03:26 PM   #16
kerunt
My Ride: '06 ML350
+1.
Had this happen this past summer. Replaced valve stems, checked tire, still kept leaking. Turned out to be a crack in the rim.
'06 ML350
kerunt is offline   Reply With Quote
Old 11-01-2011, 09:59 PM   #17
gitchies
My Ride: 05 325xi
how?
Really? ...i think there is 6.5 bolts to undo, maybe the tire size should have been 20 inches instead of 19, ......i like this forum there is some useful information here....but sometimes i wonder....
maybe the grocery store can check the tire?
gitchies is offline   Reply With Quote
