Old 11-01-2011, 08:51 AM   #1
jeepo23
My Ride: 2008 X3, 6 Speed
Rear Brake Job - Sensor question
Want to do my rear brakes this weekend.
Couple of quick questions,
Do I need a new wear sensor too? It has not triggered yet, does that mean I can re-use the old one?
Also, my parking brake handle pulls quite high. I figured since I am doing the pads and rotors might as well do the brake shoes. Or is it really the cable that needs re-adjusting at the handle and on the star shaped nut in the rear?
Also, any recommendations for brakes? I got a dealer here, is OEM really necessary or if I stick with the middle class Napa stuff im good?
jeepo23 is offline   Reply With Quote
Old 11-01-2011, 09:13 AM   #2
ZHPRegistry
Past Site Sponsor
My Ride: was a bit tiresome
The brake sensors are pretty brittle, so if you are able to very carefully pry it off of the old pad then you can reuse it. You can't reuse them if they "tripped"
ZHPRegistry is offline   Reply With Quote
Old 11-01-2011, 09:15 AM   #3
jeepo23
Ah, alright well mine hasn't tripped yet.
Guessing these sensors are only available from the dealer?
Old 11-01-2011, 09:35 AM   #4
nk_zhp
My Ride: ZHP / E30 M3
34351164372 is the p/n I believe. Available from many places online as well.
'04 330i ZHP - OEM Clears - ///M Strut bar - CoolantSnitch
nk_zhp is offline   Reply With Quote
Old 11-01-2011, 09:57 AM   #5
Stinger9
My Ride: '04 330Ci
Why would your shoes be worn?
What severe duty would indicate that these are not almost new?
And rear brake sensor breaks easily, so good to have one spare if needed. Do you want to run to the store like I had to do when replacing brakes? Available from dozens of online BMW vendors. Return it if you do not use it. Tiny little spring clip easy to lose.
Rear brakes adjustable at the console handle.
All this trouble, why not get superior pads that will not dust nearly as much, but with great braking ability? Take a look at Axxis Metal Masters strongly recommended at the Turner Motorsport site. Fantastic on my car.
Old 11-01-2011, 10:28 AM   #6
ECSTuning
ECSTuning's Avatar
My Ride: BMW
If you are super super careful sometimes you can reuse them. Typically they are replaced during each brake job.
With the hand brakes the cable often stretches, when you reach the maximum adjustment it's going to be time to replace the cables. There are two cables a right and left, you'll want to replace both at the same time when that time comes.
I've had my parts specialist put together RPS (Rotor, Pad, Sensor) Kits for the Front and Rear of most BMWs. Your 330xi is one they have covered. I'm not familiar with the quality of the middle of the row Napa products but the Brembo or Zimmerman rotors as well as the PBR Ceramic Brake Pads found in our RPS kits are not only direct replacements but all quality products.
If you ever have any questions or need help finding parts feel free to shoot me a PM!
ECS Tuning
Old 11-01-2011, 10:32 AM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I usually replace the sensor anyways since it costs about $8 for me. The brake job is very easy, just make sure you have a nice 12" breaker bar.
Old 11-01-2011, 10:47 AM   #8
jeepo23
I see their bad, the mechanic told me inspection will be a no go until changed, the PO told me so. Very obvious their done
Just picked up all the stuff from the dealer. It was the cheapest around town than anyone else. Picked up pads, disc and sensor. And I would of ordered online but I needed them this weekend so ordering was a no go. Also I am not even sure how much I would of saved if I had ordered online after shipping/ and a chance of duties to Canada..
Old 11-01-2011, 11:19 AM   #9
Stinger9
My Ride: '04 330Ci
The word Canada convinces me
you did the right thing! If in the states you get free S&H from most everyone.
Good Luck! We're here on weekends too. Hope your rotors pop off easily.
Old 11-01-2011, 01:45 PM   #10
jeepo23
Yah I'll be doing it with a buddy so I'll have an extra set of hands. Overall the cost wasn't too bad just the dealer wanted a tad bit too much for just the brake shoes and the spring kit ~$200.
I priced out the brake shoe kit online from a canadian retailer and the shoes and spring kit and its like 120$ cheaper. So down the road I can always swap those. For now I'll just adjust the cable to lower the amount I have to pull the handle.
Old 11-01-2011, 02:16 PM   #11
TopazBlu02
My Ride: 330CI
I was able to reuse my brake sensors when I replaced my pads. The corners were chipped a bit when taking it out but still usable. You just gotta pry it out carefully.
TopazBlu02 is offline   Reply With Quote
Old 11-01-2011, 02:38 PM   #12
jeepo23
Yah I will try and remove it without braking lol. But better have one on hand just in case.
Quick question; bleeding the brakes at the end. Do I only need to do the 2 rears since that is where I am replacing pads/rotors or at all 4 wheels?
Old 11-01-2011, 02:54 PM   #13
CylonRed
My Ride: '01 E46 330i sport
You don't have to bleed the brakes if it has been done recently or within the last year or so.
CylonRed is offline   Reply With Quote
Old 11-01-2011, 03:00 PM   #14
SPDSKTR
My Ride: E46 ZHP TS2+ Coupe
Note on Zimmerman rotors: I bought some cross-drilled Zimmermans for my first brake job and they didn't last long at all. Maybe five months tops. The holes weren't all that impressive looking, either. I went with OEM blanks this time around.
Originally Posted by Brucifer325 View Post
Thread sucks so bad they moved it to the Feedback Forum.
SPDSKTR is offline   Reply With Quote
Old 11-01-2011, 04:09 PM   #15
jeepo23
Really?? I thought every time you service anything brake related you have to bleed them?
According to service records I have here, the front pads and discs were done in March 2011.
So your saying I will not have to bleed one this weekend when I do the rear end?
Old 11-01-2011, 06:34 PM   #16
Stinger9
My Ride: '04 330Ci
If you have solid brakes now
And you change the pads properly, you will not have to bleed anything. No one here bleeds their brakes when doing a brake job unless you have a problem.
You need to find a good brake DIY and study.
Old 11-01-2011, 06:37 PM   #17
jeepo23
This is what I was looking at --> http://m3.madrussian.net/diy_rear_brake_pads.shtml
He does not say to bleed, but I've seen other members on here talk about it.
Old 11-01-2011, 07:09 PM   #18
Stinger9
My Ride: '04 330Ci
What you need to know
is to not let the calipers hang by the brake lines. Tie them up securely.
After you take out the old pads, ease the pistons back into the caliper cylinder while monitoring the brake fluid reservoir level so as not to overflow the fluid.
This whole process does nothing to necessitate bleeding.
Be careful, go slo and think as you go.
Old 11-01-2011, 07:29 PM   #19
jeepo23
Got it boss!
** Removed **
