Old 11-01-2011, 01:06 PM   #1
browniesong
My Ride: a car
DIY: custom red suede interior pieces
Hello fellow fanatics! Just was looking at my car and thinking about how much nicer the interior would look with some red suede accenting. I wish I could do the headliner, but I'm not a professional, and for that I apologize. I'm also leaving the b pillar out of the mix. I've been looking through the forums and it seems like a lot of unnecessary work to get one little piece off. For now I'm just doing the a and c pillar, the rear windshield brake light cover, the alarm center roof liner cover, and the sunroof/mic button trim. If someone shoots me an idea as to how I can completely wrap the headliner (nicely), I might look into doing it later on. I started yesterday and already finished with the a and c pillars. I'm sorry, I'm not the best at doing write-ups for DIY's but I thought I'd let you know the materials needed to complete the job. I'm off to start wrapping. I'll be back with pics in a bit!
browniesong is offline   Reply With Quote
Old 11-01-2011, 05:25 PM   #2
browniesong
My Ride: a car
Finished! Pics...
Total time: 5 hours of work
Materials needed: i purchased a yard of red suede and a half yard of black suede, helenes tacky adhesive spray, x-acto precision razor edge)
Total cost: approximately $65
I like the way it turned out. Sorry i pretty much failed at this DIY because i did all the wrapping and didn't think to stop and take pics :/ oh well. I'm thinking of wrapping the b pillars and headliner, then making the car trim red. Ill make a complete DIY including the removal of the b pillars (i know how frustrating it was to disassemble that thing with NO HELP FROM THE INTERNET! All removal diy i found were for a coupe). Lemme know what you think!
Sent from my Nexus S 4G using Bimmer
ID:	423435   Click image for larger version
ID:	423436   Click image for larger version
ID:	423437   Click image for larger version
ID:	423439   Click image for larger version
ID:	423440   Click image for larger version
ID:	423441   Click image for larger version
ID:	423443   Click image for larger version
ID:	423444   Click image for larger version
ID:	423445   Click image for larger version
ID:	423447   Click image for larger version
Old 11-01-2011, 05:28 PM   #3
browniesong
My Ride: a car
Oh, I almost forgot about the pics above.
1. The microsuede material i used (purchased from Joann fabrics for $32/yard)
2. Helenes tacky adhesive spray (great for holding wrapping + doesn't bleed or discolor)
3. Peel off original fabric
4. Spray entire surface with spray (until it looks a bit frost)
APPLY SUEDE/FABRIC CAREFULLY!
The adhesive spray is very sticky and can cause wrinkles.
5. Apply material and cut outline with an Xacto knife (also purchased at Joann fabrics for $6)
6. I painted the plastic vent pieces from the alarm cover
7.finished cover
8-9. Completed c pillars
10. Completed c pillars alarm cover and brake light cover
11. Spraying a pillar trim piece
12. Completed a pillar trim piece
13. A pillar before trim is attached
14. Completed a pillar
Old 11-01-2011, 11:54 PM   #4
darksideracer69
My Ride: 01 325ci
If you like it man then whatever, to much red for my taste. Anyways, you should have taken it all apart and then wrapped everything, cause now when you choose to finish the job you're going to have to take all that stuff off again.
IMAG02051
darksideracer69 is online now   Reply With Quote
Old 11-01-2011, 11:59 PM   #5
rcsummers
Mister TechnoMeister
rcsummers's Avatar
My Ride: M3
ive been contemplating doing my whole interior roof to different type of suede than the OEM. Something thats softer feeling.
"RICH"
EURO.TECHNIKS
My Build Thread
rcsummers is offline   Reply With Quote
Old 11-02-2011, 02:16 AM   #6
browniesong
My Ride: a car
I'm guessing you dont have red interior then . Idk i was thinking yellow but i thought it might look dirty. Its not as bright as the pictures make it look (my camera has a super flash haha). Just personnal preference i guess
Old 11-02-2011, 02:53 AM   #7
HyeWarrior
My Ride: '03 325i --> '13 GTI
I'm curious as to how this glue will hold up
HyeWarrior is offline   Reply With Quote
Old 11-02-2011, 03:39 AM   #8
Hermes
My Ride: cars older than you
prob won't stay for long. even 3M #77 sucks. I think I'm trying #80 next time
Respect Your Elders
Hermes is offline   Reply With Quote
Old 11-02-2011, 02:07 PM   #9
browniesong
My Ride: a car
I'm worried about the same thing. In other threads on wrapping the interior, it seems like this helene's tacky spray had the best results. It stuck firmly, plus I used clips on the corners for added support. It's only been a day, so I can't say it's holding up. I'll let you know if it begins to pull away or wrinkle. Cross you're fingers for me
Old 11-02-2011, 02:11 PM   #10
browniesong
My Ride: a car
The microsuede has a really nice, soft feel to it. If I were you however, I would get it done professionally. Not because I think you'd have a tough time doing it, but because you're car is ssssssssssexy . Then again, you don't have a sunroof which should make things a bit easier
Old 11-04-2011, 10:20 AM   #11
Bimmekid91
My Ride: 2001 e46
Bimmekid91 is offline   Reply With Quote
Old 11-04-2011, 10:28 AM   #12
stevenluczynski
My Ride: Is Steel Blue<3
If you didn't youse automotive grade material the color will fade...
I code cars-p'm me
stevenluczynski is offline   Reply With Quote
Old 11-04-2011, 10:41 AM   #13
intelone
My Ride: e46 M3
Looks great. Just have to finish the headliner. How is the durability against fading?
6MT CB ///M3.:. USMC Vet .:. Univ. Student
///Alpine .:. 9861 .:. H/C 701 .:. S624 .:. JL Audio .:. 300/4 300/2 500/1 .:. 10W6v2 wicked .:. Focal K2Ps
Diamond Graphite v710s .:. KW2s .:. ZCP Rotors .:. 996 Calipers .:. SS lines .:. Textar pads .:. VIS Bootlid
CSL Diffuser .:. CF Grills & Gills .:. Alcantara Steering Wheel & Boots .:. 55w 5000K TFX
My Sequential Turn Signals
intelone is offline   Reply With Quote
Old 11-04-2011, 01:16 PM   #14
Sweetness
E46 is strong with this one
Sweetness's Avatar
My Ride: '01 325i
Black Headliner or Bust. Right now your car has the interior of 66' Impala. Get all that off color eggshell outta there
Sweetness is offline   Reply With Quote
Old 11-16-2011, 11:28 PM   #15
browniesong
My Ride: a car
So far so good. No wrinkling, fading, loose fabric or any problems. I really want to do the headliner black. I just don't want to do it if its going to look shotty
Old 02-12-2013, 09:03 AM   #16
neutron325
My Ride: 03 325xi
I really want to do a black suede or vinyl wrap on my pillars and maybe headliner. I reglued my pillar covers last year and they are coming loose again.
My one concern is the airbags. How does the a-pillar cover separate when the airbag goes off and will changing the material have any detrimental effects? I was thinking of removing the fabric and epoxy coating the pillar cover to make a CF wrap possible, but I really don't want to get slapped in the face with a carbon fiber paddle should the airbag ever go off. I suppose I could recode it so those airbags are turned off, but I would like to keep those safety features if possible.
Apologies for digging up an old thread. Maybe this would be a good chance for OP to give us a long term update.
neutron325 is offline   Reply With Quote
Old 02-12-2013, 09:12 PM   #17
Redline4
My Ride: 02' 330Ci
Send a message via AIM to Redline4
Bro, just don't wreck . They bust from the bottom up so the trim goes towards the windshield than your face. Whats any different than what you have on their now? I'd rather have some nice suede hit me in the face rather than that thin tweed that's in their now. Just do it! I put up like a dark gray suede in mine and I love mine.
http://forum.e46fanatics.com/signaturepics/sigpic201481_1.gif
Redline4 is offline   Reply With Quote
Old 02-12-2013, 09:21 PM   #18
oAllElseFailo
My Ride: 328Ci
What did you use to hold yours? I just got 4/5 yards of gray suede for my whole interior, just trying to figure out whats best to use as an adhesive. I was thinking the 3M spray but i'm doubting it now due to what others said above about it.
oAllElseFailo is offline   Reply With Quote
Old 02-12-2013, 09:43 PM   #19
Redline4
My Ride: 02' 330Ci
Well I used the 3m 90 extra strength glue then where I folded it I put some super glue to hold the edges even better.
Old 02-12-2013, 09:51 PM   #20
oAllElseFailo
My Ride: 328Ci
And so far so good? Nothing starting to sag?
