Australia
Old 11-01-2011, 07:14 PM   #1
J-Tim
My Ride: Blue Bavarian Wagon.
Window regulator zip tie fix. It works!
It bloody works!! That's all I have to say.
No, really. I couldn't believe that I've managed to fix the driver side window regulator just by using a couple of zip ties.
All I did, was to watch this Youtube video, which explained in great detail on how to get to the window regulator, etc.
There is also a guide on how to do the actual zip tie fix, which makes a lot more sense once you've got the window regulator out of the car.
http://www.zhpmafia.com/forums/showt...or-zip-tie-fix
Just be sure to disconnect the battery BEFORE unplugging the airbag to avoid a failed airbag light.
Next time your windows start acting up don't rush and get a window reg from eBay for $80 or worse yet $300 from BMW. Don't be lazy and do it yourself.
It most certainly not a difficult job to do.
If an IT person can do it, anyone can.
J-Tim is offline   Reply With Quote
Old 11-01-2011, 08:11 PM   #2
shannon1
shannon1's Avatar
My Ride: 2001, 318i
Congrat's well done.
Shannon.
shannon1 is offline   Reply With Quote
Old 11-01-2011, 08:17 PM   #3
ttrinh9
My Ride: BMW e46 330i
I have a 4 door sedan.. Would this work for the rear window regulators??
ttrinh9 is offline   Reply With Quote
Old 11-01-2011, 08:52 PM   #4
J-Tim
Do be honest, I've no idea. However, I highly doubt that the design would be fundamentally different from the one, used on the front. It is still probably just a plastic piece, used to hold the cable.
Edit: The zip tie method doesn't work on rear doors, as per this thread
http://www.e46fanatics.com/forum/sho...d.php?t=693347
A possible DYI is here:
http://www.e46fanatics.com/forum/sho...8&postcount=11
Old 11-01-2011, 11:46 PM   #5
BMW E465
My Ride: 1dirty5
I love you ...
Could've saved myself a few hundy when I had to change the window regs on ye olde e36 and e39... I almost miss them for this reason alone. I want to try this out!!!
Might break a window reg on purpose to do this fix
BMW E465 is offline   Reply With Quote
Old 11-02-2011, 12:13 AM   #6
Ballistic325
My Ride: slow and steady
^ pls don't....
I did this a little while back on my LH front regulator. Be sure to lube up the railings with a silicone spray or similar.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 11-02-2011, 09:25 PM   #7
J-Tim
Yes, I forgot to mention that.
Thanks.
Old 11-14-2011, 01:11 PM   #8
nborton
My Ride: 2000 328i
I just did this and it worked great. Just something to help others (I initially messed up) is that you need to zip tie on each side of the stopper on the cable. I didn't realize at first that I had both zip ties on one side. Which made it only roll up, but not down.
nborton is offline   Reply With Quote
Old 11-14-2011, 06:07 PM   #9
Ballistic325
The other point to note is to make sure the tie is very tight, otherwise there could be slippage.
I can help with
* RTABs
Old 11-24-2011, 10:31 AM   #10
ride365
Getting ready to do this job. Can I get more info on the above please?
Edit: Never mind I got it sorted.
ride365 is offline   Reply With Quote
Old 03-08-2012, 10:17 AM   #11
nborton
My Ride: 2000 328i
Back after a few months. My zip ties were too weak and snapped. The method works, but the zip ties need to be pretty sturdy. I'm going to try steel zip ties today.
Old 03-08-2012, 04:15 PM   #12
Ballistic325
Steel zip ties?
This is valid to my interest.
I can help with
* RTABs
Old 03-08-2012, 04:45 PM   #13
selien
My Ride: 330CI
wow never realised, my door panels totally different.
I AM OF DUBIOUS NATURE
selien is offline   Reply With Quote
Old 03-08-2012, 05:23 PM   #14
gueste46
Banned User
I hear it does work. But you will probably have to replace them again in a few weeks or a few months.
I just felt that if I was going to take the whole damn thing apart, I may as well replace the regulator and get several more years trouble free use.
gueste46 is offline   Reply With Quote
Old 03-08-2012, 05:38 PM   #15
Rajvosa
My Ride: M3
exactly. i changed my gf's window regulator about a month ago. didnt want it to break again so just put a genuine one in.
talk to Clicable Automotive, they have them for a great price!
Rajvosa is offline   Reply With Quote
Old 03-08-2012, 10:47 PM   #16
J-Tim
It's been over 4 months since the "fix" and the driver's side still works.
Old 03-08-2012, 10:56 PM   #17
gueste46
Banned User
1+ for Clickable Auto. Good price, lightning fast delivery.
Old 03-08-2012, 11:27 PM   #18
gueste46
Banned User
It just seems a shoddy way to hold a BMW together. But, you need to do what works best for you. I hope it holds together for a long time.
Old 02-22-2013, 03:09 PM   #19
nborton
My Ride: 2000 328i
The steel zip ties do work great. I did one fix with plastic ones first, and it lasted a few months. The steel zip ties have lasted me two years.
Old 07-15-2013, 11:35 AM   #20
tractioncircle
My Ride: 02 325i
I just did this fix. My window had collapsed all the way down.
If you are doing the zip-tie fix, you do not need to take the regulator assembly out, or remove the motor either. I was able to put the zip-ties in with the window and the carrier (on which the zip-tie goes) around half way up. Once its near the access holes, its pretty easy to get the zip-ties into place and tighten them.
Saves a bunch of effort.
tractioncircle is offline   Reply With Quote
