Old 11-01-2011, 10:43 PM   #1
M3Knight
My Ride: M3
Ran into an issue while installing Angel Eyes
I was wondering if any of you can help me out, I starting to install my Orion V2 Angel Eyes and I gotta tell you it's harder than I excepted. I wired them in and got them to work just fine, my problem is once I started putting the lights back together I ran into an issue. The left side headlight bezel trim goes in without any issues but the right bezel trim is hitting the angel eyes. I than realized about 1/2 inch the right inner headlight is sticking out further. I'm completely frozen and not sure what else to do. Any suggestions?
M3Knight is offline   Reply With Quote
Old 11-01-2011, 10:49 PM   #2
zhenkaaaM3
My Ride: Fst'r then your e46
A picture would help.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 11-01-2011, 10:55 PM   #3
M3Knight
My Ride: M3
Here is a photo, as you can see that's as far as the bezel trim is willing to go
Old 11-01-2011, 10:57 PM   #4
zhenkaaaM3
weird, those angel eyes look way to big for your headlights. Did you specify that you have projectors when purchasing them?
Eugene
Old 11-01-2011, 10:58 PM   #5
hokiebimmer
My Ride: 2003 BMW 330i ZHP
I had the same issue. Just keep working it in different ways until it slides in.
hokiebimmer is offline   Reply With Quote
Old 11-01-2011, 11:01 PM   #6
M3Knight
My Ride: M3
Yes I have projectors, the left side went well I had no issues. But this side the inner headlight literally is 1/2 inches further out and that's what causing the problem.
Old 11-01-2011, 11:01 PM   #7
zhenkaaaM3
I am sure he is. It looks like, if you put on the bezel, its going to be cover the bottom part of the angel eye (of your high beam bowl).
Eugene
Old 11-01-2011, 11:03 PM   #8
M3Knight
My Ride: M3
Yes that's exactly what it does, the bezel covers the bottom of the angel eyes. Since it's smashing directly into it.
Old 11-01-2011, 11:06 PM   #9
zhenkaaaM3
Solidjake is good with this sort of lighting things. maybe you should give him a PM with pics and issue.
Eugene
Old 11-01-2011, 11:21 PM   #10
M3Knight
My Ride: M3
Will do, thanks
Old 11-01-2011, 11:27 PM   #11
M3Knight
My Ride: M3
Here are some more photo's
ID:	423542   Click image for larger version
Old 11-01-2011, 11:35 PM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Remember, angel eyes are aftermarket. On my sedan one of my drivers side rings doesn't fit properly while the rest of them fit fine. Maybe you can take a file and file down some of the plastic.
Old 11-01-2011, 11:43 PM   #13
nonseqtur
My Ride: '04 TiAg 330i
It looks like you bought halogen-fitment angel eyes and put the wrong one on each light. With halogen fitment, the bigger angel eye goes on the low-beam, and the smaller one goes on the high-beam. That looks odd before you put the bezel on because the high-beam bowl is bigger than the high-beam angel eye, but that's precisely because the high-beam angel eye is fitted to the bezel (i.e. smaller than the high-beam bowl.
Maybe?
nonseqtur is offline   Reply With Quote
Old 11-01-2011, 11:53 PM   #14
Bemwe_03i
My Ride: 2003.5 E46 M3 smg IR
I had similar problem. You kinda have to leave one corner tab of the bezel trim out or it hits. I had problems putting back the whole headlight, fvcking nightmare. Yours looks out too much. If you push them all the way in it should fit unless you have the wrong ones. The trim doesnt look like its in the right place. GL
just for fun ill add this pic when i did mine...
Bemwe_03i is online now   Reply With Quote
Old 11-02-2011, 02:12 AM   #15
M3Knight
My Ride: M3
Thanks guys for the quick responses, I went back into the garage and was able to figure out the problem. Apparently behind the headlights I found two circular teeth when you turn them they bring the inner headlight further in or out. Which in my case I needed them to go back 1/2 an inch. I figured that out the hard way, removing the headlights and putting them back was a nightmare indeed.
Old 11-02-2011, 02:44 AM   #16
brandonwish
My Ride: 02 325i 5MT
Thank you for posting what was indeed wrong.
|||2002 325i 5MT|||
brandonwish is offline   Reply With Quote
Old 11-02-2011, 04:49 PM   #17
M3Knight
My Ride: M3
End result
Old 11-02-2011, 04:54 PM   #18
jasonbimmer
My Ride: 2001 BMW 330xi
looking good.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
aurora ae harness bright
