Old 11-01-2011, 11:55 PM   #1
bmwm330cie46
My Ride: e46
Question 330ci oil light
hi i shifted my car down in higher rpm from 5 to 4 but mist and hit second gear car over reved and oil light came on yellow not red so i drove 1 mile home then i noticed something wrong with the response of the engine i look down and oil light is red and the car did not accelarate no more pulled over and got it towed home a block down , there was smoke coming out when i opend up oil cap and engine run but stols out when i relise the clutch in gear to go, there is no oil presure but what else is wrong why the engine stoling? plz help
bmwm330cie46 is offline   Reply With Quote
Old 11-02-2011, 12:14 AM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
jesus.
did you check your oil level?
red means there is something wrong with your oil pressure.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 11-02-2011, 12:57 AM   #3
TArse
My Ride: 03 330xi, 87 325is
Check the oil.
Yellow is low oil.
Red is low oil pressure.
Money shifts are no good.
Pray it's just low oil.
TArse is offline   Reply With Quote
Old 11-02-2011, 01:14 AM   #4
Stinger9
My Ride: '04 330Ci
Maybe big trouble
You force a severe over revving onto the e46 engine and no telling what is major damaged at this point.
Drive chains, gears, etc. might be damaged.
Get someone who knows their stuff to take a look at this.
Old 11-02-2011, 01:46 AM   #5
bmwm330cie46
My Ride: e46
would a e36 or e46 engine fit on my car?
Old 11-02-2011, 02:02 AM   #6
crazyafghanguy
My Ride: E46 M3
money shifting hurts!
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
Street Edge Coilovers
ZCP Brake Upgrade
LED Tail Lights
crazyafghanguy is offline   Reply With Quote
Old 11-02-2011, 03:13 AM   #7
Vic328CSi
My Ride: depends on the mood
second money shift this week
your engines gone to a better place, either got to replace it or sell the car.
e46 328Ci 9psi SC
Vic328CSi is offline   Reply With Quote
Old 11-02-2011, 11:00 AM   #8
jdstrickland
My Ride: '94 325iC & '00 323i
You are asking questions that you cannot deal with the correct answer anyway, just take the car someplace and have it looked at. They will tell you what the cost of repair is, and you make your next move from there.
If we could give you the right answer from here, you would already know what it is and would not have asked us.
The yellow oil light means the oil level is low. Why the level is low is anybody's guess. When you saw that light, the first thing to have done is to stop the car and pull the dipstick to see what the level was, and then take the necessary steps to bring the level into compliance. You might have taken this opportunity to look under the car to see if oil was streaming out from anywhere, which it apparently was but we can't really know from what you said so far.
The red oil light means there is no oil pressure. Couple the red light with the engine's refusal to run and what you have is a very bad sign. From this side of the interweb, it appears that you have blown up the motor.
Your car is an E46, and the motor that it comes with is called an M54. For the sake of ease of labor, put in another M54.
Then buy a car with an automatic.
