2 quick questions... - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-02-2011, 11:15 AM   #1
bcaughhorn
My Ride: 02 330ci,04 frontier
1) how much oil does my car take?
2) what is the black box that goes in the side of the intake? i need to get the o-ring for it. mine is leaking..
02 330 ci(wifes)
00 crew cab F250 superduty(mine)
01 crew cab F150 bagged on 24s(my toy)
bcaughhorn is offline   Reply With Quote
Old 11-02-2011, 11:16 AM   #2
xXSHR00MIESXx
My Ride: BMW 330ci Sport Pckg
Your Car takes About 7qt and That box is called DISA. It's probably broken and you should buy new one. Inexpensive part.
My 2004 330ci , Picture Taken By E46_Moonlight
xXSHR00MIESXx is offline   Reply With Quote
Old 11-02-2011, 11:18 AM   #3
lsteg
My Ride: 2001 330ci
lsteg is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-02-2011, 11:18 AM   #4
bcaughhorn
ok thanks for the help.
is that (disa) short for something or the actual name?
02 330 ci(wifes)
Old 11-02-2011, 11:33 AM   #5
jasonbimmer
My Ride: 2001 BMW 330xi
DIfferenzierte SAuganlage - "Differential Air Intake"
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 11-02-2011, 11:56 AM   #6
bcaughhorn
thanks for the help
02 330 ci(wifes)
Old 11-02-2011, 12:50 PM   #7
dmitrofed
My Ride: Red 2001 330xi
actually you can rebuild the disa if its broken. i read in a thread and watched a video of a guy do it so i figured i'd try it on my car. what happens is that valve is like a butterfly valve that changes the length of the intake at different RPM with engine vacuum. the part is made of plastic and it rounds out in the flap itself so you can take it apart and clean it with some intake cleaner and glue the flap to the control unit. if you want to save yourself $200 and dont mind doin it yourself then PM me and ill explain how to do it. i did it to my own car because mine was starting to make a chattering noise with the car running and after i glued it up it stopped making noise. did it to my cousins car to, she has a 530 with the same engine and hers was completely loose so after i did it she said the sound of the engine changed after i fixed it.
dmitrofed is offline   Reply With Quote
Old 11-02-2011, 01:00 PM   #8
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
^ He just said the o-ring is leaking...
Old 11-02-2011, 01:34 PM   #9
new//M3fan
My Ride: 77' 924 87' E30
6.9 Quarts to be exact
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 11-02-2011, 01:37 PM   #10
dmitrofed
yeah i know but if he decides he wants to rebuild it, it would be pretty easy to clean off the mating surface and put a small coating of RTV or gasket maker on it to seal it, or he can just go ahead and buy the thing it doesnt really matter to me, just figured i'd give him another option
Old 11-02-2011, 02:14 PM   #11
bcaughhorn
i put a new o-ring on it and changed the oil. i found the reset video on here and tried that. mine didnt go to 15k. it shows 9550 i think. i mite be a little off but not much
02 330 ci(wifes)
