Old 11-02-2011, 11:24 AM   #1
daniel_f.
My Ride: 330iC
Anyone using Schrick 272 / 256 cams in M54B30?
Hi guys,
having a nice offer for 272 / 256 Schrick cams and wondering if anyone is using them? Maybe someone could let us/me know how the torque changed.
Old 11-02-2011, 11:42 AM   #2
Iceman00
Banned User
My Ride: E90 6MT
There is a member here using them in his 323, and made impressive power with them. Can't tell you how the torque curve changed, we have no before dyno.
Old 11-02-2011, 12:33 PM   #3
daniel_f.
My Ride: 330iC
Is there a after dyno sheet?
ive been told those cams are good for an increase of ~25hp in/at/on (whats the right word?) M54B30
Old 11-02-2011, 12:36 PM   #4
Iceman00
Banned User
My Ride: E90 6MT
Technically 'on' would work best because of how you phrased the question. And I wouldn't doubt they are that effective, I think those are as large as you can go keeping the vanos.
Old 11-02-2011, 01:27 PM   #5
ZeroSum
My Ride: 05 325
I imagine Vanos rattle will be pretty horrific, it is getting bad enough on my car with 248/256 (and I have the anti rattle kit).
ZeroSum is offline   Reply With Quote
Old 11-02-2011, 02:19 PM   #6
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
VANOS rattle has nothing to do with the size of the cams in my experience
Old 11-02-2011, 02:53 PM   #7
TxZHP04
My Ride: ESS TS2+ ZHP
Not saying it's right or wrong but the more aggressive cam profile has always been the "best available explanation" for why ZHP cars have always seemed more prone to vanos rattle than non-ZHP cars.
Old 11-02-2011, 02:54 PM   #8
TxZHP04
You may need to make some more adjustments with your anti-rattle kit then. I'm running 248/256 with no vanos rattle.
Old 11-02-2011, 04:46 PM   #9
ZeroSum
My Ride: 05 325
All I know is that Schricks caused my rattle, within a few hundred miles of the install. My rattle is so loud I would not wish it on anyone .
Good to hear, from all the posts I read on the issue I assumed it could not be resolved. I will check it out, perhaps this will be the excuse I need to install an M3 tensioner as well.
Old 04-29-2012, 10:17 AM   #10
daniel_f.
My Ride: 330iC
anyone else? n/a build with these cams?
Old 04-29-2012, 10:54 AM   #11
TxZHP04
Your best bet might be to talk with VAC Motorsports.
Old 04-29-2012, 01:44 PM   #12
323I00
My Ride: E46 323I
OP will you be changing the lifters as well , Ive read up on this and many have said Its best to do both...Heres a link that gives some Insight , sorry Its gen for the 323I
http://www.bimmerfest.com/forums/sho...d.php?t=394403
Functional justification... true. But girls dropping their panties counts for something
BBK on non-supercharged-non-m..... because chasecar
323I00 is offline   Reply With Quote
Old 04-29-2012, 02:54 PM   #13
daniel_f.
My Ride: 330iC
nope, lifters will remain stock, but lifters will be freshly honed on top.
valves will be weight reduced by 40%, valve spring clearance will be re-arranged, valve seats getting 5 angle valve job and compression slightly raised.
Old 04-29-2012, 03:13 PM   #14
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
The only thing I'd question is this:
Would the 272/256 cams work well in the OP's Auto 330Ci ? I'd want to know the answer to this question with at least a little certainty before buying & installing them. If they did work, I'd also install the Supertech Valve Springs with Titanium retainers, about $500 & good to 9000 RPM.
Good luck,
Rob.
SUMMIT POINT WV 1:24:229 SCCA
Old 04-29-2012, 03:45 PM   #15
daniel_f.
My Ride: 330iC
good luck trying to rev til 9000rpm
please post pics of the botton end internals, which you easily can take a photo of from outside (through the hole in the bottom end, the conrods will dig)
Old 04-29-2012, 09:56 PM   #16
Rob43
Rob43's Avatar
Next time you may want to learn who your giving a verbal smack down on.
daniel_f, you just burned a good source of info; No More Help From Me.
I'm Out.
Old 04-29-2012, 11:13 PM   #17
323I00
My Ride: E46 323I
Arent 272 / 256 Schricks a little to agressive for the m52tu ? Shouldnt they be 248-248
Old 04-30-2012, 01:01 AM   #18
daniel_f.
My Ride: 330iC
I'm Out.
if youre able to give us useful information, do it. otherwise dont hesitate to take your info with you... somewhere else
Old 04-30-2012, 01:05 AM   #19
Iceman00
Banned User
My Ride: E90 6MT
Old 04-30-2012, 01:26 AM   #20
daniel_f.
My Ride: 330iC
tell me, what makes you think ""?
