Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 11-03-2011, 08:09 AM   #1
Dan330Ci~
My Ride: 330Ci Clubsport
330Ci Clubsport weight reduction
I've started this thread to detail some of the weight reduction I have done to my 330Ci Clubsport, beyond the 20 kg advertised. I'm still researching on ETK what exactly is removed or changed for the Clubsport trim (option code S768A). Weights are given in kg from ETK or if not listed then as weighed.
For now I intend to keep 'full' interior, that's why a lot of the parts for the first round of savings are insulation etc. Note that I put back the insulation over the rear wheel arches in the cabin as this made a lot of water noise come into the car when the roads were wet and was so much more obvious and sucked compared to any general increase in noise, which is very slight anyway. It seems most of the battle in stopping general noise increase is from the trunk area so this also helps here.
I don't weight the car before beginning so I'll have to figure that out from what I know here once I do weigh it.
This first batch of savings are from parts I have permenantly removed:
Weight (kg), Part no., Description, Notes, Qty (if >1)
14.000 36 11 6 750 007 black steel emergency wheel 3.50BX17 ET:30 - includes tyre
1.670 51 48 8 252 759 sound insulation floor rear - under rear seat
0.594 51 48 8 193 943 sound insulating wheel housing rear left - in trunk
0.594 sound insulating wheel housing rear right - in trunk
1.290 51 48 8 204 047 sound insulating lateral trim panel left - behind trim panel
1.290 51 48 8 204 048 sound insulating lateral trim panel right - behind trim panel
0.466 51 43 8 252 475 sound insulating left - behind trim panel
0.437 52 43 8 252 476 sound insulating right - behind trim panel
1.385 51 48 8 204 049 sound insulating trunk floor
0.249 51 48 8 193 941 sound insulating engine hood
2.060 51 47 8 228 209 set of floor mats velour
0.187 51 47 8 230 573 left oddments tray - below cd changer
0.710 71 60 1 095 457 warning triangle with container
0.028 51 47 8 265 682 bracket for hazard warn. triangle
2.250 65 12 6 913 388 CD changer
0.177 65 12 8 364 931 CD-MAGAZINE BMW 6 CD CHANGER AI
1.488 65 12 6 935 629 radio BMW business
0.614 84 21 6 934 552 Charging electronics, hands-free - bluetooth module SA644
0.236 84 21 6 933 413 eject box, mobile telephone - phone cradle
0.650 65 12 8 370 924 Base support system, front - CD changer
0.760 84 13 6 924 552 Base support system, rear - CD changer
0.138 65 12 8 370 925 Bracket CD-changer - CD changer 2
0.505 84 13 6 924 553 Bracket for telematics control unit - bluetooth module
1.826 71 12 6 757 131 articulated car jack, steel
1.162 71 11 1 094 912 trunk tray, emergency wheel
0.502 71 11 1 179 052 chock, steel - spare wheel
0.070 71 15 1 180 625 bracket for spare wheel
0.395 71 11 1 094 903 tool box
0.030 21 52 6 755 892 lock valve - CDV
0.722 52 20 8 225 847 headrest leather - rear headrest 2
0.472 52 20 8 236 224 guide - rear headrest 4
0.212 72 14 8 255 714 Holder Isofix, exterior - isofix 2
0.182 72 14 8 255 713 Holder Isofix, interior - isofix 2
0.112 07 14 6 962 565 Fillister head screw M10x26 - isofix 4
1.078 18 10 7 506 145 vibration absorber - muffler
0.133 18 10 1 740 207 vacuum tank - muffler flap
0.080 18 10 7 502 473 Bracket, vacuum accumulator - muffler flap
0.350 13 53 1 707 404 cover - fuel rail
0.177 11 61 7 501 566 pressure regulating valve - CCV
0.285 11 61 1 440 318 distribution piece - CCV
Total removed: 39.566 kg / 87.22 lb
I sold the CD changer on ebay for £55, the spare wheel for £76 (!).
Parts I have added:
1.304 51 71 0 395 077 strut brace - front
0.092 16 11 2 229 656 Fuel baffle fixture - M3
0.167 51 16 8 217 953 drink holder
0.030 51 16 8 217 957 oddments tray with coinbox
0.049 51 71 8 197 932 cover - oil drain
0.746 18 30 7 560 777 clamping bush d=50mm - exhaust 2
Total added: 2.388 kg / 5.26 lb
Total weight reduction: 37.178 kg / 81.96 lb
Not bad considering I still have full interior and this is all stuff I simply don't need to carry around.
Photo time
'04 330Ci Clubsport | Estoril Blue | 6MT | Black Leather/Silver Cube
Turner Motorsport | Ground Control | Stett Performance | Moroso | Powerflex | Meyle HD | Goodridge
Dan330Ci~ is offline   Reply With Quote
Old 01-29-2012, 06:29 AM   #2
mad8277
My Ride: 330ci
Were you able to find any more information on this? I am extremely interested in finding out the differences between the two models; and possible doing some work to make my 330ci closer to the clubsport model. I have looked in many places and even e-mailed some dealers but since the car never came to the US they couldn’t look anything up.
mad8277 is offline   Reply With Quote
Old 01-29-2012, 07:31 AM   #3
adame46man
My Ride: 2005 330i ZHP
Get a heat gun and take the sound dampening black tar stuff out from under rear seat and trunk. I've done it I think its around 20 lbs. You'll need some goo gone or some other citrus spray to clean up after.
Bimmerbrakes Headers, Magnaflow Catback Exhaust, Rogue Power Pulleys,Active Autowerke Software, Clear corners, side and tail lights, APEX ARC-8 wheels
adame46man is offline   Reply With Quote
Old 01-29-2012, 09:39 AM   #4
BeMyWhip
My Ride: 01 BMW 330ci
You should put the headrests back. They prevent death in a serious accident.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 02-04-2012, 04:32 PM   #5
Dan330Ci~
Thanks for the tip
I have been doing some research and will post soon, once it makes sense!
Don't worry I only have rear seat passengers maybe twice a year
I find the better rear visibility at all other times is more beneficial.
Old 02-04-2012, 04:50 PM   #6
boltan
Banned User
My Ride: 2004 330ci
Very cool! How are you liking all those new bushings and stuff you put on the car a couple months ago?
boltan is offline   Reply With Quote
Old 06-07-2012, 06:57 AM   #7
Dan330Ci~
The bushes are great! It's satisfying to have much more robust parts installed. The only wear items I expect to have to replace within the cars life are the RTABs (M3) and rear diff mount (Meyle HD).
I will update this thread asap.
Old 06-07-2012, 08:05 AM   #8
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
What he means OP is that they prevent YOUR death (driver and passenger) in accident caused by your head whip-lashing backwards in the event someone rear ends you. So think about you and your wife/gf, whatever, getting rear ended at a stop light while driving out to dinner. There's all kinds of idiots out there, so protect yourself and your passenger.
Good documenting everything, it's useful info, but unless you're tracking you're regularly tracking your car or drag racing... why bother when every 100lb's is roughly 1/10th of a second faster.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 06-07-2012, 08:26 AM   #9
NOVAbimmer
My Ride: E60M
he's only removed the rear headrests
NOVAbimmer is offline   Reply With Quote
Old 06-07-2012, 08:35 AM   #10
ThatGuy_JZ
oh gotcha - my bad
Old 06-07-2012, 08:37 AM   #11
NOVAbimmer
My Ride: E60M
oh gotcha - my bad
I'm making the assumption that he'll put them back in if he has a passenger back there
Old 06-07-2012, 01:40 PM   #12
Dan330Ci~
Yeah I would put them back if someone was going to be back there.
I might put them back as I now have a rear seat cover for the dog that attaches to the front and read headrest posts that I use every few weeks. So it's worth putting them back to ease fitting it.
Old 01-18-2013, 07:54 PM   #13
ArmyBimmer
My Ride: 2003 M3
How did you get the rear headrests out? I tried once and couldn't figure it out... I don't have a rear seat so they're only really annoying and ruining the aesthetics of it... No worry about passenger safety
2003 ///M3: Daily
2001 330Ci: Totaled, part out!
1994 325is: S50 Turbo track rat, for sale
1987 325is: Sold!
ArmyBimmer is offline   Reply With Quote
Old 01-22-2013, 02:36 PM   #14
Dan330Ci~
From what I remember they just pull up, there is a notch in the posts and a clip below, see here:
http://realoem.com/bmw/showparts.do?...77&hg=52&fg=20
I think it is also possible to pull the headreasts off the posts and then pull the posts out of the parcel shelf.
Old 01-22-2013, 02:59 PM   #15
Alex323Ci
My Ride: M3 & 323Ci (sold)
in one photo it shows you took the Clubsport wing off. sacra-leg'
Old 01-22-2013, 03:14 PM   #16
My Ride: Lexus
That's a good reduction. Now i'm considering removing spare wheel tire/jack/chock. i'm sure it'll bite me in the @$$ one day though...
Old 01-22-2013, 04:45 PM   #17
tcphoto
My Ride: E92 335 MT Coupe
Seriously, how much difference can 81 pounds make? I wouldn't want to walk a couple miles or wait for a tow truck just because I wanted to save the weight of the spare and jack. Remove all that insulation and your car sounds like you're riding in a Mini. But you're still rolling on the 19's right?
tcphoto is offline   Reply With Quote
Old 01-22-2013, 05:24 PM   #18
dreyo27
My Ride: 2001 325ci
I found a good way to shed weight of a full size spare, the E46 non-M with 18" wheels had a dounut spare, so i upgraded my wheels to 18s anyway, so I took out my fullsize 17" spare, and replaced it with the oem 18" doughnut and spare cover.
Another thing you should do is get rid of the hevy sunroof. You rareley use it, and not only will you make it light, but you will shift the center of gravity LOWER.
dreyo27 is offline   Reply With Quote
Old 01-22-2013, 05:42 PM   #19
Davconelectric
My Ride: 2 dog powered sled
Wait .... This is not a track car?
Davconelectric is offline   Reply With Quote
Old 01-22-2013, 08:42 PM   #20
dreyo27
My Ride: 2001 325ci
I went to the track, 325ci stickshift, ran the 1/4 mile at 15.6
took out the spare, rear seats and ran a 14.9
