Sponsored by The Tire Rack
Old 11-03-2011, 10:12 PM   #1
ating
My Ride: 2004 M3
BBS LM 9.5/10 width setup
Hi All,
Most BBS LM setups I see are either 19x8.5ET32 with 19x10ET25 or the more aggressive 19x9.5ET32 with 19x11ET25.
Has anyone tried running a 19x9.5ET32 with 19x10ET25 setup?
The reason I ask, is cos I like the dish with wider rims but I don't want to run too much negative camber cos it's a daily driven car. I assume running 9.5ET32 fronts will need about -2.5 camber? I don't want to run more than this for daily driving. Also, how much camber needed for 11" on the rear? If it's too much, I'd opt for the less aggressive 10" rears.
Thanks!
ating is offline   Reply With Quote
Old 11-03-2011, 10:21 PM   #2
Snik
Snik's Avatar
My Ride: IR M3 Vert.
the more aggressive one should work, the front may require a mild stretch if youre lowered tho.
shouldnt need much camber either
Do you ride a sportbike?
