E46 Xi Forum
Old 11-05-2011, 02:54 PM   #1
gordo325xiwagon
My Ride: 01 325xit '12 328i
How to Access PS Banjo Bolts on xi??
I am changing out PS hoses using Starless's DIY Tech from Bimmerfest.
Compared to RWD, on an xi, access to the two (2) banjo bolts on the rack are different. Without the xi subframe, it is easy to access the bolts. However, I am having a difficult time getting the correct assortment of sockets and/or the proper approach.
Is there a trick to reaching these two bolts on our awd cars?
____________________________________________________________ _____________
2001 325xit and 2012 328i Sportwagon
gordo325xiwagon is offline   Reply With Quote
Old 11-08-2011, 10:50 AM   #2
whitexi
My Ride: 2011 328x, 2013 R56s
I used an open end wrench I believe, it was long ago but I do remember it was an awkward area to get at.
whitexi is offline   Reply With Quote
Old 11-08-2011, 11:04 AM   #3
gordo325xiwagon
Thanks Whitexi... I spoke with any Indy who said there is no 'trick' or special tool. Use whatever is in your toolbox. He suggested a socket and universal with a long extension, but I think your idea of an open ended stubby wrench will be the ticket.
The bolts are just tight enough to seat the crush washers. I think the torque spec is like 30 ftlbs.
Old 11-09-2011, 12:57 PM   #4
Mark M
My Ride: e30 M3 / e90 335d
Its awkward...just plan awkward. No special tricks...just a lot of twisting and contortions to make it all work. Hard part was keeping the inner washer on the bolt as you search for the threads to mate it into. Good luck.
Mark M is offline   Reply With Quote
Old 11-17-2011, 05:28 PM   #5
andymilonkis453
My Ride: 2001 BMW m3
I had to replace my High pressure lines a couple weeks back and this bolt was by far the most painful bolt to take off. I used an extension with a socket and slowly but surely turned the bolt half a cm 45 times until it came off.
andymilonkis453 is offline   Reply With Quote
