Old 11-06-2011, 02:46 PM   #1
scottyc
My Ride: e46 325ci
really odd miss/flat running!
Hi there my names scott, im new to the e46, and have recently just bought one! and i found your site whilst searching on google! lol
I have a weird problem with my car! its a e46 2001 325ci sport!
when i start the car it idles fine, i drive up the road and it really hesitates and is really flat to the point it feels like a missfire!
so i thought id read the fault codes, it came up with camshaft sensor b, which is the exhaust sensor!
so i thought id look at the sensor, popped the bonnet and discovered that it wasnt plugged in! so i plugged it in and deleated the code!
so i then took the car up the road for a spin! but the car was even worse missing all over the place! to the point it was un drivable! so pulled over on the side of the road and unplugged the exhaust exhaust cam sensor! switched the car of and started it again. and it went back to how it was before hesitaing and flat but drivable!
so with it plugged in- its undrivable,
unplugged- flat and hesitates with major power loss but drivable!
Any ideas?
anything would be much appreshated!
scottyc is offline   Reply With Quote
Old 11-08-2011, 03:20 PM   #2
scottyc
My Ride: e46 325ci
no one ?
Old 11-08-2011, 03:24 PM   #3
jdstrickland
My Ride: '94 325iC & '00 323i
Any new codes? Is the CHECK ENGINE (SERVICE ENGINE SOON) light on? Are you using the correct gear? Can you improve performance by selecting a lower gear?
Old 11-08-2011, 03:26 PM   #4
jasonbimmer
My Ride: 2001 BMW 330xi
plug it in and disconnect the battery for 20 mins
maybe the ECU just needs a relearn.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 11-08-2011, 03:32 PM   #5
jdstrickland
Disconnecting the battery does nothing on an OBD II car.
Old 11-08-2011, 03:56 PM   #6
jasonbimmer
depends on what cars. maybe does nothing on an E46 but other OBD2 cars you can unplug the batt to reset it.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 11-08-2011, 03:59 PM   #7
Sweeney921
My Ride: 2003 330Ci ZSP
15:1 !:. ratio
Sweeney921 is offline   Reply With Quote
Old 11-08-2011, 08:10 PM   #8
JimC-NH
My Ride: 2004 330Ci Vert
Ahhhmm. I'll go out on a limb here and say - replace the sensor.
JimC-NH is offline   Reply With Quote
Old 11-09-2011, 03:45 PM   #9
scottyc
My Ride: e46 325ci
if you select a lower gear you get better preformance and then when you get to about 3k it goes really flat/missy and you have to change up a gear!
Old 11-09-2011, 03:48 PM   #10
moiz21
My Ride: 1999 323i 5-SPD
Plug the sensor back in and reset the codes on your car. Start her up and try and drive it. When the symptoms come back/get worse try and read the codes again and see what you get. It may be that the sensor needs to be replaced or may be something unrelated. Something of this nature has to be throwing some type of code.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 11-09-2011, 03:49 PM   #11
lsteg
My Ride: 2001 330ci
just......no
but anyway, I'd vote for it being a bad sensor. may explain why it was unplugged in the first place.
lsteg is offline   Reply With Quote
Old 11-09-2011, 03:52 PM   #12
scottyc
My Ride: e46 325ci
ok, ill do that tomoz morning! and ill let you know the results! hopefully we can get to the bottom of it!
Old 11-10-2011, 03:58 PM   #13
scottyc
My Ride: e46 325ci
P0300
P0313
P1349
P1351
these are the codes i keep getting
tryed swapping the coils around and it makes no diffrence, it dosent transfer to diffrent cylinders!
when the cars miss firing and the cars running and you delete the codes it goes bk to running on all 6 and then quickly starts missing again!
Old 11-10-2011, 04:10 PM   #14
moiz21
Sounds like a air or fuel problem. I could be wrong but check for a leak after the MAF, check the intake boots for tears. If that is ruled out could be a fuel issue. Could be your pump or filter. Filter being the easier of the two to replace. I've seen a bunch of threads with those codes and those are usually the likeliest culprits.
MODS
Old 11-10-2011, 04:11 PM   #15
scottyc
My Ride: e46 325ci
after reading some things on here, do you think its possibly the fuel pump?
as when i came to come home tonight, the car wouldnt start it just cranked over! left it a 2nd and it started!
Old 11-10-2011, 04:14 PM   #16
moiz21
Yea actually. Sounds like it may be on its way out. But that is more expensive. If you want to be certain eliminate the vacuum leak possibility first. If not then you can move onto the fuel aspect. $20 and you can replace the fuel filter. If none of these solve your issue, go for the fuel pump. Or just do the fuel pump first, up to you. Just a way to eliminate the easier of the options first without spending more than you absolutely have to.
MODS
Old 12-10-2012, 10:06 PM   #17
figjam911
My Ride: 1999-323i
Any ideas?
Mine is the same...a 323i - 1999 model. Runs like s**t with a new exhaust sensor plugged in.
Recently I have replaced the plugs, fuel filter, fuel pump, inlet camshaft sensor and last of all the exhaust camshaft sensor...the latter didn't fix it and it runs perfect with the exhaust sensor unplugged.
Car is a little hesitant when accelerating, but OK. runs OK at 110 km per hour on highway!
I don't have a code reader.
No engine warning lights on at all!
What could it be?
1999-323i Steel Grey, black leather, CD stacker, tinted windows, reversing radar, sunroof and Pirellis on M-Sport 17" alloys, 245 mm wide on rear and 225 mm wide on front.
Colin Boucher
figjam911 is offline   Reply With Quote
Old 12-12-2012, 05:09 PM   #18
Slapsys
My Ride: 323Ci
Why not take it to a BMW Dealership and ask them for a quote before they fix it. That way you'll know the most likely problem and could figure out if you are comfortable to fix it yourself or see what an indie would charge you.
Slapsys is offline   Reply With Quote
Old 12-12-2012, 06:17 PM   #19
figjam911
My Ride: 1999-323i
Thanks, but I was hoping for a idea or clue from someone here. I can't find a fix here on this forum after searching for hours and hours!
Colin Boucher
Old 12-12-2012, 07:31 PM   #20
scarede46er
My Ride: 2001 BMW 325i ZSP
Where can I get the fuel filter for 20 bucks? The lowest I have seen is about 40.
