Old 11-10-2011, 02:55 AM   #1
jetblackmaverick
My Ride: parting out...=(
which switch in pic is the one that is depressed with the clutch?
So my bro had a shop do some dumb@ss push button start deal and now I am left having to return the car back to a clutch pedal start car. problem is the shop removed the switch that is pushed in when you depress the clutch. It is obviously # 11 or 12 in the pic, but im not sure which.
jetblackmaverick is offline   Reply With Quote
Old 11-10-2011, 03:25 AM   #2
MJLavelle
My Ride: 2001 BMW 330ci
I am assuming you are using RealOEM.com. If not, then go there. Because they describe part #12 as the clutch switch, and #11 as the brake switch.
I am glad you are switching it back. That is one dumb a$$ thing to do, and is illegal in some states.
Old 11-10-2011, 03:34 AM   #3
jetblackmaverick
that is real oem and I just want to verify with someone because both 11 and 12 in the diagram are affected by the clutch pedal; one is released when the clutch is depressed then one is pressed. thanks!
Old 12-08-2011, 12:32 PM   #4
akosht
My Ride: 1999 323i
yeah they exploded diagram doesnt even match my car. the one that is closed when the clutch is depressed is probably #12 but it is aligned wrong in the pic. it is actually installed 180 degrees to the alignment your diagram shows...
did you ever get an answer as to which one is or are they both used to provide signals to the car to start it??
akosht is offline   Reply With Quote
Old 12-08-2011, 01:39 PM   #5
lcoleman
My Ride: '79 Massey Ferguson
I'm pretty sure #11 is the brake light switch.
Why not leave it out? I hear that starting in neutral without the clutch depressed is better for the bearings...I assume throwout or thrust, or both.
Old 12-08-2011, 06:11 PM   #6
NJFF26
My Ride: 02 325xi
Except when you leave the car in gear and forget and go to start it without the clutch pressed in and it jumps forward into something.
NJFF26 is offline   Reply With Quote
Old 12-08-2011, 06:16 PM   #7
TX78666
My Ride: 330i ZHP, N55 135i
Originally Posted by njff26 View Post
except when you leave the car in gear and forget and go to start it without the clutch pressed in and it jumps forward into someone.
fify
Because... Grocery Getter.
TX78666 is offline   Reply With Quote
Old 12-08-2011, 06:41 PM   #8
lcoleman
I can safely say that I have never done that. Do you think cars have always had them?
Also, a failed CSS means the car won't start. That sucks.
Old 12-08-2011, 06:57 PM   #9
TX78666
They haven't always had seatbelts, or ABS, either. I believe someone in another thread on this site, had a remote start, which caused all kinds of damage when someone clicked it at the shop.
Old 12-08-2011, 08:16 PM   #10
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
It depends on what year car you have. Earlier cars used switch #12 as a neutral safety switch. Switch #11 is the brake light switch.
Later model cars used a hall effect sensor mounted on the master cylinder.
I believe that switch #12 is also a hall effect switch with 4 wires. one goes to ground, one goes to the battery positive wire feeding from the brake switch (sensor) wiring, one goes up to the ECU and the last one goes to the immobilizer unit.
/// MODS
Last edited by TitaniumCranium; 12-08-2011 at 10:24 PM. Reason: got my numbers backwards - corrected the issue
Old 12-08-2011, 08:20 PM   #11
TitaniumCranium
/// Limitless
^ On the left is the wire you just installed, coming down from the DME (ECU) and the wires attached to the clutch switch module, which snaps onto the clutch master cylinder.
Here is the reference for the clutch switch module pin-out. In short you will be supplying the hall effect sensor on the clutch switch module with power from the brake switch wiring, you will connect a wire to the DME (ECU), and the EWS (engine immobilizer unit).
PIN 1:
- Wire Color: BROWN/BLACK (brown wire, black stripe)
- Purpose: Provides Ground for the power side of the clutch module
- Connects too: Brake wiring, PIN 2 (same color)
PIN 2:
- Wire Color: BLUE/BROWN (blue wire, brown stripe)
- Purpose: Tells the DME (ECU) when the clutch is depressed in order to start the car and kill cruise control. Killing Cruise control will only work when the DME is re-coded to a manual.
- Connects too: PIN 23 of the DME, Module number X6004
PIN 3:
- Wire Color: VIOLET/YELLOW (violet wire, yellow stripe)
- Purpose: Provides + voltage for the power side of the clutch module
- Connects too: Brake wiring, PIN 1 (same color)
PIN 4:
- Wire Color: BLUE/BLACK (blue wire, black stripe)
- Purpose: Signals the engine immobilizer unit that a proper key for this car is in the ignition and in the start position, this is a valid start request so start the engine. THIS MUST BE HOOKED UP TO START THE CAR
- Connects too: PIN 8 of EWS (engine immobilizer unit)
_________________________________________
This wiring layout is for the type of switch that is mounted to the master cylinder with DME MS43, although I believe that both switches are wired the same. If you use the type that is mounted to the pedal bracket I think the wiring is the same but you should check the wiring diagram for your model car/DME to make sure.
/// MODS
