Old 06-02-2003, 09:19 AM   #1
MrBull
My Ride: 2000 328i
DDE GenV light locations on 2000 328 sdn
Just installed my GenV DDE's this past weekend and had a hard time finding a mount position for the passenger side lightbox in my 2000 328i sedan. On the drivers side I mounted it in front of the shock tower. On the passenger side screwed the lightbox's bracket to the top edge of the washer fluid tank.
For the passenger side, the only areas with enough room to mount the lightboxes were under the battery terminal, near the shock tower, to the right of the washer fluid tank (where I mounted it), or just behind the headlight, but in front of the washer fluid tank.
The fibers would not reach to the preferred position of under the battery terminal as the washer fluid tank would force me to route them around it. Behind the headlight was a concern because the side of the lightbox would've been pressed against the washer fluid tank. I was concerned with the heat the lightbox throws off & the melting of the washer fluid tank.
Any other suggestions are welcome. Also, is it possible to purchase those fibers in longer lengths? If so, I'm wondering on the effect of the halo brightness if the light has to travel a greater distance.
I'll try to post some pictures later of the install.
2000 328i Steel Gray Sedan Marriage+Child=No More Convertible
Current Mods: 18" GT3 w/Satin Finish * 235/40 Bridgestone Potenza S-03 * Hamann Eyelids * GenV DDE * Clears * Carbon Fiber Roundels * Chrome Gauge Rings * Keyhole Covers * iPod Install inside armrest * Painted headlight trim
| 2004 Planned Mods | Interior trim * Delphi XM installed in headliner * Stealthbox * AC Schnitzer Aero kit (possibly)
MrBull is offline   Reply With Quote
Old 06-04-2003, 07:59 PM   #2
•PROXUS•
My Ride: 328Ci + 528i
...got the same ride in coupe and I located mine in front just next to air condition connector (I think if I'm not mistaken) anyway as soon as you'll post some pix I'll let you know. But yea that is close to washer fluid tank.
•PROXUS• is offline   Reply With Quote
Old 06-05-2003, 12:12 AM   #3
LAFENGAS
www.thielstudios.com
LAFENGAS's Avatar
My Ride: 330ci
Send a message via AIM to LAFENGAS
here's a thread showing where I put mine:
http://forum.e46fanatics.com/showthr...r+charger+ddes
LAFENGAS is offline   Reply With Quote
Old 06-05-2003, 08:43 AM   #4
•PROXUS•
Man ..you are brave to put them there
I just dont want to think whats going to happen when bulb will brake it'll be too much hasle for me to take apart part of the body to change the bulb
check
guide from Umnitza
page 8 rigt lower corner shows you one location...but I think temperatures in that place are way too high anyway so I installed it between winshield fluid tank and air intake.
Old 06-05-2003, 11:57 PM   #5
LAFENGAS
LAFENGAS's Avatar
My Ride: 330ci
actually I only have to remove the inner fender cover (3 bolts) to replace a bulb if I need to. Not much of a hassel at all.
Old 06-06-2003, 07:08 AM   #6
MrBull
My Ride: 2000 328i
I'd love to move my lightboxes to inside the fender! Anyone know where I can get more of the fiber? I cut the pieces I have now, so they won't reach.
Old 06-09-2003, 09:17 AM   #7
MrBull
My Ride: 2000 328i
Pics of install locations
