Australia
Old 11-11-2011, 06:12 PM   #1
gueste46
Banned User
Is there a trick to removing OEM wheel?
I have taken all the 5 bolts out but the wheel is not budging even 1 mm. Am I missing something?
gueste46 is offline   Reply With Quote
Old 11-11-2011, 06:20 PM   #2
bimmerfan1990
Modded ///Member
My Ride: BMW ///M3
Grab at 4 and 10 o'clock and kind of rock back and forth. It'll come off
bimmerfan1990 is offline   Reply With Quote
Old 11-11-2011, 06:37 PM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
It is probably rusted to the hub. Use a rubber mallet and hit the tire on the back. When you put your time back on, place some anti-seize on the center ring of the hub so that it does not stick like it has.
BMWCaptain is offline   Reply With Quote
Old 11-11-2011, 07:04 PM   #4
ky0-325
My Ride: BMW e46 325i M-Sport
if you don't have a mallet, just give it a kick!
ky0-325 is offline   Reply With Quote
Old 11-11-2011, 09:06 PM   #5
fgin
My Ride: e46 facelift
+1
Becareful when you do this, if you're using the OEM jack. There is a reason why its called the "widowmaker" although in Con's case it might be a "happy widow maker"
fgin is offline   Reply With Quote
Old 11-11-2011, 10:08 PM   #6
Sherweeeny
My Ride: BMW Civic
Just wiggle and kick it mate. Also jack it up first
Sherweeeny is offline   Reply With Quote
Old 11-11-2011, 10:15 PM   #7
bwallace530
My Ride: 325
Kick the bottom of it and it will POP off
Sent from my PC36100 using Bimmer
bwallace530 is offline   Reply With Quote
Old 11-11-2011, 10:16 PM   #8
BMWCaptain
Yes, Jack up the car first. This will help tremendously. See, it is important to have all the fact to get a real solution to a problem.
Old 11-11-2011, 10:31 PM   #9
Sherweeeny
My Ride: BMW Civic
Uh yeah
Old 11-11-2011, 11:16 PM   #10
gueste46
Banned User
lol. I Jacked it up using a hydraulic jack (not the OEM jack - I'm too lazy). It took a bit of bashing with a rubber mallet on the inside of the tyre and it came right off.
Thanks guys I appreciate the help
Old 11-13-2011, 08:51 PM   #11
Shannon C
My Ride: Fern Green 318i exec
Con, take it off again then put a bit of grease on the hub - then do the same with the other 3 to minimise future issues - you might not have the luxury of a decent jack when you need it.
LED Tails / LED Plate Lights / LED Interior Lights / Angel Eyes / Smoked Corners / Smoked Side Indicators / Low beams - Narva Arctic Blue / High beams - Narva Plus 50 / Gauge Rings / Black Grille / Roof Spoiler / Boot Lip Spolier / Licence Plate Holder Deleted / Tinted windows / Style 44 Wheels/Coilovers.
Shannon C is offline   Reply With Quote
Old 11-13-2011, 09:14 PM   #12
DamoBMW
My Ride: '02 325Ci M-Sport
Before you put grease on I would also clean as much of the rust off with a wire brush.
I had a similar issue getting my old brake rotors off. I tried everything including blow torch, massive hammers etc. In the end I found this technique on youtube, which worked great:
DamoBMW is offline   Reply With Quote
Old 11-13-2011, 09:29 PM   #13
gueste46
Banned User
Shanon and Damo...Thanks guys..I will do exactly that. Great advice.
Old 11-13-2011, 10:02 PM   #14
CortinaD
My Ride: lots
Use the grease very sparingly if you intend to track the car Con.
CortinaD is offline   Reply With Quote
Old 11-13-2011, 10:17 PM   #15
gueste46
Banned User
I am really keen to track my 320i. I figure I could give those M3's a run for their money. I am also really keen for some one else to pick up the repair bill at the end of the day
My thing is not to drive a fast car. My thing is to drive the shiniest car on the continent. My time and energy goes to essential maintenance and detailing.
Old 11-13-2011, 10:27 PM   #16
fgin
Con, dont forget;
shiny = less drag*
less drag* = faster car
* In this case drag not equals Hawaiian shirts
Old 11-13-2011, 10:30 PM   #17
gueste46
Banned User
Originally Posted by fgin View Post
Con, dont forget;
shiny = less drag*
Bash me, rob me, take my wife (please) but never bad mouth my bright shirts.
I have very little in my life.
Old 11-14-2011, 07:59 AM   #18
Caosa
My Ride: 320Ci, Rx2 (soon)
I'm sure if I looked into it and read alot I'd find the reason but you know what; Constantine you're a ****ing champ. You're starting the car hobby late in life and you're humble and while you might not have alot of material things, you sure make up for it in terms of life lessons, experience and how you carry yourself. Your family and wife should be proud.
Kudos to you mate.
She's just a mazda coupe with a wankel mill, but she'll walk a skyline like it's standin still. I get pushed out of shape and she's hard to steer, but i get rubber in all four gears...
Caosa is offline   Reply With Quote
Old 11-14-2011, 04:25 PM   #19
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
Hiphip...
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
