Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 12-02-2011, 10:39 PM   #21
Vic328CSi
My Ride: depends on the mood
you got your answer, yep should work.
e46 328Ci 9psi SC
Vic328CSi is offline   Reply With Quote
Old 12-03-2011, 02:02 AM   #22
Vic328CSi
Still having some issues. I know my VO contains +LEDH like it should, and i had deactivated all the cold/warm checks... and i STILL have a bulb out warning on my dash. Anyone around to help?
e46 328Ci 9psi SC
Old 12-03-2011, 02:39 AM   #23
alex230ro
My Ride: BMW 325ti compact
Originally Posted by Vic328CSi View Post
I took your advice and tried using progman.
I was partially sucessful. I did this but still have one issue the bulb out warning on the cluster.
Selected Chassis > Change SW > Retrofit Installed? N > Retrofits > Rear Tail LED > Added
Then progman sucessfully encoded the VO and finished the process. I turned off the car, turned it back on to check. The LED Tails operate correctly with no flicker BUT the cluster still indicates that my tail bulbs are out.
When I was about to do this with the dealer a month ago, they told me that they needed 2hrs because sometimes they have to do it twice??
When I go back into the Retrofits menu, this time there are two other options "Rear Lights New" and "Rear White Lamps" also available.
Any suggestions?
BTW I bought this kit from a guy in romania, its not you is it?
no is not me,if you said that you deactivated hot and cold bulb check it should work ,it's weird that you get that light on the dash
alex230ro is offline   Reply With Quote
Old 12-03-2011, 12:42 PM   #24
Vic328CSi
Problem solved, I overlooked a couple of cold bulb tests that I thought were insignificant with regards to the brake/turn lights. I went back in and deactivated ALL cold/warm tests this time and the bulb out warning disappeared.
e46 328Ci 9psi SC
Old 03-27-2013, 05:08 PM   #25
Jerzboy21
My Ride: 02 e46 sedan
Hey Vic I just ordered my USB obd programmer (same as u) it sounds complicated maybe cuz it's a lot of codes/terms but hope my head is as quick as yours cuz I didn't even get it yet and I'm excited lol
Jerzboy21 is offline   Reply With Quote
Old 09-20-2014, 01:35 PM   #26
badasse46
My Ride: 2002 bmw 325i sedan
02 e46 sedan
I bought this from Romania on ebay months ago tried to get it to work and I gave up can some one please help me I wanna do a dme tune that's all
badasse46 is offline   Reply With Quote
Old 11-05-2015, 08:36 AM   #27
letkuteb
My Ride: E46 316TI 2002
Hi, i have some questions about a dme update/coding. I'm doing an engine swap, from n42b18 to n42b20, from what i've been told, i can keep my dme, ews and key, but i have to upgrade/code my actual dme to match the new engine. I have Pa scanner 1.4, WinKFP, NCS expert, INPA but i have no clue how to do the coding, i also have sp-daten files already. If any of you can give me a hint of how should i proceed... (i also have the key, dme,ews from the n42b20, but i don't have the ignition barrel and the drivers side door barrel).
Thanks!
letkuteb is offline   Reply With Quote
