Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 11-14-2011, 10:10 AM   #1
joeycannoli
My Ride: 911
BMW E46 3-Series DIY: Air Filter Replacement
***All, the original site hosting the images was removed. The pictures along with the full DIY can now be found below***
BMW E46 3-Series Air Filter DIY
This DIY article will help you successfully change the Air filter in the E46 3-Series. This was done on a 325xi so there might be a few variations between the different models, but all should be closely related. Changing the air filter on this car is relatively straight forward.
TOOLS NEEDED:
Flathead Screwdriver
Needle Nose Pliers
PARTS REQUIRED:
OEM Air filter: 13721744869
First let's pop the hood and get a good look at the engine bay. The airbox is located on the driver side as shown below.
First step is to remove the intake duct located in the lower front of the engine bay. It secured to the car by 3 of the BMW push pins circled below
It is a two step process to remove these push pins. First, grab a pair of needle nose pliers and remove the pin as shown in the picture
With the pin out you can now pull out the base of the push pin and slide the intake free.
Next step is to release the tabs holding the airbox lid on. There are a total of 5 tab located on each side of the airbox. The locations are pointed out below
Here is a close-up of how the tabs work. To release the clip you simply pull up on the tab as pictured below. By pulling up on the tab the clip at the top will release from the airbox lid
Picture of the tab released
The one tab between the airbox snorkel and the power steering reservoir is a little bit cramped to get to. If you need to you can use a right angle pick to release the tab.
NOTE: It is now possible to crack the airbox lid open and gain access to change the air filter. However, i wanted to remove the entire lid to clean the inside of the airbox so i went an extra step and removed the MAF connector and tube. You can follow my steps below or simply change the air filter now and proceed with the re-install in reverse order
To completely remove the airbox lid we need to remove the MAF connector and the loosen the MAF tube hose clamp. Grab a flat head and loosen the clamp highlighted below
To release the connector, push down on the silver piece and then pull outward to remove the plug
We can wiggle the airbox lid free from the intake tube
Old filter
To remove the filter simply grab it and pull out. Here is a shot of some debris i found in the airbox. Clean as necessary
Old air filter vs new air filter. This one was definitely in need of being changed
You can either pop the new filter on the base of the airbox or on the lid for installation. I found it easier to seat the air filter on the air box lid before putting the cover back on. If the filter edge is not seated in the groove properly the airbox will not seal correctly
Installed directly into base
Installed on airbox lid
That is pretty much it! Follow this article in reverse to button everything back up.
Hope this article has helped and motivated you guys to continue doing your own maintenance. Any questions please feel free to ask.
joeycannoli is offline   Reply With Quote
Old 11-14-2011, 10:20 AM   #2
BimmersGarage
My Ride: E46 330i
Nice job.
BimmersGarage is offline   Reply With Quote
Old 11-14-2011, 11:08 AM   #3
joeycannoli
My Ride: 911
Thanks! I have done a ton of these articles in the past, but this is the first one for the E46. Typing up a spark plug and valve cover gasket one right now...
Old 11-14-2011, 09:05 PM   #4
mickey513
My Ride: e46
Uh ...
I am pretty sure you can just pop the tabs, lift the top part of the box enough to where you just pull out the old filter and put in the new one. No need to do all the extra steps.
mickey513 is offline   Reply With Quote
Old 11-15-2011, 01:19 AM   #5
joeycannoli
My Ride: 911
Originally Posted by mickey513 View Post
Uh ...
I'm pretty sure i explained this in my article if you took the time to read. Thanks for playing though
Old 11-17-2011, 02:20 PM   #6
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
On the old filter, you can see what remains of the cotton-like backing. I put in a Mann filter last week and it also had this kind of backing. Looks like the Mahle filters do not have it. I can't imagine the backing does anything significant.
Old 11-17-2011, 10:10 PM   #7
John in VA
My Ride: 328i/325xi
What you see on the old filter is the black foam "pre-filter" layer (BMW's terminology). You can purchase a filter with or without it.
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 11-18-2011, 08:12 AM   #8
LeMansteve
Ha ha, only ze Germanz would put a filter on a filter!
I'm guessing the one shown here is black due to age. My new air filter had a white pre-filter.
Old 12-25-2011, 01:33 PM   #9
jas594
My Ride: 2004 BMW 325i
i went to change my oem filter and it didnt looked as bad as yours. the top looked the same and the bottom just had a grey sheet of foam across it. do you think it needs to be changed or should i wait?
i did replace it with a k&n and the startup sounded nicer but then i put back the oem incase it didnt need to be changed. I didnt know how to put the seal on with the K&N. is it necessary to apply the seal or is it ok to just swap the filters?
jas594 is offline   Reply With Quote
Old 12-26-2011, 12:46 PM   #10
John in VA
My Ride: 328i/325xi
The older filter I removed had the gray foam pre-filter; the newer one has the white fibrous layer. Age/condition will determine when to replace it.
Many pages of pros/cons on K&N filters. Many feel the stock paper filter does an adequate job, and does not run the risk of fouling the MAF with filter oil. Most owners use too much oil when prepping the K&N.
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
Old 02-12-2012, 11:06 PM   #11
Adamo99
My Ride: 2016 Wrangler 75thAE
I think what he's saying is that you don't need to remove the intake like you have- you can just take the top off the airbox and replace the filter.
Adamo99 is offline   Reply With Quote
Old 02-13-2012, 12:05 AM   #12
Sansho
My Ride: 2001 325i
Nicely done.
Sansho is offline   Reply With Quote
Old 06-28-2013, 11:25 AM   #13
edjerum
My Ride: BMW 323i
Air Filter DIY
Thank you for this. Very clear.
I have a 1999 323i. The two tips that helped the most was taking off the air intake (easy and quick) and putting the new filter in the lid made the reinstall easier. On my model there are two tabs (not clips) on the left side of the box and you need to slide the housing into these and then clip the other attachment points. I used the Mann filter purchased from Amazon.
edjerum is offline   Reply With Quote
Old 10-08-2014, 06:31 PM   #14
joeycannoli
My Ride: 911
BMW 325xi
Porsche 996 GT3
Joey Cuccaro
