Thread Tools Search this Thread Rating: Thread Rating: 87 votes, 5.00 average. Display Modes
Old 02-19-2014, 11:21 AM   #241
goose123
My Ride: 2005 BMW 325i
Did this yesterday. Hardest part was finding the three bolts I dropped. Only one made it to the belly pan. Took me forever to find the other two. I bought a magnetic pickup when I first started working on this car.
Mods: Clear corners and sidemarkers
DIY's: Belts, $5 key beep, pulleys, OFHG, oil change, VCG, Alternator, Plugs, radiator, expansion tank, coolant hoses, fuel pump
goose123 is offline   Reply With Quote
Old 02-19-2014, 11:43 AM   #242
Sedan Hussein
My Ride: e46
My VCG kit came in the mail yesterday. Going to knock it out when I do my vanos seals. Great write up OP
Sedan Hussein is offline   Reply With Quote
Old 02-20-2014, 10:19 AM   #243
john_y
My Ride: 2005 330ci zhp
During vcg change, the ultra copper rtv got smeared on the timing chain and some of it got locked inside.. was wondering if it would cause any harm? Im new here so any tiny bit of a tip is much appreciated, thank you fellas in advance!
john_y is offline   Reply With Quote
Old 02-20-2014, 11:23 AM   #244
Sansho
My Ride: 2001 325i
When it comes to BMW maintenance, consider a new friend. RTV should only go on the front like this:
Similar on the rear also.
Sansho is offline   Reply With Quote
Old 02-20-2014, 02:26 PM   #245
john_y
Thank you for the reply unfortunately learned about it a bit too late and I will definitely start doing my own maintenance from now on and of course doing more research before i do.
Old 02-21-2014, 10:56 AM   #246
lowesdown
My Ride: 2003 325i Wagon
Hard to say either way, it may stay on it may not. It might make it's way to your filter it may not. Seeing as the passages for oil are small throughout the engine I could see a potential for it to get stuck in one of those. Cross your fingers...
lowesdown is offline   Reply With Quote
Old 03-28-2014, 05:20 PM   #247
kwill1992
My Ride: 2004 330ci
Awesome write-up!
I just change my valve cover gasket. Thanks a lot for this write-up! I love internet.
I used the RTV sealant as mentioned in the post.
A question though: Does it come with sealant there from BMW? I did not see any old residue on the old gasket or the engine.
Kevin
kwill1992 is offline   Reply With Quote
Old 03-28-2014, 11:24 PM   #248
lowesdown
The reason for the RTV is prevent failure again. The motors do not come with RTV from factory.
Old 03-29-2014, 04:39 AM   #249
AudiEtr
My Ride: 330i
If I change my VCG today (saturday) is it OK to go to the track tomorrow? The drive to the track is a little over an hour if that makes a difference. Thanks
AudiEtr is offline   Reply With Quote
Old 04-03-2014, 11:58 PM   #250
projectmayhem713
My Ride: '04 325i - '90 535i
Did VCG a couple years/40k ago. Followed this tutorial. Worked great. But it was one of my first projects and someone who was "helping" went a little overboard with the RTV. I believe that's why it's leaking again. So I ordered a new VCG and I'm going to do it, alone this time. I'm at 135k now and was wondering if I should just pre-emptively do VANOS seals, don't feel like going in here a third time... Your thoughts?
There is a large build up of oil up front which has dripped down to the lower radiator hose and caused some bubbling on the hose. It was less than 20k old but I replaced it anyways. I would like to avoid oil ruining the new hose.
projectmayhem713 is offline   Reply With Quote
Old 04-03-2014, 11:58 PM   #251
projectmayhem713
Sorry. Double post. Stupid ipad.
Old 04-25-2014, 09:10 AM   #252
KyleAndrew
My Ride: 2002 e46 330i
A note about the coil pack harness from someone that just did this job:
So I did my VCG, Vanos Seals, and Spark Plugs on Wednesday, and I wanted to share a note with everyone about a difficulty I ran into. First of all these instructions are fantastic.
When I went to remove my coil pack harness form the little clips, they started snapping one by one. I assume this is due to cars age (190k), harsh winters etc. etc. but I stopped touching it after snapping three clips. Turns out I was able to perform all of this work no problem without removing the coil pack harness. It just flipped on over with the valve cover and I handled it gingerly, removing the old gasket and installing the new one on top of the rest of the engine with a towel layed out on it. The coil pack harness is still fitted securely with the three snapped clips.
I'm sure I'm not the only one whose had this problem.
KyleAndrew is offline   Reply With Quote
Old 04-25-2014, 09:12 AM   #253
KyleAndrew
If you are at 135k and have never done your Vanos Seals, then you aren't 'pre-emptively' doing them at all. 99% chance they are shot. I just did both of these on Wednesday. Vanos Seals added considerable time to the work, but highly doable. Also, since you're in there... when is the last time your Spark Plugs were changed?
Old 07-16-2014, 07:32 PM   #254
Bimrboy
My Ride: 2001 330i
Great DIY, I just got my gasket today and plan on changing it on Sunday.
What keeps bugging me is that i can't find a torque wrench that i can use for this job (7.5ft-lb), i know some people say its not necessary but i plan on doing things properly on this car .
I'll also use it when i do the oil changes (18 ft-lbs) and some other small repairs, my budget is around 70$ any recommendations?
Bimrboy is offline   Reply With Quote
Old 07-16-2014, 07:35 PM   #255
jmb
My Ride: an old wagon
is there a Harbor Freight near you?
jmb is offline   Reply With Quote
Old 07-16-2014, 07:40 PM   #256
Bimrboy
My Ride: 2001 330i
Yes there is and i have my eye on this one:
http://www.harborfreight.com/3-8-eig...rench-807.html
But i was looking for something better as i have the money. If i don't find any other within my range i might go with the Pittsburgh.
Old 07-16-2014, 07:44 PM   #257
jmb
they have even smaller ones. same price but lower torque figures
http://www.harborfreight.com/1-4-qua...ench-2696.html
Old 07-16-2014, 07:50 PM   #258
Bimrboy
My Ride: 2001 330i
Yes but i cannot use this wrench over 22nm and the oil filter cap needs 25nm lol i'm thinking ahead about future jobs on this car, i'm looking for something that can do between 10nm to atleast 100nm.
Old 07-16-2014, 07:56 PM   #259
Dbills
My Ride: 99' 328i
I picked up an in/lb one from autozone for $20. It does 10-100nm just need a simple conversion.
Dbills is offline   Reply With Quote
Old 08-16-2014, 05:15 AM   #260
ih8ants
My Ride: '02 330Ci
did this on tues or weds. definitely a back breaker. engine has 103k (2.5k/4wks from me) with unknown maintenance history. saw smoke in the morning after parking, had a day of driving the next day so talked my local dealer down from 90$ for the gasket and 5.xx$ for each grommet to 50$ (ecstuning 41.50) and 1.15 (same as ecs). started around 530 and between cooking dinner, spending time with the gf, cleaning up the garage and the test drive it was all finished around 2am.
car spent a few years on catalina island, so it was a relief to see a clean everything once the VC was off.
OP thanks for the write up!!
ih8ants is offline   Reply With Quote
