Thread Tools Search this Thread Rating: Thread Rating: 87 votes, 5.00 average. Display Modes
Old 03-19-2012, 03:43 PM   #41
RiFTy80
My Ride: 2003 330xi
I just did the Valve Cover Gasket and Spark Plugs yesterday. It took about 2 1/2 hours going VERY carefully. Excellent write-up! My 03 xi has 82,500 miles. Side note: the computer calculated MPG average on my 30 mile drive this morning was about 2.5 mpg (10%) better than usual. Does changing the spark plugs make that much of a difference?
RiFTy80 is offline   Reply With Quote
Old 03-26-2012, 12:49 PM   #42
elie12
My Ride: 2001 Bmw 325i
Great DIY, was the first time for me working on my car, Thanks.
I did it for my 01 325i, but I might dropped one of the cover's washer inside without noticing. I opened it again to find it, but no clue where is at!. kept looking with magnetic screw driver looking all around but nothing where there. And after I gave-up thinking it might be missing from the start. I placed everything back and run the engine for a second, I could hear the ticking inside on the top of the engine ....luckily the engine still running. Again, I opened everything looking for this washer, but nothing so far. The car is parked, and I have no clue of what to do! Any help or advice what to do please?
elie12 is offline   Reply With Quote
Old 03-26-2012, 09:59 PM   #43
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
My Ride: 328i, M3, 525iT
elie12, I would get the brightest flashlight you can get ahold of and a mirror to try to find it, one other idea, is your splash shield under the engine still installed? If so you may want to drop it to see if the washer fell down there, I have a had a few things fall down there and couldn't see them until I dropped the shield.
ddaniel1 is offline   Reply With Quote
Old 03-27-2012, 08:52 PM   #44
caleb6
My Ride: 2005 330XI
Just finished this VCG replacement with VANOS seals, pre-cat 02 sensors and new spark plugs. Whew, pretty easy with the DIY's here - but until I got it all back together and had the chance to run it for a little - with NO check engine lights or other indications of something being wrong - I was scared. Alas, all is well and she's running stronger then ever.
thanks!
caleb6 is offline   Reply With Quote
Old 03-27-2012, 10:17 PM   #45
elie12
I heard the washer bouncing back and forth. I know its inside, but I couldn't see it with flash light and mirror even magnetic. Someone told me to check the oil pan, but I looked to the size of the hole is way smaller than the washer, unless it fit inside the valve hole. And that unlikely because of the sound was continuous and clearly from the top(not deep). I don't have experience in engines, but if i remove the camshaft I would make sure(I dont think its good idea, I have no clue how to place the camshaft back).
Old 03-27-2012, 10:46 PM   #46
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
You don't want to remove the cams, that is a huge job, if you heard it, it must have been contacting the cam or lifters, I would focus your search around the cams, lifters and valve springs. This thread on removing the cams shows some of the places to look.
http://forum.e46fanatics.com/showthr...0#post14098020
Old 03-27-2012, 11:10 PM   #47
elie12
Thanks man, I will keep looking and plan to remove the oil pan to change the gasket at the same time(to clear the doubt).
Old 03-28-2012, 10:53 AM   #48
Ivanhoe
My Ride: BMW 330 xi 2005
Great DIY, thanks for sharing , planning to do it very soon !!!
Ivanhoe is offline   Reply With Quote
Old 04-03-2012, 04:20 PM   #49
hk_bimmer
My Ride: e46
What if u cant take off the bolts on the plastic engine cover. Like i kept turning them (both) then try pull off and nothing. I see the bolts turning in circular motion but not going not moving up (loosen) reason is because I seen a greasy stain on the left plastic cover I tought must been oil dropped from oil change but its not.
hk_bimmer is offline   Reply With Quote
Old 04-03-2012, 04:42 PM   #50
Rickna
My Ride: '01 330xi - '09 IS-F
The bolts are held captive by the rubber gromets. So losen all of them and the cover should come off. You might need to gently pry to get the cover off.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 04-03-2012, 05:06 PM   #51
BYOB3amer
My Ride: 2002 325i
I think im about to try this within the next couple of weeks. Where are the parts located and how much do they cost
BYOB3amer is offline   Reply With Quote
Old 04-03-2012, 05:52 PM   #52
hk_bimmer
My Ride: e46
i tried
here is what i see
this is why i got worried
then i seen this
Old 04-03-2012, 05:54 PM   #53
hk_bimmer
My Ride: e46
i never took them off before i got the car then like 2 months later seent he engine cover like that and i tried take bolts off but no luck, i think somehow there stripped
Old 04-03-2012, 06:48 PM   #54
Rickna
You need to remove the scew covers. #15 in the pic.
2001 BMW 330xi
2009 Lexus IS-F
Old 04-03-2012, 07:17 PM   #55
caleb6
My Ride: 2005 330XI
yeah i was gonna say man - by plastic cover you mean number 11 above HK bimmer? take the four little square covers off (number 15 above) and remove the four bolts underneath - think they are 10mm to be exact. Then pop off both of the covers and then the 15 bolts on the Valve cover - well after taking off the other stuff like the DIY says.
Old 04-03-2012, 08:15 PM   #56
hk_bimmer
My Ride: e46
I know I took them off im talking about the bolts after the cap
Old 04-03-2012, 08:17 PM   #57
hk_bimmer
My Ride: e46
Yes but the four bolts wont come off theu just twist but dont move a inch up to loosen up
Old 04-06-2012, 07:25 AM   #58
Abe911
My Ride: 986S, E46, E91
Thanks for the great write up!
Where did you purchase the gasket set? BMW's parts list shows everything separate and from the pictures, I see that you purchased a set.
Thanks,
Abe911 is offline   Reply With Quote
Old 04-06-2012, 07:38 AM   #59
Rickna
Most online vendors offer kits.
2001 BMW 330xi
2009 Lexus IS-F
Old 04-09-2012, 02:18 PM   #60
joeycannoli
My Ride: 911
Thanks,
Got my stuff through Rogue Engineering
joeycannoli is offline   Reply With Quote
