Thread Tools Search this Thread Rating: Thread Rating: 86 votes, 5.00 average. Display Modes
Old 08-14-2012, 08:31 PM   #101
dylan.
My Ride: 135i
One more thing! Does the kit from fcpeuro even include the valve cover grommets???
dylan. is offline   Reply With Quote
Old 08-14-2012, 08:36 PM   #102
Nyl777
My Ride: 2004 325xi
No, it is only the VCG.
Nyl777 is offline   Reply With Quote
Old 08-14-2012, 08:40 PM   #103
dylan.
My Ride: 135i
Alright thanks man
Old 08-14-2012, 08:47 PM   #104
Nyl777
My Ride: 2004 325xi
No problem. Good luck again. In my case I did not change the grommets since they all look pretty good. I just returned them from its original position.
Old 08-14-2012, 08:52 PM   #105
dylan.
My Ride: 135i
Ya I'm just going to replace them as well. I might as well just to be sure.
Old 08-16-2012, 07:56 AM   #106
naMKaren
My Ride: 2001 330i
Why does this need to be done?
What exactly is being changed and what is this process prevent?
naMKaren is offline   Reply With Quote
Old 08-16-2012, 09:46 AM   #107
Rickna
My Ride: '01 330xi - '09 IS-F
You could read the 1st few pages of the thread...?
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 08-18-2012, 08:23 PM   #108
dylan.
My Ride: 135i
just finished the job. went pretty dang smooth except for trying to find a bolt for a good two hours lol but no more leaking oil so i'm pleased
Old 08-18-2012, 10:47 PM   #109
Nyl777
My Ride: 2004 325xi
Nice!!!
Old 08-20-2012, 05:51 PM   #110
dylan.
My Ride: 135i
So my car is still smoking from the left rear of the engine after i did this job. Soooo confused. Anybody have any idea what else this could be from??
Old 08-20-2012, 06:23 PM   #111
Sansho
My Ride: 2001 325i
Did you apply RTV sealant around the front moons and seams like this, and on the rear half moons?
If you use a mirror and light to look at the rear half moons, are they leaking?
Sansho is offline   Reply With Quote
Old 08-20-2012, 06:49 PM   #112
dylan.
My Ride: 135i
Damn. I only applied the rtv sealant to the front moons and not the rears.I just put my finger back there to feel for some oil but i didn't really get any on my hands.
Should I take it back apart and peel off the sealant on the front moons and just reapply fresh stuff to both the front and back, or could this just be oil burning on some pipes that was from the leak before i did the valve cover gasket?
Old 08-20-2012, 07:11 PM   #114
dylan.
My Ride: 135i
Shuuuuucks. haha alright I will get right on that.
Old 08-20-2012, 07:44 PM   #115
2003silver330i
My Ride: 03 BMW 330i
You sure that it isn't old oil from before that is burning?
2003silver330i is offline   Reply With Quote
Old 08-20-2012, 07:48 PM   #116
dylan.
My Ride: 135i
That's what I'm thinking, yeah. But i just about have the valve cover off again so i can reapply the rtv sealant to both the front and rear moons, since I olnly did the front moons before.
Old 09-01-2012, 03:37 PM   #117
Hovs13
My Ride: E46 325ci
Just replace mine. Great post.
Hovs13 is offline   Reply With Quote
Old 09-02-2012, 08:55 PM   #118
lecourasa
My Ride: 2001 330i
I'm trying to do this job on mine. Everything was going smoothly until I got the valve cover off. In all the YouTube videos I watched the gasket came right off. However, my 2001 330i has 145k miles on it and the original gasket so the gasket is stuck in the valve cover pretty good. Is there some trick to detaching the gasket from the valve cover?
Also, having a similar problem with the parts of the gasket around the spark plug sockets, only they have pretty much turned to hard plastic. Any hints or help will be appreciated. Thanks.
Alex
lecourasa is offline   Reply With Quote
Old 09-02-2012, 09:34 PM   #119
Crestwood1001
My Ride: 2001 325xi
No just be very careful not to crack the cover
Crestwood1001 is offline   Reply With Quote
Old 09-02-2012, 11:35 PM   #120
trj
My Ride: 325Ci
Alex
Try running the engine with the VC on for a couple of minutes. Just to get it warm enough, but not hot to burn yourself. Our blocks get very hot in no time. When its warm it might come off more easily.
Or may be try a blow dryer to heat the gasket. Prying with a thin screw driver very carefully not to damage the aluminum surface may help. But very gently.
Also clean the mating surfaces off oil and debris once its out before putting the new one in.
Be very careful in tightening the cap nuts, if you over tighten you will break a stud and you will have to do the whole thing again.
Ask me how I know and those studs and cap nuts are not very cheap at the dealership.
Once you get to a point where you feel the resistance on the washer, 1/8th turn of the wrench in a star pattern.
