Thread Tools Search this Thread Rating: Thread Rating: 87 votes, 5.00 average. Display Modes
Old 10-20-2012, 07:35 PM   #141
kowalzekc
My Ride: 99 328i
Originally Posted by DRE97 View Post
There is a torque pattern. I do not have it handy. You start from the middle working crisscross towards both ends. Similar to tightening an intake manifold on a V8 of a 40 year old car.
Agree, start on one side, go straight accross, then just creat a circle going outwords. DO NOT START AT THE ENDS.
kowalzekc is offline   Reply With Quote
Old 10-22-2012, 04:51 PM   #142
pmagloir
My Ride: 2004 330Ci
I would appreciate some advice: I just broke a stud on top of the VCG as my torque wrench was not properly calibrated. How can I take it off?
pmagloir is offline   Reply With Quote
Old 10-22-2012, 05:24 PM   #143
Rickna
My Ride: '01 330xi - '09 IS-F
Drill the stud and use an "easy-out" or screw extractor.
Looks something like this-
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 10-23-2012, 01:09 AM   #144
Nickvjr
My Ride: 2004 330Ci Conv.
Send a message via AIM to Nickvjr Send a message via Yahoo to Nickvjr
I used this extra or set to remove broken VCG bolts from my cousins E90 last year. Take your time when drilling... slow and steady wins this race! Good Luck!
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
Old 10-23-2012, 01:45 AM   #145
trj
My Ride: 325Ci
no need for an extractor, if you just broke the stud part in the cap nut.
Just remove the VC and use 10mm socket to remove the broken stud.
Buy a replacement stud and nut cap from the dealer if you are in a pinch.
A set will cost you almost $10 for a set.
Its not cheaper online too.
Been there done that.
Old 10-23-2012, 06:50 PM   #146
pmagloir
My Ride: 2004 330Ci
Thank you all for your responses. As Tri indicated, I was able to remove the broken stud with a 10mm socket. I just got the stud from the dealership and I was wondering how tight it should be?
Old 10-23-2012, 07:17 PM   #147
haurelio
My Ride: 2001 bmw 325i
10nm.. double check on page 1 of this thread..
Old 10-26-2012, 02:23 PM   #148
Jperry666
My Ride: 2002 325i 5spd
Did mine today. All went smooth. Spark plugs were sh*t.
Jperry666 is offline   Reply With Quote
Old 10-26-2012, 10:39 PM   #149
rkneeshaw
My Ride: 330i ZHP
For those looking for the right sealant to use:
http://www.permatex.com/products/aut...t_Dressing.htm
The manual calls for "3-bond 1209" but it appears its very hard to get anymore. Some BMW dealerships are using Hylomar Universal Blue instead. I have yet to see an official document from BMW on this though.
Hylomar was bought by Permatex.
The product descriptions for Permatex Ultra Rubber Gasket Sealant (#85409) is nearly identical to Hylomar Universal Blue.
Additionally it is specifically for sealing rubber gaskets and keeping that rubber soft and pliable. Our valve cover gaskets are rubber.
In my opinion, using the Permatex 85409 is the best solution here to ensure long seal life and lowest chance of leaks.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 10-27-2012, 08:17 AM   #150
Sansho
My Ride: 2001 325i
There certainly are choices for the sealer used. I used Permatex Ultra Copper, following the Beisan Systems procedure, as I was doing the vanos at the same time. It's done fine for the past 17K miles.
Sansho is offline   Reply With Quote
Old 10-27-2012, 10:33 AM   #151
pmagloir
My Ride: 2004 330Ci
Thank you OP for the excellent step-by-step directions. Unfortunately, after changing the VCG, I noted that the red oil light is flashing intermittently when I am driving at low RPMs or at a stop light. I checked to see if there were any leaks and I do not see any. Oil level is fine. Does anyone have any suggestions regarding this issue?
Old 10-27-2012, 01:09 PM   #152
Sansho
My Ride: 2001 325i
Red oil lamp means low oil pressure. Perhaps that sensor coincidentally is failing?
Part #12 below, list $12 BMW, discounting dealer ~$9.
Old 10-28-2012, 06:46 PM   #153
farukh
My Ride: BMW 325i 2002
Hi, great thread! I have a question though about the torque! 10 nm - what exactly does that mean... or actually, without even getting into technical details, how would I know that I tightened the valve cover properly?
farukh is offline   Reply With Quote
Old 10-28-2012, 09:24 PM   #154
Sansho
My Ride: 2001 325i
You would use a torque wrench to show when you've reached 10nm. Newton meters (nm) is a measure of torque, just like foot lbs or inch lbs. Torque wrenches can come with a dial (mechanical or electronic) or just click when you hit the value you set.
Old 10-29-2012, 05:01 AM   #155
Rickna
Torque is a measurement of force, or in this case how tight the nuts/bolts are. For the valve cover it is important to have uniform torque.
2001 BMW 330xi
2009 Lexus IS-F
Old 10-29-2012, 06:18 AM   #156
tttomttt
My Ride: 2003 330xi
permatex
Oxygen sensor safe? Went through their MSDS and instructions but could not find any info.
tttomttt is offline   Reply With Quote
Old 10-29-2012, 09:00 AM   #157
farukh
Damn, I didn't even know such exist lol I wonder how much they are... gotta do my research! Thanks!
Old 11-13-2012, 01:01 PM   #158
Rumplemenz
My Ride: 05 330i zhp/15 335i
First off thanks to the OP... DIY's are such a huge help and wow he sure did take his time with the write up.. awesome
ON ANOTHER NOTE SPEAKING FROM EXPERIENCE
1 - Follow the proper tq specs
2 - Use proper technique in tightening VC bolts
Why am I saying this? Well I replaced my gasket about 2 years/20k miles ago. And the famous smell thru the cabin vents has returned. I need to replace the valve cover gasket once again (slight leak in rear and in front)
I didn't follow proper tq specs and I didn't tighten bolts, starting in the center, in a criss cross/star like pattern.
So don't be like me and inconvenience yourself.
Do it right the first time!
Rumplemenz is offline   Reply With Quote
Old 11-13-2012, 01:06 PM   #159
farukh
+1
Old 11-15-2012, 07:07 PM   #160
edbubuli
My Ride: 325i
BMW in N.J is quoting me for the VCG for $600.00!!!! I'll try to check Bimmer Clinic near Avanel...
edbubuli is offline   Reply With Quote
